daz
January 3, 2023, 8:40am
#1
Hi Guys,
For some reason I cannot get my ledger usb to be recognized within Qubes Devices, However I can see it via lsusb via dom0 terminal, what do I need to do to get it recognized via Devices?
Thanks
Darren
Some relevant discussions:
I have a Ledger harware wallet that connects to my laptop with USB. Ive checked in the [Dom0] terminal with qvm-usb and qvm-pci but cant find it and need to conect it to the Ledger Live app I installed in a vitual machine. Any help please?
Hello, i have set up my sys-usb, my qube can find my ledger but when i attached the ledger to my monero qube then cant find the monero app my ledger device…yubikey works fine, ledger dont work…
When i am in the app then i put my pin in the ledger and i ll create a wallet in monero gui but dont work.
Should i first install the ledger live?
Best regards,
kencho
The following is a new how-to guide for users who are
starting out with Qubes OS. You can also find it in our documentation
under How to organize your qubes .
When people first learn about Qubes OS, their initial reaction is often, “Wow,
this looks really cool! But… what can I actually do with it?” It’s not
always obvious which qubes you should create, what you should do in each one,
and whether your organizational ideas makes sense from a security or usage
perspective.
Each qube is essential…
Greetings,
I am having difficulty getting my Ledger Nano S hardware wallet working with the Monero GUI wallet app on my anon-whonix Qube.
After plugging in the Ledger Nano S, unlocking it and opening my Monero app (on the hardware device) it appears as a USB device in my device list on Qubes. I am then able to attach this USB to anon-whonix.
However, when I attempt to restore my wallet using the hardware device option in the Monero GUI wallet on anon-whonix (something I have never had issues …
Hi Darren,
you should assign the ledger to an AppVM via the sys-usb,
Attached is a link with the instructions for Qubes:
Installation, Setup, Security, Ledger Live, Electrum
In the template for the AppVM where the ledger should be used I still had to install the following packages:
apt install pyhton3-ecdsa python3-btchip
