/dev/sda2 - luks1 partition with ext2 filesystem inside (UUID=$uuid-sda2) and inside ext2 filesystem with UUID $uuid-sda2-boot)
What exactly should I do from this point?
P.S. I read several times articles like provided links below and some others, but they are not consistent with each other, kind of outdated, have not-related stuff and did not work for me. Grub does not ask for password with error: no such device) in my case.
I think the main problem is properly modification of grub configs in Qubes OS. There is almost zero documentation for Qubes OS for it, and completely zero for encrypted boot case.
If I manually go to grub2 command line and type something like: cryptmount (hd0,gpt2) it WILL ask for password. And it I then say root=(crypto0) and exit - it WILL boot to initramfs (from sda2) and then system fine.
So, the main problem - how to edit /etc/default/grub properly and run something like grub2-mkconfig or something. I hope for solution that would be probable to update with mounting sda1 and sda2 to dom0 via qvm-block attaching and then running system update the usual way.
