Awesome Overlay: overlayfs on tmpfs, zram block device, and plain dm-crypt. Ephemerality for VMs and directories
Overlayfs allows one, usually read-write, directory tree to be overlaid onto another, read-only directory tree. All modifications go to the upper, writable layer. This type of mechanism is most often used for live CDs but there is a wide variety of other uses.
You can read more about this in numerous documentations and wiki pages.
It’s a popular environment for testing, and it can be used for full ephemerality. Now, I want to compile all ephemeral modules and scripts into a single guide so that anyone can use them for ephemerality in individual directories or for any type of VMs (dom0, AppVMs, Templates, StandaloneVMs).
The key difference between an overlayfs mount with tmpfs/zram/dm-crypt upper layer and a direct tmpfs mount is that the latter gives you either an empty directory or a full copy of all files consuming RAM upfront. OverlayFS completely avoids this compromise: files remain on disk in read-only mode, and only modifications are directed to the ephemeral upper layer. As a result, RAM is consumed solely by actual changes, not by the entire dataset.
For example, with a 5 GB /home containing files: a direct tmpfs mount consumes 5 GB of RAM immediately, even if the user touches nothing. An overlayfs with the same 5 GB on disk as lowerdir and tmpfs as upperdir starts at near-zero RAM usage, growing only as files are actually modified.
We will cover three types of overlayfs setups: one backed by tmpfs, on a zram device, and a third using plain dm-crypt.
Dracut modules: entire system in overlayfs. This works well with dom0 or in StandaloneVMs.
Fedora / RHEL and openSUSE use dracut by default. If you are using Debian/Ubuntu in a StandaloneVM, you can safely install dracut as follows:
sudo apt install --no-install-recommends dracut
sudo apt purge initramfs-tools
sudo dpkg-reconfigure linux-image-$(uname -r)
1. Overlayfs on tmpfs (50% of RAM):
The kernel command-line option tmpfsovl is used to enable this module.
sudo tee /usr/lib/dracut/modules.d/90overlayfs-tmpfs/module-setup.sh<< 'EOF'
#!/bin/bash
check() {
    [ -d /lib/modules/$kernel/kernel/fs/overlayfs ] || return 1
depends() {
    return 0
installkernel() {
    hostonly='' instmods overlay
install() {
    inst_hook pre-pivot 10 "$moddir/overlay-mount.sh"
EOF
sudo tee /usr/lib/dracut/modules.d/90overlayfs-tmpfs/overlay-mount.sh<< 'EOF'
#!/bin/sh
. /lib/dracut-lib.sh
if ! getargbool 0 tmpfsovl ; then
    return
fi
modprobe overlay
mount -o remount,nolock,noatime $NEWROOT
mkdir -p /live/image
mount --bind $NEWROOT /live/image
umount $NEWROOT
mkdir /cow
mount -n -t tmpfs -o mode=0755,size=50%,nr_inodes=500k,noexec,nodev,nosuid,noatime,nodiratime tmpfs /cow
mkdir /cow/work /cow/rw
mount -t overlay -o noatime,nodiratime,volatile,lowerdir=/live/image,upperdir=/cow/rw,workdir=/cow/work,default_permissions,relatime overlay $NEWROOT
mkdir -p $NEWROOT/live/cow
mkdir -p $NEWROOT/live/image
mount --bind /cow/rw $NEWROOT/live/cow
umount /cow
mount --bind /live/image $NEWROOT/live/image
umount /live/image
umount $NEWROOT/live/cow
EOF
2. Overlayfs on zram block device (10GB):
The kernel command-line option zramovl is used to enable this module.
