Sys-audio with pci-passthrough issue: no codecs initialized
I’m building a sys-audio according to the guide: Audio qube
However, the sound card being passed through (snd-hda-intel) is not recognized in sys-audio:
nd_hda_intel 0000:00:06.0: azx_get_response timeout, switching to polling mode: last cmd=0x200f0000
snd_hda_intel 0000:00:06.0: No response from codec, disabling MSI: last cmd=0x200f0000
snd_hda_intel 0000:00:06.0: Codec #2 probe error; disabling it...
snd_hda_intel 0000:00:06.0: no codecs initialized
This is on a system with sys-gui-gpu with the integrated gfx passed through to sys-gui-gpu. The same happens if I pass-through the sound card to sys-gui-gpu. Only when both the GPU and sound card reside in dom0, the sound card is properly recognized.
I already tried a few kernel options but to no avail:
kernelopts(sys-audio): nopat iommu=soft swiotlb=8192 snd_hda_core.gpu_bind=0 snd_hda_codec_hdmi.enable_acomp=n
I’m hiding both pci devices from dom0, so I don’t think any dom0 modules / module options are related.
All sys domU use the fedora-40-xfce template with the packages installed as per the sys-audio and sys-gui-gpu guides.
Maybe you could try a different version of linux kernel. I had a different problem but with similar symptoms and fixed it downgrading the kernel version (see this link)
Unfortunately it’s unrelated to the kernel - went back as far as 6.6.
Here my observations:
  • audio subsystem passed through seperate sys-audio: no luck (regardless of snd_hda_core.gpu_bind setting)
  • audio subsystem passed through to sys-gui-gpu (along with the GPU itself obviously):
    • snd_hda_core.gpu_bind unset or set to “1”: same behaviour; azx_get_response timeout, codec not initialized
    • snd_hda_core.gpu_bind set to “0”: card detected snd_hda_intel loaded - azx error message gone but still “no codecs found” and as result no playback device, no controls
Not sure if gpu_bind=0 would allow to output via HDMI at all.
