Part 2 of Playing with qubes
Is a rewrite of my old notes, Qubes OS Installation - Detached encrypted boot and header
Thank you @kaizer and @dum0 for donating to qubes so that I could rewrite this guide.
I’d recommend that you try in VM first, before doing it on your machine, so that you can also learn and understand too.
This is UEFI based only.
Prerequisite :
- QubesOS Installation Medium.
- 2 Drives for separated Root and Boot/EFI Partition, and we would call them with :
- Root = /dev/nvme0n1
- Boot = /dev/sda
After booting into installation in language section, press ctrl + alt + f2 to enter tty2
Format drive we would use for the installation.
dd if=/dev/urandom of=/dev/nvme0n1 bs=1M status=progress
dd if=/dev/urandom of=/dev/sda bs=1M status=progress
Create Boot, EFI, Root Header, Swap Header Partition.
Boot Partition
sgdisk -n 0:0:+200MiB -t 0:ef02 /dev/sda
EFI Partition
sgdisk -n 0:0:+200MiB -t 0:ef00 /dev/sda
Root Header Partition
sgdisk -n 0:0:+16MiB -t 0:8309 /dev/sda
If you want to use BTRFS also add swap header, another FS is not needed.
XFS / EXT4
Create custom Luks configuration.
cryptsetup -c aes-xts-plain64 -h sha512 -s 512 -y -i 10000 luksFormat /dev/nvme0n1
You may want to use -i 1 (iterations 1ms) to speed up decrypting process for practice.
Of course you can choose another -c (chiper) -h (hash size) -s (key size)
cryptsetup luksOpen /dev/nvme0n1 luks-root
pvcreate /dev/mapper/luks-root
vgcreate qubes_dom0 /dev/mapper/luks-root
lvcreate -L 8G -n swap qubes_dom0
You might want to read 8.2. Recommended system swap space if you’re not sure about swap space
lvcreate -T -L 40G qubes_dom0/root-pool
lvcreate -T -l +90%FREE qubes_dom0/vm-pool
SSD would perform badly if all of the space is used, so we leave 10% of the total to maintain the best performance.
lvcreate -V30G -T qubes_dom0/root-pool -n root-pool
You should leave at least 10% in total of Thin Pool space so it could tell you if your drive will out of space.
lvs
To see how much space you have in the VM pool, and use it to create VM lv.
lvcreate -V800G -T qubes_dom0/vm-pool -n vm
XFS
mkfs.xfs /dev/qubes_dom0/vm
mkswap /dev/qubes_dom0/swap
EXT4
mkfs.ext4 /dev/qubes_dom0/vm
BTRFS
Create Root and Swap Partition.
Swap Partition
sgdisk -n 0:0:+8GiB -t 0:8200 /dev/nvme0n1
Root Partition
sgdisk -n 0:0:0 -t 0:8304 /dev/nvme0n1
cryptsetup -c serpent-xts-plain64 -h sha512 -s 512 -y -i 10000 luksFormat /dev/nvme0n1p1
cryptsetup -c aes-xts-plain64 -h sha512 -s 512 -y -i 10000 luksFormat /dev/nvme0n1p2
cryptsetup luksOpen /dev/nvme0n1p1 luks-root
cryptsetup luksOpen /dev/nvme0n1p2 luks-swap
mkfs.btrfs --csum blake2b -L qubes_dom0 -d single /dev/mapper/luks-root
You can use another -csum (checksum) and may want to read this if you want to learn another Checksum Algorithms
mkswap /dev/mapper/swap
Proceed GUI Installation
- This is also a full video of this guide.
Begin installation.
After installation go back to tty2
cp -r /usr/lib/grub/x86_64-efi /mnt/sysroot/boot/efi/EFI/qubes/
chroot /mnt/sysroot/
mount -oremount,ro /boot
install -m0600 /dev/null /tmp/boot.tar
tar -C /boot --acls --xattrs --one-file-system -cf /tmp/boot.tar .
