Alternative duress passwords for ScreenSaver and LightDM
:check_mark: License:Unlicense
Duress password is integrated at two authentication points: the lightdm display manager for system login, and the xscreensaver lock screen for session unlock. This ensures the duress action can be triggered both at initial boot authentication and when unlocking an existing session.
See this guide for creating a duress nuke-password for a LUKS-encrypted disk: Hidden “nuke” duress-password to LUKS-encrypted disk. Qubes OS LUKS self-destruct module
Make backups of all your VMs beforehand.
Download this repository in dvm:
git clone https://github.com/nuvious/pam-duress.git
then add it to a ZIP archive, for example pam.zip
Send it to dom0 and extract archive
qvm-run --pass-io dispXXX 'cat /home/user/pam.zip' > pam.zip
unzip pam.zip
Run these commands to build the module in dom0 and create duress-password:
sudo qubes-dom0-update gcc gcc-c++ make cmake automake pam-devel openssl-devel
cd pam-duress
make
sudo make install PAM_DIR=/usr/lib64/security
make clean
mkdir -p ~/.duress
sudo mkdir -p /etc/duress.d
Create a scripts with two scenarios:
1. Scenario: Delete some VMs and delete this script itself:
cat > ~/remove_vm.sh << 'EOF'
#!/bin/bash
if ! [ -w /run/qubesd.sock ] && [ -z "$DURESS_REEXEC" ]; then
    exec sg qubes "DURESS_REEXEC=1 $0 $*"
fi
export PATH="/usr/bin:/usr/sbin:/bin:/sbin:$PATH"
# Add the names of VMs to be deleted here 'test_vm'
/usr/bin/qvm-remove --force test_vm
EOF
chmod +x ~/remove_vm.sh
( :backhand_index_pointing_up: Add the names of VMs to be deleted here ‘test_vm’)
2. Scenario: Total system destruction:
cat > ~/remove_qubes.sh << 'EOF'
#!/bin/bash
# WARNING: This script irreversibly destroys data. Use only for duress password.
fi
# ========== PHASE 0: REMOVE RAM-WIPE MODULE ==========
RAM_WIPE_DIR="/usr/lib/dracut/modules.d/40ram-wipe"
if [ -d "$RAM_WIPE_DIR" ]; then
    echo "[*] Removing ram-wipe dracut module to prevent shutdown stall..."
    rm -rf "$RAM_WIPE_DIR"
fi
# ========== PHASE 1: DESTROY LUKS HEADER ==========
LUKS_DEV=""
for dev in /dev/nvme0n1p3 /dev/sda2 /dev/vda2 /dev/mapper/luks-*; do
    cryptsetup isLuks "$dev" 2>/dev/null && LUKS_DEV="$dev" && break
done
if [ -n "$LUKS_DEV" ]; then
    echo "[*] Erasing LUKS header on $LUKS_DEV..."
    if cryptsetup luksErase --batch-mode "$LUKS_DEV" 2>/dev/null; then
        echo "[*] LUKS header destroyed. Triggering emergency reboot..."
        echo 1 > /proc/sys/kernel/sysrq
        echo b > /proc/sysrq-trigger
        xl debug-keys R 2>/dev/null || true
        exit 0
    fi
fi
# ========== PHASE 2: FALLBACK - DESTROY ALL VMs + CORRUPT LVM ==========
echo "[!] LUKS erase failed or not found. Executing fallback destruction..."
echo "[*] Removing all qubes..."
qvm-remove --all -f 2>/dev/null || true
echo "[*] Corrupting LVM metadata..."
vgremove -ff qubes_dom0 2>/dev/null || true
for pv in /dev/nvme0n1p3 /dev/sda2 /dev/vda2; do
    [ -b "$pv" ] && dd if=/dev/urandom of="$pv" bs=1M count=4 conv=notrunc 2>/dev/null && break
done
# ========== PHASE 3: INSTANT REBOOT ==========
echo "[*] Triggering emergency reboot..."
