Audio qube
An audio qube acts as a secure handler for potentially malicious audio devices, preventing them from coming into contact with dom0
(which could otherwise be fatal to the security of the whole system).
It thereby mitigates some of the security risks of using USB
devices
and Bluetooth devices.
Nonetheless, we strongly recommend carefully reading the security warning on USB input
devices
devices before proceeding.
With an audio qube, many kinds of devices can be used (that previously were either unsafe or impossible to use in dom0):
  • Jack
  • HDMI/DisplayPort/…
  • USB audio devices
  • Bluetooth
Manual setup
In this section, we will explain how to manually set up an audio qube.
A lot of alternatives configurations are also possible.
Creating the qubes
  1. Create a template named ‘audio-template’ – You can clone ‘fedora-XX’ template (or a fedora minimal template) for that –
  2. Then create an appvm named ‘audio-app’ and mark it as a disposablevm template
  3. Finally, create a disposablevm named ‘sys-audio’
Note: By making “sys-audio” disposable, volume configuration will not be
persistent.
See below, some screenshot of this configuration
Result of \`qvm-prefs audio-app\`
audiovm               D  sys-audio
autostart             D  False
backup_timestamp      -  1689304025
debug                 D  False
default_dispvm        D  fedora-dvm
default_user          D  user
dns                   D
gateway               D
gateway6              D
guivm                 D  dom0
icon                  D  templatevm-gray
include_in_backups    D  True
installed_by_rpm      D  False
ip                    D
ip6                   D
kernel                D  6.4.8-1.fc37
kernelopts            D  swiotlb=2048
keyboard_layout       D  fr+oss+
klass                 D  AppVM
label                 -  gray
mac                   D  00:16:3e:5e:6c:00
management_dispvm     D  default-mgmt-dvm
maxmem                D  4000
memory                D  400
name                  -  audio-app
netvm                 -  None
provides_network      -  False
qid                   -  50
qrexec_timeout        D  60
shutdown_timeout      D  60
start_time            D
stubdom_mem           U
stubdom_xid           D  -1
template              -  audio-template
template_for_dispvms  -  True
updateable            D  False
uuid                  -  62ad295e-cfdc-4cbd-a5a7-09284dff87d9
vcpus                 D  2
virt_mode             D  pvh
visible_gateway       D
visible_gateway6      D
visible_ip            D
visible_ip6           D
visible_netmask       D
xid                   D  -1
Result of \`qvm-prefs audio-template\`
audiovm             D  sys-audio
autostart           D  False
backup_timestamp    -  1689304024
debug               D  False
default_user        D  user
dns                 D
gateway             D
gateway6            D
guivm               D  dom0
icon                D  templatevm-black
ip                  D
ip6                 D
klass               D  TemplateVM
label               -  black
maxmem              D  4000
memory              D  400
name                -  audio-template
netvm               D  None
provides_network    D  False
qid                 -  49
qrexec_timeout      D  60
start_time          D
stubdom_mem         U
stubdom_xid         D  -1
updateable          D  True
uuid                -  43dfeca9-41b6-4b85-b462-2c566cc5da1f
vcpus               D  2
virt_mode           D  pvh
visible_gateway     D
visible_gateway6    D
visible_ip          D
visible_ip6         D
visible_netmask     D
xid                 D  -1
Result of \`qvm-prefs sys-audio\`
audiovm             D  sys-audio
auto_cleanup        D  False
autostart           -  True
debug               D  False
default_dispvm      D  audio-app
default_user        D  user
dispid              -  2229
dns                 D
gateway             D
gateway6            D
guivm               D  dom0
icon                D  dispvm-gray
ip                  D
ip6                 D
kernelopts          D
klass               D  DispVM
label               -  gray
maxmem              -  0
memory              D  400
name                -  sys-audio
netvm               -  None
qid                 -  51
qrexec_timeout      D  60
start_time          D  1693413928.06
stubdom_mem         U
stubdom_xid         D  2
template            -  audio-app
updateable          D  False
uuid                -  9422a856-7b81-464d-9fd5-987ef2cf99f7
vcpus               D  2
virt_mode           -  hvm
visible_gateway     D
visible_gateway6    D
visible_ip          D
visible_ip6         D
visible_netmask     D
xid                 D  1
Installing the required packages
In ‘audio-template’, install the required packages:
sudo dnf install -y pipewire-qubes qubes-audio-daemon pavucontrol qubes-core-admin-client qubes-usb-proxy alsa-utils
Optional package, software to configure sound effect, like noise cancellation:
sudo dnf install easyeffects
If you want to be able to use Bluetooth devices, you also need to install the
following packages:
sudo dnf install -y blueman
And the required drivers for your Bluetooth hardware, for example, some hardware
will need this package:
sudo dnf install -y linux-firmware
If you want to have a systray to control the sound, you can install this package
sudo dnf install -y pasystray
Note for \`debian-13-minimal\` templates
The same command for debian VM, minus the package that doesn’t exist in debian :
apt install pipewire-qubes qubes-audio-daemon pavucontrol qubes-core-admin-client qubes-usb-proxy alsa-utils blueman pasystray
Configuring PCI passthrough
Then we need to passthrough the PCI devices we want to ‘sys-audio’.