umount /boot/efi
umount /boot
Reformat Boot Partition
cryptsetup -c twofish-xts-plain64 -h sha512 -s 512 -y -i 1 --use-random --type luks1 luksFormat /dev/sda1
Create Alias
uuidB = /boot partition
uuidR = /root partition
uuidS = swap partition
uuidB=“$(blkid -o value -s UUID /dev/sda1)”
XFS / EXT4
uuidR=“$(blkid -o value -s UUID /dev/nvme0n1)”
BTRFS
uuidS="$(blkid -o value -s UUID /dev/nvme0n1p1)
uuidR=“$(blkid -o value -s UUID /dev/nvme0n1p2)”
Reopen luks boot partition
cryptsetup luksOpen /dev/sda1 luks-$uuidB
XFS
mkfs.xfs /dev/mapper/luks-$uuidB
xfs_admin -U $uuidB /dev/mapper/luks-$uuidB
EXT4 / BTRFS
mkfs.ext2 -m0 -U $uuidB /dev/mapper/luks-$uuidB
Configure fstab
sed -i ‘s?UUID=QUBE[^ ]*?/dev/mapper/luks-’$uuidB’?g’ /etc/fstab
Replace QUBE with the First 4 UUID Numbers of /dev/sda1
XFS / EXT4
sed -i ‘s?/dev/qubes-dom0-root?/dev/mapper/luks-’$uuidR’?g’ /etc/fstab
BTRFS
sed -i ‘s?UUID=QUBE[^ ]*?/dev/mapper/luks-’$uuidR’?g’ /etc/fstab
echo -e “/dev/mapper/luks-$uuidS none swap defaults 0 0” >> /etc/fstab
Remount Boot and EFI partition
mount -v /boot
tar -C /boot --acls --xattrs -xf /tmp/boot.tar
mount /dev/sda1 /boot/efi
Configure keys
mkdir -m0700 /etc/keys
( umask 0077 && dd if=/dev/urandom bs=1 count=64 of=/etc/keys/root.key conv=excl,fsync )
( umask 0077 && dd if=/dev/urandom bs=1 count=64 of=/etc/keys/boot.key conv=excl,fsync )
BTRFS also create swap key
( umask 0077 && dd if=/dev/urandom bs=1 count=64 of=/etc/keys/swap.key conv=excl,fsync )
Configure LUKS for XFS / EXT4
cryptsetup luksAddKey /dev/nvme0n1 /etc/keys/root.key
cryptsetup luksAddKey /dev/sda1 /etc/keys/boot.key
cryptsetup luksHeaderBackup /dev/nvme0n1 --header-backup-file header
dd if=/header of=/dev/sda3 bs=16M count=1 status=progress
Configure LUKS for BTRFS
cryptsetup luksAddKey /dev/nvme0n1p2 /etc/keys/root.key
cryptsetup luksAddKey /dev/nvme0n1p1 /etc/keys/swap.key
cryptsetup luksHeaderBackup /dev/nvme0n1p2 --header-backup-file root-header
cryptsetup luksHeaderBackup /dev/nvme0n1p1 --header-backup-file swap-header
dd if=/root-header of=/dev/sda3 bs=16M count=1 status=progress
dd if=/swap-header of=/dev/sda4 bs=16M count=1 status=progress
Remove unnecessary files
shred -uvz /header
shred -uvz /tmp/boot.tar
Configure Crypttab
XFS / EXT4
echo -e “luks-$uuidR /dev/nvme0n1 /etc/keys/root.key luks,discard,key-slot=1,header=/dev/sda3\nluks-$uuidB UUID=$uuidB /etc/keys/boot.key luks,key-slot=1” > /etc/crypttab
BTRFS
echo -e “luks-$uuidR /dev/nvme0n1p2 /etc/keys/root.key luks,discard,key-slot=1,header=/dev/sda3\nluks-$uuidS /dev/nvme0n1p1 /etc/keys/swap.key luks,key-slot=1,header=/dev/sda4\nluks-$uuidB UUID=$uuidB /etc/keys/boot.key luks,key-slot=1” > /etc/crypttab
Configure GRUB
echo “GRUB_ENABLE_CRYPTODISK=y” >> /etc/default/grub
grub2-mkconfig -o /boot/efi/EFI/qubes.cfg
Rewrite uuid map and crypttab
XFS / EXT4
sed -i ‘s?block_uuid.map"?block_uuid.map"\necho “/dev/nvme0n1 ‘$uuidR’\n/dev/disk/by-uuid/’$uuidB’ ‘$uuidB’" > “${initdir}/etc/block_uuid.map”?g’ /usr/lib/dracut/modules.d/90crypt/module-setup.sh
sed -i ‘s?$initdir/etc/crypttab?$initdir/etc/crypttab\necho “luks-’$uuidR’ /dev/nvme0n1 /etc/keys/root.key luks,discard,key-slot=1,header=/dev/sda3\nluks-‘$uuidB’ UUID=‘$uuidB’ /etc/keys/boot.key luks,key-slot=1” > $initdir/etc/crypttab?g’ /usr/lib/dracut/modules.d/90crypt/module-setup.sh
BTRFS
sed -i ‘s?block_uuid.map"?block_uuid.map"\necho “/dev/nvme0n1p2 ‘$uuidR’\n/dev/nvme0n1p1 ‘$uuidS’\n/dev/disk/by-uuid/’$uuidB’ ‘$uuidB’" > “${initdir}/etc/block_uuid.map”?g’ /usr/lib/dracut/modules.d/90crypt/module-setup.sh
sed -i ‘s?$initdir/etc/crypttab?$initdir/etc/crypttab\necho “luks-’$uuidR’ /dev/nvme0n1p2 /etc/keys/root.key luks,discard,key-slot=1,header=/dev/sda3\nluks-‘$uuidS’ /dev/nvme0n1p1 /etc/keys/swap.key luks,discard,key-slot=1,header=/dev/sda4\nluks-‘$uuidB’ UUID=‘$uuidB’ /etc/keys/boot.key luks,key-slot=1” > $initdir/etc/crypttab?g’ /usr/lib/dracut/modules.d/90crypt/module-setup.sh
Configure Dracut
echo -e ‘add_dracutmodules+=" crypt “\ninstall_items+=” /etc/keys/root.key /etc/keys/boot.key ”’ > /etc/dracut.conf.d/qubes.conf
dracut -vf /boot/initramfs-*
exit
umount /mnt/sysroot/boot/efi
umount -l /mnt/sysroot
umount -l /mnt/sysimage
XFS / EXT4
swapoff /dev/qubes_dom0/swap
vgchange -a n qubes_dom0
cryptsetup luksClose /dev/mapper/luks-root
cryptsetup luksClose /dev/mapper/luks-*
wipefs -a /dev/nvme0n1
reboot
BTRFS
swapoff /dev/mapper/luks-swap
cryptsetup luksClose /dev/mapper/luks-swap
wipefs -a /dev/nvme0n1p1
wipefs -a /dev/nvme0n1p2
reboot
Please remember that we do Detached Boot, so if you plan to use sys-usb (well you should), don’t forget to edit the kernel parameter in the grub menu if you want to update kernel, and add qubes_skip.autostart
to prevent sys-usb starting and detaching our /boot partition.