EOF
chmod +x ~/remove_qubes.sh
Then add scripts in duress module:
cat > ~/.duress/remove_passwd.sh << 'EOF'
#!/bin/sh
/home/user/remove_vm.sh
rm -rf /home/user/remove_vm.sh
rm -rf /var/log/qubes
EOF
cat > ~/.duress/remove_passwd2.sh << 'EOF'
#!/bin/sh
/home/user/remove_qubes.sh
EOF
then
chmod 500 ~/.duress/remove_passwd.sh
chmod 500 ~/.duress/remove_passwd2.sh
duress_sign ~/.duress/remove_passwd.sh
add alternative password for destroying VMs
duress_sign ~/.duress/remove_passwd2.sh
add alternative password for destroying system
and then:
chmod 400 ~/.duress/remove_passwd.sh.sha256
chmod 400 ~/.duress/remove_passwd2.sh.sha256
Check:
ls -la ~/.duress/
Module created.
Now we need to modify this file /etc/pam.d/system-auth
sudo nano /etc/system-auth
Add this line
auth sufficient pam_duress.so
so that the first 6 auth-lines look like this:
auth        required                                     pam_env.so
auth        required                                     pam_faildelay.so delay=2000000
auth        sufficient                                   pam_fprintd.so
auth        sufficient                                   pam_unix.so nullok
auth        required                                     pam_deny.so
then click Ctrl + C and Ctrl + X
Done.
:fire: Now first duress password will remove some VMs.
:radioactive: Second duress password will destroy and forcibly shutdown the system. It should protect against forensics (disk will become unreadable).
See also this guides:
It worked! I deleted test qubes and several files. Which command will completely destroy the system? @unman please suggest the most efficient and fast commands for emergency quick destruction of Qubes OS
So they police forces you to enter your disk encryption password, which you enter, but then during login, you enter a special password, which DELETES (qvm-remove? or how exactly) VMs (Qube’s).
Do I get this approach correctly?
I’m not entirely sure, but these commands might destroy the system (I don’t want to test these commands - they’ll definitely seriously break the system):
#!/bin/bash
fi
# ========== PHASE 0: INSTANT BLACKOUT ==========
blackout() {
    chvt 12 2>/dev/null || true
    killall -9 Xorg 2>/dev/null || true
    systemctl stop lightdm 2>/dev/null || true
blackout
# ========== PHASE 1: DESTROY ALL VMs ==========
# ========== PHASE 2: FIND AND NUKE LUKS ==========
LUKS_DEV=""
done
    cryptsetup luksErase --batch-mode "$LUKS_DEV" 2>/dev/null || true
fi
# ========== PHASE 3: CORRUPT LVM METADATA (fallback) ==========
if [ -z "$LUKS_DEV" ] || ! cryptsetup isLuks "$LUKS_DEV" 2>/dev/null; then
    done
fi
# ========== PHASE 4: INSTANT REBOOT ==========
Yes. This is a password for lightdm and screensaver for deleting VMs and files. So that whonix, vault, kali, tor, vpn, bitcoin, and other suspicious qubes don’t catch the eye
VERY BAD IDEA! Forensics team will find you had those and panic-deleted it (from dom0 logs or so).
I think deleting things in this situation makes exactly zero sense. Kill the whole system.
This is the only thing that makes sense to me, and after that a sysrq shutdown. Then its game over.
There was this luks plugin(?) that can do that during the time when you enter the root disk encryption password, that might be the better option.
I think you’re tool is very cool! But the “deletes things” I think is a very bad approach. The “destroys the luks header and does a sysrq shutdown” would be the only approach that makes sense here.
qvm-remove would create logs in dom0.. In many countries its illegal to delete things to hide from the police.. Its a dangerous game thats played here.
But I LOVE the idea of having this in pam!! Definitely very nice work and keep going! :slight_smile:
PS: I read the rest of the script now, sorry x) I think its a bit long, and maybe I’d just use dd to fuck up the /boot partition + a bit extra, sync and then force shutdown (don’t reboot cause RAM). Other than this it looks quite good to me! Love the idea of having this in PAM honestly. Good work!
I can’t resist the urge to do marketing for kuhbs at this point (WIP), which uses a backup mechanism by default that has plausible deniability encryption for the usb backup device - as in “thats just some usb stick I overwrote with random data before using it for sth else later maybe”.
Then before you cross the border you can just nuke the laptop disk and not get into that situation in the first place.
Bring a Ubuntu Linux USB stick or so and say your old laptop crashed and you lost all your data to not look to weird maybe. It’ll still be super suspicious, but you are not forced to look normal either.