It needs to be configured as HVM, without memory balancing.
Configuring sys-audio as the default audiovm
In dom0 execute the following command:
qubes-prefs default_audiovm sys-audio
Testing sound
Note: qubes that were running before the moment the audiovm has started will not
have sound. See Troubleshooting section.
Now you can check that sound can be played in ‘sys-audio’ by executing the
following command in ‘sys-audio’.
aplay /usr/share/sounds/alsa/Noise.wav
In the screenshot below, I passed my audio jack device to
‘sys-audio’. The name of these devices are different on every hardware.
Note: You could permanently assign a usb device to a qube using “Qubes Global Config” → “Device Assignements” → “Device Assignment” → “Add new rules”.
You can check what hardware is available using ‘pavucontrol’:
See the ‘Troubleshooting’ part if you have trouble with USB audio devices.
Bluetooth configuration
Nothing specific to QubesOS to configure your Bluetooth device, so the
explanation will be minimal.
  1. In ‘sys-audio’ launch ‘blueman-manager’
  2. Pair with your Bluetooth hardware
  3. Activate the audio profiles
When you configure a Bluetooth device, the configuration files are stored as root in /var/lib/bluetooth. If you want the device to be permanently known by the audiovm (even after reboot), you need to either copy this folder to the template qube, or have any other means of deploying back the configuration that have been saved to /var/lib/bluetooth
Configuring services
Add the custom service ‘audiovm’ using QubesManager for your audio qube.
Adding this service will launch at startup the following command:
qvm-start-daemon --all --watch
Bluetooth service
Additionally, if you intend to use bluetooth services, you probably want to also enable “blueman” service
Configuring policy
Finally, we need to create a policy file to allow the required communications between
‘sys-audio’ and the other qubes.
In dom0, create the file ‘/etc/qubes/policy.d/50-sys-audio.policy’ with the
following content:
admin.Events          *                                          sys-audio     @adminvm                  allow target=dom0
admin.vm.CurrentState *                                          sys-audio     @adminvm                  allow target=dom0
admin.vm.List         *                                          sys-audio     @adminvm                  allow target=dom0
admin.Events          +property-set_audiovm                      sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +property-pre-set_audiovm                  sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +property-pre-reset_audiovm                sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +property-reset_audiovm                    sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +property-reset_is_preload                 sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +property-reset_xid                        sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +property-reset_stubdom_xid                sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +domain-stopped                            sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +domain-shutdown                           sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +domain-spawn                              sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +domain-start                              sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.Events          +connection-established                    sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.CurrentState *                                          sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.List         *                                          sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.property.Get               +virt_mode                   sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.property.Get               +klass                       sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.property.Get               +audiovm                     sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.property.Get               +is_preload                  sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.property.Get               +xid                         sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.property.Get               +stubdom_xid                 sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.feature.CheckWithTemplate  +audio                       sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.feature.CheckWithTemplate  +audio-model                 sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.feature.CheckWithTemplate  +supported-service.pipewire  sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.feature.CheckWithTemplate  +audio-low-latency           sys-audio     @tag:audiovm-sys-audio    allow target=dom0
admin.vm.feature.CheckWithTemplate  +gui                         sys-audio     @tag:audiovm-sys-audio    deny notify=no
admin.vm.property.GetAll *                                       sys-audio     @tag:audiovm-sys-audio    deny notify=no
Once this is done, you can restart your ‘sys-audio’ qube.
If everything has been configured correctly, you should see the active qube
configured to use ‘sys-audio’ in the ‘pavucontrol’ interface of ‘sys-audio’.
Installing the required audio package in the clients qubes
It is already done out of the box for most template.
For archlinux template and debian minimal template, you need to install the pipewire-qubes package.
Disabling audio for qubes that doesn’t need it
You should disable the audiovm for qubes that doesn’t need it.
