Problem with audio qube
After following this guide: Audio qube
now I’m stuck at the step where I am supposed to run sys-audio and check the audio by playing Noise.wav, because I can not start it.
Here is a picture of the attached devices to sys-audio and the error message I got at the top right of the screen:
Why have you attached the 1st two (USB controller) PCI devices to your sys-audio? Remove them from the right panel and try to start your sys-audio again.
Sorry I forgot to mention but it is a usb audio device, but yeah, after removing them the sys-audio started but there is no sound I tried to attach the qubes device to sys-audio but same problem even the built-in speaker is not working
If it is a USB device (such a Focusrite, Presonus, …), you do not need to attach its controller to sys-audio. But the audio device itself has to be attached to sys-audio. Then you have to assure that the audio device(s) work properly within sys-audio. Finally you can work on other issues of passing audio from other qubes to sys-audio.
Works, but the sound is too laggy (It is just a usb headset)
I forgot to comment this but I think this was a solution for laggy audio Standard Dom0 pulseaudio configuration not working - #2 by DVM
I do not no if its a coincidence so please correct me, but the audio now is nearly perfect.
