Can we fix that anyway?! For example : when starting teams or libreoffice there should not be only the colored vm qube- There should be the icon in the color u prefer. Just selecting the icon in properties doesn*t change anything. maybe I have to modify the .desktop file to use an other png. I got an other .png in the qubes appmenus but not in the pannel. Everywhere I have got the right icon, but as soon I start the app it will be the qube. That will be very good to know how to get that working. Then I would post a new kde-customization thread for qubes 4.1 and we can say that KDE is fully working. I will update later a few dependencies I installed later. Atm the icon is the only problem I noticed with KDE. And an other advantage is that you can change the language of ur system to german, arabian or what u need
The problem with the icon should be sth. with the breeze and oxygen theme and need to copy in one of this folder anywhere:D. It uses .svg files as pictures and the other one .png from the hi-color folder. I think we need to copy the icon in one of those folder and maybe change the .png to .svg or sth like that ,but I don’t know how to get it working and my main problem is the correct path. And some apps like teams did not tell dom0 that the app is installed and did not have a link to the high color icon folder. But too much folders for me to get the structure how and where to place the icon. But we are getting closer. Anytime we can fix it;)
Btw I try to update how to install Kde with its main and useful dependencies at a github page and summarize all our results their, so it wil be easier for new people to get it working. The icon problem is one of the last things I cannot fix and like to tell everybody how that is working. But I sometimes I have no time and need some to update the page and I do not garanty for any problems and it should just be a help for new users:)
The problem with icons is that a app like teams don’t have the step: processing trigger for hi-color-icon-theme and most apps do this at installing. But how to do it for these apps , unfortunately I don’t know …
When I did sudo-qubes-dom0-update @kde-desktop-qubes, it gave me a list of the core packages it was attempting to install in the sys-firewall popup terminal. I copied and pasted the core list from there, used dnf to install:
Everything works except, missing icons on the dock (start icon, + vm nm icons). All other icons are there (including virtual desktops). Yay, finally runing KDE in 4.1.
One other issue: The window manager has locked up twice in the few hours since I swiched…not sure why yet. I restart it via a console: ctrl-alt-F2 to get a console, then log in, then sudo systemctl restart sddm
@face
I didn’t run into package group issues when installing KDE in dom0, but that was probably >6mo ago. KDE was experiencing random startup problems until I used dylangerdaly’s workaround for the bad hpet timer on my system. Now KDE is very solid. However, the system still does lock up if I use the built-in Wifi (Intel AX200) which causes IOMMU errors to be reported in the hypervisor.log. When using a USB Wifi adapter instead, the system is rock solid for weeks.
The KDE colors actually do work, but they have no default setting. You can create the settings with a small script which I added to my KDE startup.
Thank you for writing those lines @face I was too lazy and busy the last weeks. Of course I installed this, too, after running sudo qubes-dom0-update @kde-desktop-qubes, I run sudo dnf install plasma-workspace and took a screenshot of the packages that are usually in the kde group and installed it after that step. But now it is much easier, just to copy these lines to dom0. Thank you very much again
My lines are just some more to add the addon to the bar if you like such things and then kde should be completely. But you don’t need it. And you can install it in one step ,not like i told u up.
just in dom0: sudo qubes dom0-update qt5-qtbase-devel qt5-qtdeclarative-devel qt5-qtx11extras-devel kf5-plasma-devel kf5-kglobalaccel-devel kf5-kxmlgui-devel
I like KDE and Qubes. And I am running this setting since 2-3 month without much problems and can prefer it to everybody, especially new users should have it a bit easier to work with kde .
Ps; A few icons are missing for me two and I don*t know how to fix it, because the folder structure in qubes, kde and all those vm’s is difficult for me, but maybe anytime I know the place where to copy a .png file and to have icon available for those missing apps. Or maybe anybody can help here and know the right place. Then we can use a custom icon for those apps, with a missing one.
@face can you please tell me how to use the color script? I have to download it as a .sh and install it in dom0 or what is the easiest way? sorry for that nooby question, but sometimes I hang at easy things and more difficult things works …
@rasta yes, just install it in dom0 and run it. tasket’s script is a .sh, the official one is a .py. Tasket suggested putting the script in autostart for kde, but you really only need to run it once and it creates some color configurations under $HOME/.local/share/qubes-kde/…
In a nutshell:
dom personal:
cd /tmp
wget https://raw.githubusercontent.com/QubesOS/qubes-desktop-linux-kde/master/qubes-generate-color-palette
now manually inspect qubes-generate-color-palette, make sure it is not nefarious
It makes a lot of fixes (journalctl is full of non-critical errors), but i haven’t a clue how to use or install it. I’ve searched for a great deal of time on how to do it. But the closest I’ve got is to create an RPM which isn’t really the route i’d like to take. I’m sure I managed to run it in the alpha but can’t remember for the life of me how I did.
I tried different methods to add different Qubes OS input methods, but the only one worked. The best way is to add all of the settings during install, otherwise follow instructions below.
So, to add new input language in Qubes do the following:
Log Out of KDE session
On a login screen choose Xfce desktop environment
Login
Open Main Menu -> System Tools -> Keyboard, choose Layout tab
Unselect Use system defaults and change input layout settings as needed.