For example “sys-net” “sys-firewall” and others qubes that will never need audio.
Case 1: Most of your qubes need to have audio
By default, configure all qubes to use ‘sys-audio’ as the audiovm
Then remove the audiovm from the qubes that doesn’t need audio
qvm-prefs sys-net audiovm ''
Case 2: Most of your qubes doesn’t need to have audio
By default, configure all qubes to use nothing as the audiovm
qubes-prefs default_audiovm ''
Then add the audiovm for the qubes that need audio
qvm-prefs sys-net audiovm 'sys-audio'
Optional step: Noise suppression
In “audio-app” you can configure noise suppression: GitHub - werman/noise-suppression-for-voice: Noise suppression plugin based on Xiph's RNNoise · GitHub
Audio recording is much better, at the cost of a bit of cpu consumption
Important note:
Most user will never encounter such a case, but for people that have a LOT of qubes running, it is important to properly configure the audiovm property, it need to be empty for qubes that will never use audio
There is a maximum of ~19 qubes that can be running simultaneously without using audio (but with a audiovm configured). After that number, when a new qube is created, sys-audio will stop working. (xenstore quota issue, audiovm - Argument list too long - no sound for new qubes · Issue #8966 · QubesOS/qubes-issues · GitHub )
Microphone note:
You have to attach the device named “dom0:mic” to the qube you want to be able to record your microphone input
Shortcuts
In your desktop environment, you can configure shortcuts.
Turn up the volume:
qvm-run sys-audio 'amixer sset Master 2%+'
Turn down the volume:
qvm-run sys-audio 'amixer sset Master 2%-'
Toggle the audio between muted and un-muted
qvm-run sys-audio 'amixer sset Master toggle'
Additional technical information
In ‘sys-audio’, the system needs to find all the qubes of the system (and that
is configured to use ‘sys-audio’ as an audiovm) and create
the communication channel to receive the audio information from those qubes.
The software responsible for that can be launched manually like that:
In any qube, you can find the XID of your configured audio VM with this command:
qubesdb-read -w /qubes-audio-domain-xid
For pipewire setup: In any qube, to start pipewire with the ‘vchan – *’ modules, run:
systemctl --user restart pipewire
You can have multiple audiovm. You can configure each qubes to use a specific
audiovm:
qvm-prefs QUBE_NAME audiovm
qvm-prefs QUBE_NAME audiovm MYAUDIOVM
Special cases of non-linux HVM.
Support have been added by the QubesOS team, so no additional configuration is needed. I haven’t yet personnally tested it. If it doesn’t work, the old way of doing that is below
Old way of doing that
Windows qubes don’t support audiovm at the moment, and are hardwired to dom0 for
audio processing.
Below, example to how to add audiovm for windows qubes.
First, you need to manually edit the xen template file in dom0
“/usr/share/qubes/templates/libvirt/xen.xml”
Above the line
<emulator
Add the following content:
{% if vm.audiovm %}
 {% set audiovm_xid = vm.audiovm.xid %}
{% else %}
 {% set audiovm_xid = 0 %}
{% endif %}
In the rest of the file, you will find two occurrences of lines starting by “cmdline=”,
append the following content to these two lines (before the closing double-quote)
 -qubes-audio:audiovm_xid={{ audiovm_xid }}
Stubdom-linux-rootfs
Then, you need to modify to patch “stubdom-linux-rootfs”.
In dom0, in your home directory, execute the following bash command:
mkdir stubroot
cp /usr/libexec/xen/boot/qemu-stubdom-linux-rootfs stubroot/qemu-stubdom-linux-rootfs.gz
cd stubroot
gunzip qemu-stubdom-linux-rootfs.gz
cpio -i -d -H newc --no-absolute-filenames < qemu-stubdom-linux-rootfs
rm qemu-stubdom-linux-rootfs
nano init
After the line starting by “audio_model=”, add:
# Extract network parameters and remove them from dm_args
audio_args=$(echo "$dm_args" | sed -n '/^-qubes-audio:/p')
dm_args=$(echo "$dm_args" | sed '/^-qubes-audio:/d')
get_audio_arg() {
    echo "$audio_args" | sed -n 's/^.*[:,]'$1'=\([^,]\+\).*$/\1/p'
And in the rest of the file, replace
module-vchan-sink domid=0
by
module-vchan-sink domid=$(get_audio_arg 'audiovm_xid')
Save and close the file. Then run:
find . -print0 | cpio --null -ov \
--format=newc | gzip -9 > ../qemu-stubdom-linux-rootfs
sudo mv ../qemu-stubdom-linux-rootfs /usr/libexec/xen/boot/
Stubdom-linux-full-rootfs
Redo the same things but for the file “stubdom-linux-full-rootfs”
Known issues. HELP WANTED
  • Keyboard layout switching issue
  • Audio quality in some cases (at least jack seems to be problematic)
Troubleshooting
USB devices
Some USB audio controller cannot be passed from a USB qube to an audio qube.
