Hello,
I need help urgently and would appreciate any tips.
I have two hard drives on my computer. One 250gb ssd and a 1tb ssd. On the smaller one I installed qubes for testing purposes and then switched to the 1tb for daily work.
Today my computer first froze and then shut down. It automatically tried to reboot and I got this error message:
After waiting for a while I shut down the computer again and on the next reboot it bootet into the 250gb ssd. Rebooting and looking into the boot menu gave me
Qubes created a new entry Qubes (M.2_1…250) and thats the one Qubes is using, regardless if there are some other entries, which point to SSD drives. I’m afraid you have to edit the grub configuration with a second entry called somewhat Windows (M.2_2 …) to get this available in a boot menu.
But I can’t tell you, how exactly this should be done. So please wait for some more repies here. Guess some other people can help you edit the boot configuration.