sudo tee /usr/lib/dracut/modules.d/90overlayfs-zram/module-setup.sh<< 'EOF'
#!/bin/bash
check() {
    [ -d /lib/modules/$kernel/kernel/drivers/block/zram ] || return 1
    return 0
depends() {
    return 0
installkernel() {
    hostonly='' instmods overlay zram ext2
install() {
    inst_multiple mkfs.ext2
    # Optional
    # inst_multiple zramctl
    inst_hook pre-pivot 10 "$moddir/overlayz-mount.sh"
EOF
sudo tee /usr/lib/dracut/modules.d/90overlayfs-zram/overlay-mount.sh<< 'EOF'
#!/bin/bash
if ! getargbool 0 zramovl ; then
    return
fi
modprobe overlay
modprobe zram
if [ ! -b /dev/zram0 ]; then
    echo 1 > /sys/class/zram-control/hot_add 2>/dev/null || true
fi
echo 1 > /sys/block/zram0/reset 2>/dev/null || true
echo 10G > /sys/block/zram0/disksize
mkfs.ext2 -F -m 0 -q /dev/zram0
umount $NEWROOT
mkdir -p /cow
mount -n -t ext2 -o noatime,nodiratime,noexec,nodev,nosuid /dev/zram0 /cow
mkdir -p /cow/work /cow/rw
umount /live/image
EOF
3. Overlayfs on plain dm-crypt (5GB):
The kernel command-line option cryptovl is used to enable this module.
sudo tee /usr/lib/dracut/modules.d/90overlayfs-crypt/module-setup.sh<< 'EOF'
#!/bin/bash
check() {
    require_binaries cryptsetup || return 1
    require_binaries losetup || return 1
    require_binaries mkfs.ext4 || return 1
    return 0
depends() {
    return 0
installkernel() {
    hostonly='' instmods overlay 2>/dev/null || true
    hostonly='' instmods dm-crypt 2>/dev/null || true
install() {
    inst_multiple cryptsetup losetup mkfs.ext4 dd modprobe mount umount shred
    inst_hook pre-pivot 10 "$moddir/overlay-crypt.sh"
EOF
sudo tee /usr/lib/dracut/modules.d/90overlayfs-crypt/overlay-mount.sh<< 'EOF'
#!/bin/bash
if ! getargbool 0 cryptovl ; then
    return
fi
modprobe overlay 2>/dev/null || true
modprobe dm-crypt 2>/dev/null || true
mount -o remount,ro /sysroot 2>/dev/null || true
mount --bind /sysroot /live/image
umount /sysroot
dd if=/dev/urandom bs=64 count=1 of=/dev/shm/overlay-key status=none
chmod 600 /dev/shm/overlay-key
mkdir -p /var/lib
dd if=/dev/zero of=/var/lib/overlay-crypt.img bs=1M count=0 seek=5120 status=none
losetup -f
LOOP_DEV=$(losetup -f --show /var/lib/overlay-crypt.img)
cryptsetup luksFormat --type luks2 \
    --cipher aes-xts-plain64 --key-size 512 \
    --hash sha256 --pbkdf pbkdf2 --pbkdf-force-iterations 1000 \
    --batch-mode --key-file /dev/shm/overlay-key "$LOOP_DEV"
cryptsetup open --type luks2 --key-file /dev/shm/overlay-key "$LOOP_DEV" overlaycrypt
mkfs.ext4 -F -L "overlaycrypt" /dev/mapper/overlaycrypt
mkdir -p /cow
mount -o noatime,nodiratime,nobarrier /dev/mapper/overlaycrypt /cow
mount -t overlay -o noatime,nodiratime,volatile,lowerdir=/live/image,upperdir=/cow/rw,workdir=/cow/work,default_permissions,relatime overlay /sysroot
mkdir -p /sysroot/live/cow /sysroot/live/image
mount --bind /cow/rw /sysroot/live/cow
mount --bind /live/image /sysroot/live/image
umount /cow 2>/dev/null || true
umount /live/image 2>/dev/null || true
shred -u /dev/shm/overlay-key 2>/dev/null || rm -f /dev/shm/overlay-key
EOF
Scripts to mount individual directories in overlayfs.
All examples create an overlayfs for /home.