In those cases, the audio qube need to also be a USB qube to have direct
access to the PCI USB controller.
For example, this is the case for the Sennheiser GSX 1XXX.
No sound in qubes started before audiovm
This issue is that the vchan modules of the pulseaudio/pipewire daemon running in the already started qubes are
not using the correct audiovm xid (ID of the xen vm).
In special configuration, you may need to manually set the “domid” parameter of
the vchan modules.
Salt
A community effort to have this configuration done by a salt script is available here: qusal/salt/sys-audio at main · ben-grande/qusal · GitHub
Links
Document sys-audio · Issue #8093 · QubesOS/qubes-issues · GitHub
qvm-start-daemon - audiovm - keyboard layout · Issue #8109 · QubesOS/qubes-issues · GitHub
qubes-doc/user/advanced-topics/audio-qubes.md at sys-audio · neowutran/qubes-doc · GitHub
qubes-attachment/doc at audiovm · neowutran/qubes-attachment · GitHub
Thanks to the many peoples that made this guide possible.
Thanks also to @fb2043 for debian guide
How to make sys-audio and how to use bluetooth
Proper guide on how to use sys-audio (AudioVM) must be created
Why does sys-usb need so much RAM?
How do I stop screen dim/screen energy/sleep mode while watching youtube?
Systemd inclusion in QubesOS
How to change default volume in pasystray
Sys-audio and bluetooth - how safe?
Unable to get sys-audio qube to auto start on boot
Problem with audio qube
Sys-audio doesn't start
Youtube und audiowiedergabe funktioniert nicht korrekt in Qubes 4.1.2
No Audio after fresh install using Kernel latest
No audio on linux mint standaloneVM
Audio output from one qube as mic input for another vm?
Saffire Pro 24 firewire audio interface recognized but loss of sound and system crash after audio playback
Xen Issue After Stubdom Update
Is analog audio safe to not need an audio qube?
How to get sys-audio working in other VMs using an audio jack?
Windows 10 installation stops halfway through
Blueman Bluetooth headset confusion
Sys-audio drops qubes on restart
Changer sys-usb ---) sys-audio
AiStone X6AR57TY aka TongFang X6 16" Intel High-end Performance
How can I correctly use my USB headphones?
Can't play audio via Bluetooth headphones
Bluetooth usb persistance in sys-audio with built in or external usb dongles guide
NovaCustom NV41 Series
Can't get VM audio working after accidently did PCI strict reset
Can't find any bluetooth device or controller, am i missing something or is it hardware-level problem?
Please Help! How do I use my bluetooth headphones with sys-net in other qubes?
Can't pipe audio from dom0 into sys-usb
Trying to setup a new audio qube but starting qube restarts the whole OS/computer
Would like to reset audio settings back to default after failed sys-audio setup
What would you like to see improved in Qubes OS?
How to make an appvm a template at the same time
Major problems with starting any qube
Sys-audio Has Failed to Start
Another bluetooth headphone issue..help,please
How can I get my bluetooth headset to connect to Debian 13 minimal?
Qubes 4.3 r4 - inconsistent installation - sys-bluetooth missing
Is there a fast way to 'reset' sys-audio?
Using External Audio Devices
Computer does not shutdown, it reboots - reprise
Introduction to Qubes OS when you do not know what it is
How to create an audio VM (sys-audio) and have Bluetooth audio support in it?
Are sys-audio and sys-gui implimented by default in R4.2.4?
Audio VM with Intel Arrow Lake 15th gen
Has anyone gotten sys-gui-gpu to work in r4.3?
Qubes 4.2.4 no sound sent to external speakers
Sys-audio not working in archlinux standalonevm
Qubes won't boot after audio qube creation
Global, irreversible audio degradation with waydroid and sys-audio
Split "something" and other paranoia gimmicks - what would you setup for end users' Qubes OS installation by default?
How to use Bluetooth tethering via qube that is not sys-net
How to fix 0.2s audio delay in QubesOS?
To the devs, because have no github account - static xid
Arguments in favor of sys-audio/AudioVM?
