Actually I only answer to this statement.
Running dom0 and dispvm from ram is decreasing thread vector.
For how this cache works I also don’t know, someday I’ll learn about this.
I just practiced again and found an error I forgot to post last time. It’s the very first error I encounter in the process. Here’s the error along with the few commands just before it:
[anaconda root@localhost /]# pvcreate /dev/mapper/luks
Physical volume "/dev/mapper/luks" successfully created.
[anaconda root@localhost /]# vgcreate qubes_dom0 /dev/mapper/luks
Volume group "qubes_dom0" successfully created
[anaconda root@localhost /]# lvcreate -n swap -L 4G qubes_dom0
Logical volume "swap" created.
[anaconda root@localhost /]# lvcreate -T -L 20G qubes_dom0/root-pool
Thin pool volume with chunk size 64.00 KiB can address at most 15.81 TiB of data.
/usr/bin/dmeventd: stat failed: No such file or directory
WARNING: Failed to monitor qubes_dom0/root-pool.
Logical volume "root-pool" created.
The other error I posted before also pertains to dmeventd. Even if nobody here has a solution, it helps to document and share errors.
I’ve tried it out by configuring LUKS like this:
dd if=/dev/urandom of=key.img bs=32M count=1
cryptsetup luksFormat key.img
cryptsetup open key.img lukskey
dd if=/dev/zero of=header.img bs=16M count=1
cryptsetup --key-file=/dev/mapper/lukskey --keyfile-offset=0 --keyfile-size=8388608 luksFormat /dev/sda --offset 32768 --header header.img
cryptsetup open --header header.img --key-file=/dev/mapper/lukskey --keyfile-offset=0 --keyfile-size=8388608 /dev/sda qubes_dom0
lvcreate -n swap -L 512M qubes_dom0
lvcreate -T -L 5G qubes_dom0/root-pool
lvcreate -T -l +100%FREE qubes_dom0/vm-pool
lvcreate -V5G -T qubes_dom0/root-pool -n root
lvcreate -V4G -T qubes_dom0/vm-pool -n vm
mkfs.xfs /dev/qubes_dom0/vm
And installer can see the disk configuration created this way just fine when I press on “Reload storage configuration from disk”:
Or will it fail at a later stage?
For a key, I recommend /dev/random instead of /dev/urandom. The former ensures high entropy. (though I don’t know the answer to the rest of your question)
If you’re talking about this:
Then I think it shouldn’t really matter because cryptsetup will use /dev/random when it’ll initialize a LUKS partition here:
And the key used to encrypt /dev/sda later won’t be raw key.img file created from /dev/urandom but the decrypted key.img file that was encrypted with key from /dev/random.
I’ve looked into it more and luksFormat is using /dev/urandom by default:
#cryptsetup --help
Default compiled-in device cipher parameters:
loop-AES: aes, Key 256 bits
plain: aes-cbc-essiv:sha256, Key: 256 bits, Password hashing: ripemd160
LUKS: aes-xts-plain64, Key: 256 bits, LUKS header hashing: sha256, RNG: /dev/urandom
LUKS: Default keysize with XTS mode (two internal keys) will be doubled.
So maybe it’ll make sense to add --use-random option to cryptsetup luksFormat command.
But there’s a note in arch wiki about it:
Note that /dev/random blocking pool has been removed. Therefore,
--use-randomflag is now equivalent to--use-urandom.
So maybe using /dev/random is pointless.
I have paid 50% of my donation as promised. $250 via xmr to Qubes. Will pay the balance when you publish. I Send you PM with txid for proof.
Will do in the next 24h.
Is a rewrite of my old notes, Qubes OS Installation - Detached encrypted boot and header
This will cover how you use it with xfs and btrfs on dom0
This is UEFI based only.