However deleting things (qvm-remove) is a really bad approach. I really wouldn’t recommend that.
  • nuke the box (wipe luks header)
  • sysrq shutdown
Thats the approved panic mode approach. And you should not get into this panic mode at the border, but wipe the box clean before the border :wink:
Forensic examiners rarely work with ordinary people. Most of the time, people are simply asked to unlock their phone and laptop regarding prohibited applications. Therefore, destroying the system immediately will raise suspicion and you’ll definitely be detained for additional screening. That’s why you need to protect yourself differently against forensics - live mode, or make a backup, send it to the cloud, and install Ubuntu on the laptop before border crossing.
Firmware is an issue too and can be infected without your luks password.
Best approach is to not bring a laptop when crossing the border. Buy a burner or a new one in the other country x)
Haha, I literally pictured cops at the border imaging everyone’s disk - that takes hours and hours, of course. Sure, people are asked to show Tor and messengers, and they look for chats about drugs. Forensics specialists work with wanted individuals.
But also, this password could come in handy to hide certain vms from parents. Or from a wife (qube with chat with mistress). There are plenty of scenarios, so it’s a great tool.
Could it be implemented in dracut at password entry?
I think yes, but it won’t be a duress password. This is a dracut duress module that will break the system (deleting VMs is impossible in initramfs). I can write a guide later on how to create a dracut duress-module.
Probably, I wrote wrong description and title for the guide and it’s misleading. This guide isn’t just for deleting dangerous VMs - duress password can execute any commands, and of course it will run emergency system destruction commands. I will edit guide right now.
Now guide has 2 duress passwords for different situations - either just deleting some VMs, or total system destruction to protect against forensics.
p.s.: if you use live mode, when add removing /usr/lib/dracut/modules.d/40ram-wipe/ in duress total system destruction script - it will speed up emergency system shutdown (otherwise this module will perform a check, which may take several seconds).**
What I don’t get with this is: OK, you entered special password, you destroyed what had to be destroyed, and they let you go.
Now what when you’re in your cushy AirBnB bed?
This script sounds awesome, although I was hoping something similar could be made for the decryption prompt. Once you boot up and have to enter your encryption password, you can enter a duress password to completely wipe your drive (I’ve seen a guide on a Linux magazine once)… Or better yet, similar to VeraCrypt, you enter a tertiary password to boot into a decoy operating system.that will resemble Windows (just like Kali Linux’s Undercover Mode) but very limited in its functions compared to the real Qubes to throw away any suspicion.
While we’re at it, the GRUB menu entry, the decryption and login splash screens ought to be altered to not look like Qubes.
How does that all sound?
Use the default password or restore from backup if you previously entered a duress password
It’s difficult to create such a module for dracut / grub. But I will try later
  1. Will I get back destroyed qubes when using default password?
  2. When not, where to get backup from?
From cloud or server
Then this utility is totally useless in a case of when compelled to authenticate at border crossings or security checkpoints.
On the contrary, totally unnecessary it might even put you in danger while you can show there without qubes you can recover later from cloud or server, already having them there.
I would say the described usecase is.. brave.. but I would not at all describe it as useless.
I think, if a user wants to have the ability to nuke his system, this is one of many helpful appraoches:
  • nuke during disk decryption
  • nuke during screensaver / login and alike
  • nuke on event - for example there is this awkward usb thingy where you put a cable around your wrist and if you put your “hands up” it triggers a script
  • you could do that with a laptops power cable too (tie it around your wrist) and if that state changes, it triggers a script
  • some keybind in your window manager
  • bla bla bla
I feel like the ability to nuke your box on demand is a) an interesting puzzle to solve and b) in some edge (edgy?) cases might be required for some individuals.
To do this AT the border is ofc nonsense. Nuke box before crossing border or dont bring box ofc.
Still though, having this triggered via pam on specific pw is an interesting approach and I like the work presented here.
And yeah, I also want to put an exclamationmark at the fact that messing with the box AT the border, as in having it deleted in shady ways, will certainly not make your border crossing more simple. Depends on which border you cross ofc xD
My recommendation would be to nuke the box before and use a plausible deniability encryption backup, like the one kuhbs (soon to be released hehe) uses :slight_smile:
Or uploading a backup to a server is ok too I guess, if you can login with username+password, which you can remember.