Audio dropouts and stutter
Mic audio transfer -> rdp session on whonix
Framework Laptop 16 (AMD Ryzen 7040 Series)
Is it safe to use bluetooth with Qubes?
Are there any USB speakers that can be used in QubesOS without any configuration?
Sys-audio Qubes v4.2 / denied admin.vm.list from sys-audio to dom0
Startup lag for VM with `pulseaudio-qubes` but no `audiovm`
Fixing audio after update
Sys-audio with pci-passthrough issue: no codecs initialized
I get an error when attaching USB audio
How to create bluetooth qube on Novacustom NV41?
Bluetooth headset not working
Is there are an easier way to configure audio in Qubes?
After a few days of operation, all Qubes sound plummy
USB Headphones don't work
Many thanks to this detailed and comprehensive guide!
One more question, is the part of “Special cases of non-linux HVM” upstreamable? That would benefit every user of audio vm.
If some people try it and confirm that it work as expected, someone could send a pull request
Thanks for this guide. I have 4.1. I got to this:
qvm-prefs default_audiovm sys-audio
and I got in response:
usage: qvm-prefs [--verbose] [--quiet] [--help] [--help-properties]
                 [--hide-default] [--get] [--set] [--default]
                 VMNAME [PROPERTY] [VALUE]
qvm-prefs: error: no such domain: 'default_audiovm'
What did I do wrong?
wrong command, re-read the guide…
My bad. Thank you. I’ve never used qubes-prefs before.
Another question: is bluetooth a PCI device that needs to be attached to sys-audio?
I only have one audio device in the “Available devices” list in sys-audio Settings. And I attached connected it to sys-audio.
it is usually a USB device with a weird name. Forgot to add the screenshot
These are my available devices. I have USB for USB-C and USB 3.2. All 3 USBs are assigned to sys-usb. Would you be able to recognize Bluetooth?
usb device showing up once you started your sys-usb, not pci device
Thanks. Do I need to connect bluetooth via the Devices Manager on every boot?
You could permanently assign it to the audiovm.
My example, in dom0:
qvm-devices usb attach --persistant sys-audio sys-usb-1:2-6
Thanks! I will test.
You may have had some typos. Here’s what I will try:
qvm-device usb attach --persistent sys-audio sys-usb-1:2-6
indeed, it is getting late :slight_smile:
ofcourse you need to adjust this part “sys-usb-1:2-6”
I think xen.xml will be overwritten on at least kernel update (I am absolutely not sure in which cases this happens, but it does happen), so maybe it would be a good idea to add this notice to OP.
xen.xml can be overwritten, Stubdom-linux-rootfs too, qvm_start_daemon too
I followed all the steps. Here’s a quick feedback.
I opted for the:
Because I don’t know how to patch source code.
It works! Bluetooth audio works. It has two options: high quality listening mode, and low quality headset mode.
But sys-audio does not boot on start despite having chosen this option. And I couldn’t figure out how to get the mic from the bluetooth device (headset mode) to be the main mic for the computer.
One more thing. Bluetooth device name changed from 4:10 to 2:10, so the persistent attached failed me once so far.
I don’t know how to easily do that (aka: without custom code).
You could have a script in dom0 that scan usb devices / hook the usb qubes event, and automatically attach them to sys-audio when they are detected.
Around 10 lines of bash should be enough to write a dumb implementation of that.
First of all, thank you for this great guide, @neowutran.
I wanted to know if anyone here had a similar issue. I have gone through all of the steps in the guide successfully up to the “Configuring policy” step with policy file created and audio vm rebooted. The only deifference from the guide is that I’ve applied the steps to my sys-usb qube instead of creating a new sys-audio qube. I have the sound working in my sys-usb qube and all of the other qubes use it as their audio vm, but when I try to play back any sound in any qube besides sys-usb I get the following:
$ aplay /usr/share/sounds/alsa/Noise.wav
ALSA lib confmisc.c:855:(parse_card) cannot find card '0'
ALSA lib conf.c:5181:(_snd_config_evaluate) function snd_func_card_inum returned error: No such file or directory
ALSA lib confmisc.c:422:(snd_func_concat) error evaluating strings
ALSA lib conf.c:5181:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1334:(snd_func_refer) error evaluating name
ALSA lib conf.c:5181:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5704:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2666:(snd_pcm_open_noupdate) Unknown PCM default
aplay: main:834: audio open error: No such file or directory
Or if I try to play back some video, for example, it gets stuck until I mute it.