Prerequisite :
After booting into installation in language section, press ctrl + alt + f2 to enter tty2
Format drive we would use for the installation.
dd if=/dev/urandom of=/dev/nvme0n1 bs=1M status=progress
dd if=/dev/urandom of=/dev/sda bs=1M status=progress
Create Boot, EFI, Header Partition.
sgdisk -n 0:0:+200MiB -t 0:ef02 /dev/sda
sgdisk -n 0:0:+200MiB -t 0:ef00 /dev/sda
sgdisk -n 0:0:+16MiB -t 0:8309 /dev/sda
Create custom Luks configuration.
cryptsetup -c aes-xts-plain64 -h sha512 -s 512 -y -i 10000 luksFormat /dev/nvme0n1
You may want to use -i 1 (iterations 1ms) to speed up decrypting process for practice.
cryptsetup luksOpen /dev/nvme0n1 luks-root
pvcreate /dev/mapper/luks-root
vgcreate qubes_dom0 /dev/mapper/luks-root
lvcreate -L 8G -n swap qubes_dom0
You might want to read 8.2. Recommended system swap space if you’re not sure about swap space
lvcreate -T -L 40G qubes_dom0/root-pool
lvcreate -T -l +90%FREE qubes_dom0/vm-pool
lvcreate -V30G -T qubes_dom0/root-pool -n root-pool
lvs
To see how much space you have in the vm-pool, and use it to create vm lv.
lvcreate -V800G -T qubes_dom0/vm-pool -n vm
mkswap /dev/mapper/swap
sgdisk -n 0:0:+8GiB -t 0:8200 /dev/nvme0n1
sgdisk -n 0:0:0 -t 0:8304 /dev/nvme0n1
cryptsetup -c aes-xts-plain64 -h sha512 -s 512 -y -i 10000 luksFormat /dev/nvme0n1p1
cryptsetup -c serpent-xts-plain64 -h sha512 -s 512 -y -i 10000 luksFormat /dev/nvme0n1p2
cryptsetup luksOpen /dev/nvme0n1p1 luks-root
cryptsetup luksOpen /dev/nvme0n1p2 luks-swap
mkfs.btrfs --csum blake2b -L qubes_dom0 -d single /dev/mapper/luks-root
Video / Pict ?
Begin installation.
After installation go back to tty2
cp -r /usr/lib/grub/x86_64-efi /mnt/sysroot/boot/efi/EFI/qubes/
chroot /mnt/sysroot/
mount -oremount,ro /boot
install -m0600 /dev/null /tmp/boot.tar
tar -C /boot --acls --xattrs --one-file-system -cf /tmp/boot.tar .
umount /boot/efi
umount /boot
Reformat Boot Partition
cryptsetup -c twofish-xts-plain64 -h sha512 -s 512 -y -i 1 --use-random --type luks1 luksFormat /dev/sdb1
uuidR=“$(blkid -o value -s UUID /dev/nvme0n1)”
uuidB=“$(blkid -o value -s UUID /dev/sda1)”
cryptsetup luksOpen /dev/sda1 luks-$uuidB
mkfs.xfs /dev/mapper/luks-$uuidB
xfs_admin -U $uuidB /dev/mapper/luks-$uuidB
Configure fstab
sed -i ‘s/dev/mapper/root/dev/mapper/luks-’$uuidR’\g’ /etc/fstab
sed -i ‘s\UUID=F4N*/dev/mapper/luks-’$uuidR’\g’ /etc/fstab
Replace F4N with First 4 UUID Number of /dev/sda1
mount -v /boot
tar -C /boot --acls --xattrs -xf /tmp/boot.tar
mount /dev/sda1 /boot/efi
Configure keys
mkdir -m0700 /etc/keys
( umask 0077 && dd if=/dev/urandom bs=1 count=64 of=/etc/keys/root.key conv=excl,fsync )
( umask 0077 && dd if=/dev/urandom bs=1 count=64 of=/etc/keys/boot.key conv=excl,fsync )
cryptsetup luksAddKey /dev/nvme0n1 /etc/keys/root.key
cryptsetup luksAddKey /dev/sda1 /etc/keys/boot.key
cryptsetup luksHeaderBackup /dev/nvme0n1 --header-backup-file header
dd if=/header of=/dev/sda3 bs=16M count=1 status=progress
shred -uvz /header
shred -uvz /tmp/boot.tar
Configure Crypttab
echo -e “luks-$uuidR /dev/nvme0n1 /etc/keys/root.key luks,discard,key-slot=1,header=/dev/sda3\nluks-$uuidB UUID=$uuidB /etc/keys/boot.key luks,key-slot=1” > /etc/crypttab
Configure GRUB
echo “GRUB_ENABLE_CRYPTODISK=y” >> /etc/default/grub
sed btrfs driver # TODO
grub2-mkconfig -o /boot/efi/EFI/qubes.cfg
Configure Dracut
echo -e ‘add_dracutmodules+=" crypt “\ninstall_items+=” /etc/keys/root.key /etc/keys/boot.key ”’ > /etc/dracut.conf.d/qubes.conf
sed -i ‘s?block_uuid.map"?block_uuid.map"\necho “/dev/nvme0n1 ‘$uuidR’\n/dev/disk/by-uuid/’$uuidB’ ‘$uuidB’" > “${initdir}/etc/block_uuid.map”?g’ /usr/lib/dracut/modules.d/90crypt/module-setup.sh