1. Overlayfs on tmpfs (2GB):
#!/bin/bash
OVERLAY_BASE="/run/home-overlay"
LOWERDIR="/home"
UPPERDIR="$OVERLAY_BASE/upper"
WORKDIR="$OVERLAY_BASE/work"
MOUNTPOINT="/home"
# Create directories
mkdir -p "$UPPERDIR" "$WORKDIR"
# Mount tmpfs for overlay upper+work layers
mount -t tmpfs -o size=2G,mode=0755 tmpfs "$OVERLAY_BASE"
# Recreate upper/work inside tmpfs after mount
# Mount overlayfs
mount -t overlay overlay \
  -o lowerdir="$LOWERDIR",upperdir="$UPPERDIR",workdir="$WORKDIR" \
  "$MOUNTPOINT"
2. Overlayfs on zram block device (2GB):
#!/bin/bash
ZRAM_DEV=""
ZRAM_SIZE="2G"
LOWERDIR="/home"
MOUNTPOINT="/home"
# Load zram module if not loaded
if ! lsmod | grep -q "^zram"; then
    modprobe zram num_devices=1 || modprobe zram
fi
# Wait for zram control interface
for _ in {1..10}; do
    if [ -d /sys/class/zram-control ]; then
        break
    fi
    sleep 0.1
done
# Find first free zram device
for i in /sys/block/zram*; do
    [ -e "$i" ] || continue
    if [ "$(cat "$i"/disksize)" = "0" ]; then
        ZRAM_DEV="/dev/$(basename "$i")"
        break
    fi
done
if [ -z "$ZRAM_DEV" ]; then
    # No free device; try to add one via hot_add
    if [ -f /sys/class/zram-control/hot_add ]; then
        idx=$(cat /sys/class/zram-control/hot_add)
        ZRAM_DEV="/dev/zram$idx"
    else
        echo "ERROR: no free zram device found and hot_add not available" >&2
        exit 1
    fi
fi
echo "Using $ZRAM_DEV"
# Configure compression and size
echo lz4 > /sys/block/$(basename "$ZRAM_DEV")/comp_algorithm 2>/dev/null || true
echo "$ZRAM_SIZE" > /sys/block/$(basename "$ZRAM_DEV")/disksize
# Format and mount zram as ext4 (needed for overlay upper+work)
mkfs.ext4 -q "$ZRAM_DEV"
mkdir -p "$OVERLAY_BASE"
mount -t ext4 "$ZRAM_DEV" "$OVERLAY_BASE"
# Prepare overlay directories
# Mount overlayfs
  "$MOUNTPOINT"
3. Overlayfs on plain dm-crypt (2GB):
#!/bin/bash
CRYPT_NAME="home-overlay-crypt"
LOWERDIR="/home"
MOUNTPOINT="/home"
SIZE="2G"
CIPHER="aes-xts-plain64"
KEY_SIZE=512
# Check if already mounted
if findmnt -n -o FSTYPE "$MOUNTPOINT" 2>/dev/null | grep -q overlay; then
    echo "Overlay already active on $MOUNTPOINT"
    exit 0
fi
# Require root privileges
if [[ $EUID -ne 0 ]]; then
    echo "Need root" >&2
    exit 1
fi
# Create tmpfs backing store for container file
mount -t tmpfs -o size=1100M,mode=0700,noexec,nodev,nosuid,noatime tmpfs "$OVERLAY_BASE"
# Create 2G sparse file
truncate -s "$SIZE" "$OVERLAY_BASE/container.img"
# Set up loop device
LOOP_DEV=$(losetup --find --show --sector-size 512 "$OVERLAY_BASE/container.img")
# Ephemeral key in memory only
KEYFILE=$(mktemp -p /dev/shm .key.XXXXXX)
dd if=/dev/urandom of="$KEYFILE" bs=64 count=1 status=none
chmod 600 "$KEYFILE"
# Open plain dm-crypt (no LUKS header)
cryptsetup open --type plain \
    --cipher "$CIPHER" \
    --key-size "$KEY_SIZE" \
    --key-file "$KEYFILE" \
    "$LOOP_DEV" "$CRYPT_NAME"
# Key no longer needed - destroy it
shred -u "$KEYFILE" 2>/dev/null || rm -f "$KEYFILE"
unset KEYFILE
# Filesystem on encrypted device
mkfs.ext4 -F -q -m 0 -O ^has_journal /dev/mapper/"$CRYPT_NAME"
# Mount encrypted volume ON TOP OF tmpfs
# (container.img remains alive because loop device holds it)
mount -o noatime,nodiratime,noexec,nodev,nosuid /dev/mapper/"$CRYPT_NAME" "$OVERLAY_BASE"
# Directories for overlay
mkdir -p "$OVERLAY_BASE/upper" "$OVERLAY_BASE/work"
# Final overlay mount
    -o lowerdir="$LOWERDIR",upperdir="$OVERLAY_BASE/upper",workdir="$OVERLAY_BASE/work",noatime,nodiratime \
    "$MOUNTPOINT"
:check_mark: License:Unlicense
Anyone may use and redistribute these scripts and modules under their own name.
