Sys-audio Has Failed to Start
Everytime i start sys-audio, it gave me that pop-up: Qube sys-audio has failed to start: Internal Error: Active 0000:05:00.0 devices on bus with 0000:05:00.1, not doing bus reset
This is the guide i followed. I stoped at “Testing sound” Step.
Devices attached to sys-audio:
05:00.1 Audio Device: NVIDIA Corporation GP106 High Definition Audio Controller
07:00.4 Audio Device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Templated used for audiotemplate: kicksecure-17
Did you check that they are in different iommu groups? (You need to boot to a separate non-Xen OS for that.)
If your devices are in different IOMMU groups, but you still get this message, enable the “no-strict-reset” option for PCI passthrough (you can do that from the Qube Manager settings, or through the command line in dom0).
