I still have to do all of this to have audio in my qube?
Can i somehow configure direct passthrough to a speaker and a microphone for one qube?
Audio should work out of the box in you use the PCI audio device connected to dom0 as audio input/output.
If you want to use USB device for audio input/output then you can connect this USB device directly to the qube to use it there.
Should it work out of the box for standalone kali hvm?
Is it based on a kali template or installed from ISO?
Installed from ISO. If you install kali based on kali template you can get audio working out of the box?
I guess audio should work for kali installed from ISO as well, but you need to set the audio-model feature for your kali qube in dom0:
qvm-features YourKaliQubeName audio-model ich6
At least it works for WIndows:
- audio output and input (available even without QWT installation if
qvm-features audio-modelis set asich6)
Thank you! It works