If you added new layouts in KDE settings first, there could be some bugs. Try to delete and add everything.
If easy way of doing it did not work for you, then follow the official manual.
Is the hope of full KDE reworked support now completely dead? Is XFCE, going forward, literally the only DE Qubes will support (i know XFCE is the only official, I am referring to community support). I have KDE running on full testing enabled 4.1 qubes, but it seems that the reworking of KDE has come to a stop and there are endless errors in journalctl, which i think fepitre’s reworking was resolving. It would be a shame to ‘strictly’ only support XFCE when it seems a good number of people, myself included, hate/very much dislike the XFCE desktop…
Don’t do this. (Besides the fact that dnf wont do anything in dom0,
so it just wont work.)
Because of the refactoring in 4.1, you get KDE with Qubes support
by issuing sudo qubes-dom0-update kde-settings-qubes in dom0.
Some rough edges, but all the benefits of KDE and decent coloring.
No - there are rough edges that need polishing.
It’s a mistake to think that Xfce is “the only official DE” - it’s the
default, but Qubes provides official packages to support KDE and i3.
With a small team, it’s necessary to prioritise, and KDE support isn’t a
priority.
Despite the log errors, (and the perennial icon bug in the panel), I
find it as good as ever.
I think the move to Xfce was a huge mistake, and KDE far better suited
to Qubes workflow.
As always @unman , your reply is very much appreciated, and although you do not speak for the Qubes team, your input on various things all things Qubes, I’m sure, many are grateful for. The network icon bug doens’t really bother me at all, and I agree that move from KDE to XFCE was a mistake - but I’m obvioulsy speaking with compete bias. I’ll just hope the people who have the capabilities to support KDE well, can, hopefully, bring it on track. As a side note/question…Would you be able to tell me how to impliment the spec.in in fepritre’s reworking? I’m not a novice, but I am certainly not a developer of any kind, nor someone who has any history of compiling rpm packages…Quite literally anything you can tell me with respect to this, I would be grateful to hear.
sorry that im crashing this thread and asking a bit different question here but as i read this i was wondering is there anywhere a list what the qubes-dom0-update package manager brings for us? i got the feeling there are some interesting packages in here
I found KDE and latte dock was important for me when I used Ubuntu-studio but I don’t like it in Qubes due to the lack to functionality to customize things like the theme. Also latte dock doesn’t pin AppVM and the menu structure requires one additional click to get to the same point.
That’s unexpected from my point of view. I find KDE more customisable (including themes) than probably any other DE, Admittedly, you’re limited on the window titlebars if you want Qubes colouring.
If you set your global theme and preferences in systemsettings5 and maybe something like qt5ct you can get qubes gui stuff like qubes manager themed perfectly. Then just edit your config files for GTK, or install some app for this.
I don’t know how/when the cache is updated in dom0 but you can do “dnf search WhatYou’reLookingFor” if you need something specific. Obviously the less clutter in dom0 the better though.
Crash away - if you are on 4.1, you’ll find output in a pop-up window
rather than passed through to dom0 - somewhat confusing and poorly
thought through imo.
Also, qubes-dom0-update doesn’t support the handy repository-packages ... list option
You can use variations on: qubes-dom0-update --action=list --disablerepo=* --enablerepo=qubes-dom0-current
I’ve been playing with Qubes for a while getting to know it. As well as finally learning a lot more about Linux something I just never found the time for at work since we’re mainly a Windows shop.
I loved the idea around Qubes on and endpoint level yes I use VMWare workstation for testing but designing an OS around a Hypervisor to isolate it is brilliant.
But the interface hasn’t done it for me exactly in xfce. Finally getting KDE working and all the tweaks to the interface I’ve already been able to change, now this is feeling more natural and alot closer that it did to something I’ll be using as a daily driver very soon. With a little more work getting the GUI how I want it and putting it through its paces for my daily tasks. As well as continuing to adapt 99% of those tasks away from Windows and over to Linux Qubes and appropriately isolated.
Granted I’ll still need to go back to the latest documentation and get a Windows VM up as well for a small number of specific tasks with the VM restricted to a small number of IP’s.
Anyway I setup using:
sudo dnf install and reinstall commands for the same package list
Not sure if the reinstall was needed, someone else suggested it in a thread and it did load packages the initial install command apparently failed to load.
disabled lightdm and enabled sddm
I only noticed one very minor annoyance in KDE not sure if anyone has a known solution. I can of course live with it very minor like I said.
**IGNORE this first one I noticed someone else answered this above but I missed it.
The network icon is just a white square. I’m guessing that part just isn’t done as far as the rework goes, clicking on the icon does what it’s supposed to do that’s what counts haha.
And two questions
I noticed it’s wierd the mic icon keeps telling me the mic is connected to basically every VM powered on even though device manager says it’s connected to nothing. I’m guessing people just hide that icon?
I’m guessing as far as additional theme’s or icon sets the recommended method is to download them on a dispvm and then install them from a file? Although what I have looks fine I don’t want to load up dom0 with excess stuff.
