I’ve decided to write some of the setup I use.
The layout would contains :
- Building light qubes os installer and 4Kn debian template.
- Detached header and encrypted boot.
- Setting up dom0 and vm.
- Running dom0 and DispVM in tmpfs.
In this thread it would only talking about building light qubes (dom0 only) and
make a 4Kn debian template.
What you need is :
Fedora AppVM to run qubes-builder, you can use fc34 / fc35.
2 or more vcpu, 6gb or more ram
30gb private storage.
Every command below is issued in your builder vm.
How to :
-Qubes Key
[] gpg2 --import /usr/share/qubes/qubes-master-key.asc
[] gpg2 --edit-key qubes
[] trust
[] 5
[] q
[] wgethttps://keys.qubes-os.org/keys/qubes-developers-keys.asc
[] gpg2 --import qubes-developers-keys.asc
-Qubes Builder
[] git clone
https://github.com/QubesOS/qubes-builder.git
qubes-builder
[] cd qubes-builder
[] git tag -v git describe # add ` between git describe
[] cat >>builder.conf<< EOF
# vim: ft=make
VERBOSE ?= 2
BACKEND_VMM ?= xen
GIT_BASEURL ?= https://github.com
GIT_PREFIX ?= QubesOS/qubes-
RELEASE ?= 4.1
DIST_DOM0 ?= fc32
DISTS_VM ?= bullseye+minimal
COMPONENTS = \
installer-qubes-os \
linux-yum \
builder-rpm \
builder-debian \
linux-template-builder
BUILDER_PLUGINS ?= builder-rpm builder-debian
USE_QUBES_REPO_VERSION = 4.1
USE_QUBES_REPO_TESTING = 1
ISO_USE_KERNEL_LATEST = 1
ISO_VERSION = 5111341
INSTALLER_KICKSTART=/home/user/qubes-src/installer-qubes-os/conf/travis-iso-full.ks
EOF
[] make get-sources
[] make install-deps
-Delete fedora, whonix, and debian build
[] sed -i ‘/@whonix/d’ qubes-src/installer-qubes-os/conf/qubes-kickstart.cfg
[] sed -i ‘/@debian/d’ qubes-src/installer-qubes-os/conf/qubes-kickstart.cfg
[] sed -i ‘/@fedora/d’ qubes-src/installer-qubes-os/conf/qubes-kickstart.cfg
-Build debian 4Kn template
[] cd qubes-src/linux-template-builder
[] curl https://github.com/51lieal/qubes-linux-template-builder/commit/e656f59a18e15e58ec68a2e94fd47bc5da8efca2.patch | git apply v
[] cd ~/qubes-builder
[] make template
-Build Qubes
[] make remount
[] make iso
-Mount drive to /mnt and copy template & iso
[] sudo cp /iso/*.iso /mnt
[] sudo cp qubes-src/installer-qubes-os/rpm/noarch/*.rpm /mnt
That’s it how you build light qubes-os-installer and 4Kn debian template.
Please no question about the next step in here, so we can make a Q&A in the right post, qubes-builder related is okay. Lets wait in the couple days for the next step.