I’ve got some questions:
  • where does the image come from? Is it also covered by the license?
  • is there something related to Qubes OS here? Where?
  • I thought we agreed to keep titles straight to the point, am I wrong?
I made the image myself because I couldn’t find clear diagrams online. What does “related” to Qubes mean? This guide is for running dom0, standaloneVMs, /home, and other directories in any AppVM with ephemerality that doesn’t affect active memory usage. And what, in your opinion, in the title doesn’t match the guide’s topic? Tell me. I probably shouldn’t post guides here anymore if the moderators keep asking strange questions. This was the last guide.
It is very polished, have you used an LLM?
Would this guide work on a computer with Fedora (not Qubes, but a regular Fedora)?
I’m referring to this topic: Should we do something about flashy forum topic titles? So, it could be “Ephemerality for VMs and directories with overlayfs”?
We have a lot of users here on the forum creating solutions, tools, everything for free. Some spend the whole day studying and programming, and even sacrifice their Sunday to help create new setups, solutions, and tools for Qubes. And we have certain moderators who only criticize, complain, or cause trouble over small things…
That “parulin” — I’ve seen him complaining about emojis in the title of one of the most advanced posts on the forum… this one:
What’s the benefit of nitpicking emojis? This post provides a robust solution for anonymity. It took months of work and research, and a moderator is complaining about stickers in the title?
Why don’t you work and create all of this the way you want—perfectly—instead of just complaining?
Do you think it’s easy to keep studying, working, researching, testing, and writing on the forum all these solutions for free, without gaining anything, just to help the community?
If moderators are so great, they should have already done all of this for everyone!
It seems the moderators don’t like guides and high forum activity. They decided to nitpick everything - now it’s the titles, now something else. I used to work with Debian, and only in Qubes did I start working with Fedora. I don’t care whether the guides and scripts work on default Fedora or not - I won’t even check that. What matters to me is that it works in Qubes. Maybe it works in Arch too. But what’s the difference - Qubes is based on Fedora. Qubes uses dracut. I think many people on this forum have never worked with Fedora or won’t install Fedora - their experience with Fedora will be limited to Qubes only. And because of guides like these, it’s easier for beginners to understand Qubes. But with moderators like these, forum will turn into just a chat with boring discussions. And it becomes clear why the authors of many cool guides quickly disappear from the forum and don’t respond to comments under their guides.
@cloud-quber-master
Keeping the forum clean from manipulative gimmicks.
A moderator is entitled to point out whatever doesn’t fit the community.
Can you differentiate between “complaining” and moderating?
Do you think it is easy to be a volunteer moderator for free?
Do you even know the meaning of the word moderator? Hint: it does not mean writer of perfect guides.
The title is fine let the user contribute. No more emojis which I agree with, anything more in moderating and it will be over the top for no reason at all.
damn man, let it be, I see no harm in having emojis in forum titles, there is no need to act like the forum hall-monitor. @linuxuser1 has obviously put a lot of work into this and should be respected for it. Why all the hate? as @unman said, the moderation here seems to be overkill.
I have learned a lot from @linuxuser1. Keep up the good work!
@linuxuser1 I found zram to be a waste of time. I will focus on the overlayfs as it seems to hold the most promise. Combined with a detached luks-header (ext4) and a Vault with it’s own detached header is where I am heading. Thanks for your inspiration!