sed -i ‘s?$initdir/etc/crypttab?$initdir/etc/crypttab\necho “luks-’$uuidR’ /dev/nvme0n1 /etc/keys/root.key luks,discard,key-slot=1,header=/dev/sda3\nluks-‘$uuidB’ UUID=‘$uuidB’ /etc/keys/boot.key luks,key-slot=1” > $initdir/etc/crypttab?g’ /usr/lib/dracut/modules.d/90crypt/module-setup.sh
dracut -vf /boot/initramfs-*
exit
umount /mnt/sysroot/boot/efi
umount -l /mnt/sysroot
umount -l /mnt/sysimage
swapoff /dev/qubes_dom0/swap
vgchange -a n qubes_dom0
cryptsetup luksClose /dev/mapper/luks-root
cryptsetup luksClose /dev/mapper/luks-*
wipefs -a /dev/nvme0n1
reboot
I will try later, I remember in my first research, it failed.
don’t bother with the error, just proceed you’ll be fine, and you may want to follow the progress above instead of #1, and look for #1 or in btrfs thread for the image.
Maybe it’ll work if you use PARTUUID /dev/disk/by-partuuid/ instead of UUID?
UUID is a filesystem-level UUID, which is retrieved from the filesystem metadata inside the partition. It can only be read if the filesystem type is known and readable.
PARTUUID is a partition-table-level UUID for the partition, a standard feature for all partitions on GPT-partitioned disks. Since it is retrieved from the partition table, it is accessible without making any assumptions at all about the actual contents of the partition. If the partition is encrypted using some unknown encryption method, this might be the only accessible unique identifier for that particular partition.
fstab - What is UUID, PARTUUID and PTUUID? - Unix & Linux Stack Exchange
I’m not sure, if you look at my approach I wrote the header on the partition, so the partition will have the same metadata as root.
I’m surprised by this,
it actually work.
I think, it’s not necessary, I did shred on both boot.rar and header
I assume that because you’re writing just header on raw partition then there is no filesystem there so there is no UUID for this partition. But this partition still has PARTUUID and could be addressed with /dev/disk/by-partuuid/.
Shred works fine for HDD, but it doesn’t work for SSD:
dm-crypt/Specialties - ArchWiki
I’ve checked it myself and my guess was wrong. When you write header to the raw partition then it’ll have UUID of the luks partition.
Ah i see, that make sense with ssd but still, I think one need to bypass crypt first to examine this. But your approach to creating detach header before installation is acceptable, I’ve add it to my note, but not with these guide. It has been 1y+ and everything still fine.
As expected.
@51lieal The image seems to be missing from your post. Provided below.
[anaconda /] vi /etc/crypttab
---# Change root device value so it look like this
Take a look at this for anyone who want a better guide.
After completion, switch back to shell with ctrl + alt + f2
After completion of the installation in full - meaning upon arrival to the fully installed desktop system? Or after completion of the first part of the installation, prior to booting and putting the LUKS password for the first time and prior to configuration and template installation? Thanks!
Take a look at this for better guide.
yes, after first part of installation.
I’ve included video there, you should check.
@51lieal I followed this is exact guide and it worked well but now I would like to switch back to using only the ssd without booting from SD card. Is it possible without reinstalling? I guess I would need to shrink the partition but I don’t know how to do it since the whole disk is encrypted.
@51lieal Please clarify for us when we should use the $uuidR or $uuidB as a variable and when we should use it alphanumerically, thank you.
