After trying and failing to set up an audio qube using the guide here, I would like to reset my audio back to what it was before.
Previously, I could play YouTube videos in Firefox and hear the sound via an audio jack connected to my headphones. Currently, I can no longer hear audio though the video is clearly playing.
Not sure what to do. I’ve removed the audio policy file I created and also deleted the sys-audio VM I’d created for this purpose.
Do I need to also delete the audio-template and audio-app for sound to go back to what it was?
I think that I am using the right Volume Control since screenshots get saved in the qubes_user Downloads folder of dom0. Not sure how I can attach them here to show what output devices I have.
As of now, toggling them on or off and/or selecting the different options they offer, doesn’t result in sound appearing for the playing video in Firefox. I assume that if I select the correct one, then I should hear sound immediately.
There should be devices in the Output Devices tab but there is no devices there.
Maybe it’s because your audio device was attached to sys-audio first and it’s not working after it was returned to dom0 when you shut sys-audio down.
Did you reboot the system after removing the sys-audio?
Also I don’t know which audio device do you use, there are three audio controllers in the Configuration tab but two of them are Off. Maybe you need to turn them on there.