Some clarifications: my first 3 questions were raised by some concerns, so an explanation for each one in the original order:
  1. Checking: solved, but, then I asked about Using AI in contributions, this second part is still unanswered.
  2. Is it specific to Qubes OS? unanswered, even if I rephrased it using a vanilla Fedora installation as an example. This could lead me to close this guide.
  3. That question is not necessarily a moderation question, I discussed that as a user in Should we do something about flashy forum topic titles? , read @linuxuser1 answers here, saw that they edited some of their titles, so I thought that it was resolved. With that guide, I was in doubt, so instead of making a second post as @parulin I put my question with the two others. I try to avoid mixing moderation actions (that account) with the rest of my activity here, but it is not perfect.
That’s exactly why I don’t understand why volunteer moderators are creating extra work for themselves. They could simply focus on fighting spammers and aggressive, abusive users. But instead, a volunteer moderator who finds forum life non-easy invents countless reasons to nitpick the guides. It would have been better if he had written some useful guide instead of creating censorship out of thin air.
I think I speak for the majority, this is allowed. This has everything to do with qubes and should be treated as such. Further meddling would be considered in my eyes censorship.
How about not twisting reality instead?
One week ago, I asked how this guide could be either specific or related to Qubes OS. There was no answer, so I’m putting a timer to auto-close this guide, unless someone brings new information.
You need to be consistent and follow through with your work to the end if you’ve decided to become a moderator.
Therefore, you should close this guide as well Qubes OS live mode. dom0 in RAM. Non-persistent Boot. RAM-Wipe. Protection against forensics. Tails mode. Hardening dom0. Root read‑only. Paranoid Security. Ephemeral Encryption because there’s nothing Qubes-specific in it - you’ll easily set up new GRUB options, dracut modules, and sysctl hardening on other distros (Debian, Fedora, Ubuntu). I did this easily on other distros. So, it should be closed and deleted.
Also, you should close this guide Hidden "nuke" duress password to LUKS-encrypted disk. Qubes self-destruct module what’s unique about it for Qubes? It would work on any Fedora.
You should also close this guide Alternative duress passwords for ScreenSaver and LightDM, because here too there’s nothing unique to Qubes, and it works on any Fedora.
Then close and delete this guide, as it’s just running antidetect browsers on Linux Antidetect‑appVM with FOSS Antidetect Browsers. Windows fingerprint. Random fingerprint in dvm
You can close and delete this guide Ephemeral DVMs in fully ephemeral thin pools (ephemeral encryption, zram-disk, tmpfs). Removing DVM logs and metadata you can run these overlay pools on any distro with LVM, as well as clean up the journal and logs using tmpfs - there’s absolutely nothing unique here (and it looks very similar to this guide).
Next, close this guide DNScrypt-proxy qube. Encrypted anon DNS with relay routing (like Tor) it’s just a DNSCrypt proxy for Linux, nothing Qubes-specific at all (this guide would work on any distro).
And it’s also time to close this guide Installation of Amnezia VPN and Amnezia WG: effective tools against internet blocks via DPI for China, Russia, Belarus, Turkmenistan, Iran. VPN with Vless XRay reality. Best obfuscation for WireGuard. Easy self‑hosted VPN. Bypass it just installing a VPN on Debian.
Otherwise, you are just a slacker who doesn’t carry out their responsibilities to the end.
:slightly_frowning_face:
https://forum.qubes-os.org/guidelines#agreeable
This topic was automatically closed after 3 days. New replies are no longer allowed.
Suspended user for 7 days with warning, this is a CoC violation. Mods do their best to help.
remain civil please
for the rest of your post demanding consistent moderation actions on items you deem to not be qubes specific guides - its appears to me to be confrontational whataboutism.
The feedback in this thread from all points of view has been noted. I will open a discussion with the mod team regarding how guides are looked at. Perhaps a “all around qubes guides” and “community qubes guides” separation will be a viable path. I have also opened the discussion regarding titles and what we need to look at there.
