Why Anonymity No Longer Exists in 2026 - Open Discussion
I found this great Reddit post on why one click anonymity does no longer exists in 2026:
https://old.reddit.com/r/Whonix/comments/1rellkq/video_summary_tails_whonix_qubes_os_why_anonymity/
:onion: http://red.lpoaj7z2zkajuhgnlltpeqh3zyq7wk2iyeggqaduhgxhyajtdt2j7wad.onion/r/Whonix/comments/1rellkq/video_summary_tails_whonix_qubes_os_why_anonymity/
This is just a repost because I think it’s worth discussing here.
Summary: Tails, Whonix & Qubes OS — Why Anonymity No Longer Exists in 2026
Context & Premise
The presenter (Vector T13, 17 years of practice in the field) argues that simply installing privacy-focused operating systems like Tails, Whonix, or Qubes OS is no longer sufficient for anonymity in 2026. These systems were architectural masterpieces when created but remain stuck in 2013-era threat models. The webinar demonstrates this by running 10 practical attacks against all three systems.
The Three Systems at a Glance
Tails — Boots from a USB drive, runs entirely in RAM, all traffic routed through Tor, wipes RAM on shutdown. Public since ~2013. Designed purely for anonymity. The most “plug and play” of the three.
Whonix — Runs as two virtual machines: a Gateway (internet access, no file access) and a Workstation (file access, no internet access). Connected via internal network bridge. Even if malware executes, it cannot discover the user’s real IP. Well-audited for leak prevention.
Qubes OS — A hypervisor-based OS that isolates tasks into separate virtual machines (“cells”). Architecturally brilliant (developed by a prominent researcher), but almost nobody actually uses it in practice. Vulnerable to Meltdown/Spectre class attacks by design.
Historical Context: The Snowden Revelations (2013)
These systems gained fame largely through Edward Snowden’s 2013 leaks, which revealed:
  • PRISM — NSA system that could access all user data from 200+ US tech giants (Google, Facebook, Microsoft, Apple, etc.) with a court order. Active monitoring: companies were required to submit monthly reports and cooperate on demand. No geographical restrictions.
  • Treasure Map — Global internet mapping tool that could trace connection paths across countries and continents.
  • The 2013 US intelligence community budget for these programs was $90 billion; by 2025 it reportedly reached $272 billion.
    The presenter’s key point: if this is what was possible in 2013, imagine what exists in 2026 that we don’t know about.
The 10 Attacks (Scorecard: Tails 3, Whonix 1, Qubes 2 out of 10)
Attack 1: MAC Address Tracking
  • Tails: Has built-in MAC spoofing — passes
  • Whonix: No built-in spoofing, but running on a VM inherently changes the MAC — partial pass
  • Qubes: MAC spoofing works for Ethernet but not Wi-Fipartial fail
Attack 2: Government Blocking of Tor
  • Tor is banned or restricted in many countries. Blocking methods are simple: TLS fingerprint blocking, port blocking, TCP traffic pattern analysis, blocking known entry node IPs.
  • AI-enhanced DPI systems make blocking even easier now.
  • None of the three systems include built-in anti-censorship/anti-DPI bypass. Bridges exist as add-ons but aren’t default. All three fail.
  • Named commercial systems doing this: Sophos, Fortinet, Vectra AI, Cisco Mercury (open-source on GitHub). These use machine learning and fixed rules for traffic classification.
Attack 3: Device Traffic Pattern Analysis
  • ISPs can profile devices by their background network “noise” (OS services, update checks, IoT devices, etc.). This fingerprint reveals what OS you run, what devices are active, and even behavioral patterns (when you sleep, watch TV, vacuum, etc.).
  • Scenario A (booting Tails on a work laptop): The normal traffic noise suddenly vanishes and is replaced by Tor traffic — a dead giveaway that a second OS was loaded.
  • Scenario B (dedicated secret laptop): ISP sees a new network subject appear alongside existing devices.
  • Virtual machine networking mode matters: NAT mode blends Tor into host traffic; bridged mode exposes a separate device.
  • None of the three systems generate fake background noise to mask their traffic patterns. All fail.
Attack 4: Tor Volume Pattern (TVP) Analysis
  • Tor fragments traffic into fixed 512-byte cells and adds minimal padding during idle periods to obscure timing.
  • However, the volume of traffic is still visible. Casual browsing/messaging produces low-volume patterns; downloading large files produces massive spikes.
  • This volume analysis has been used by US/EU law enforcement since at least ~2018 as an automated alarm system — a large Tor traffic spike flags the user for investigation.
  • The padding Tor generates is negligibly small by 2026 standards and essentially meaningless against modern analysis.
  • All three systems fail — none address traffic volume masking.
Attack 5: End-to-End Correlation
  • Even Tor developers officially acknowledge they cannot defeat this attack class.
  • In 2021, it was revealed that a group (likely intelligence services) controlled large numbers of both entry and exit relays, tagging packets to correlate users’ entry and exit points — effectively deanonymizing them. This specific vulnerability was patched in 2022.
  • A variant still works: ISP-side correlation combined with communication timing. By engaging a target in conversation (e.g., via Telegram) and sending files of known size at known times, investigators can correlate Tor traffic spikes with specific users. Over several days of snapshots, neural networks can identify targets with ~93% accuracy.
  • All three systems fail.
Attack 6: RAM Forensics (+ Swap/Hibernation Files + Frame Buffer)
This is a multi-layered attack:
  • RAM capture: If a machine is seized while powered on, all data in RAM (passwords, keys, messages) is stored unencrypted and can be extracted. RAM data persists for minutes after power loss; freezing RAM with liquid nitrogen can preserve it for days.
  • Tails: Has a built-in “trigger tipping” mechanism that overwrites RAM (ones → zeros) on shutdown — passes.
  • Whonix & Qubes: Have no RAM-clearing mechanismfail.
  • Swap/Page files: Whonix and Qubes use swap/page files, meaning RAM contents can be written to disk permanently. The presenter found 6 months of Jabber chats, images, and other sensitive data in a page file during a 2015 forensic investigation. Mentioned Belkasoft as the leading forensic tool company.
  • Tails: Doesn’t use swap or hibernation — passes (unless run inside a VM on Windows, where the host OS may page Tails’ memory to disk).
  • Whonix & Qubes: Vulnerable through swap/hibernation files — fail.
  • Frame buffer forensics: GPU memory stores rendered frames (screenshots of your work). With discrete GPUs, this memory can be forensically examined. With integrated graphics, frame data goes to RAM and potentially to swap files — extractable as actual screenshots of user activity.
  • All three systems are essentially vulnerable; none address this.
Attack 7: (Covered within Attack 6 discussion — swap/hibernation as sub-attack)
Attack 8: Zero-Day Vulnerabilities
  • Zero-days appear daily by the hundreds. Intelligence agencies target not the Tor network itself (economically unjustifiable) but the client software: browsers, messengers, email clients, media handlers.
  • Key case study: FBI’s 2015 “PlayPen” operation deployed malware via a zero-day that scanned users’ active network connections to obtain real IPs. All Tor Browser users were compromised; Tails users were also compromised.
  • Whonix users would have been safe because the workstation VM has no knowledge of the real IP address — even malware running with full privileges cannot discover it.
  • Whonix: passes. Tails: fails. Qubes: partial (in raw form).
Attack 9: Ultrasonic Cross-Device Tracking
  • Media files (video, audio, web resources) can contain encoded ultrasonic signals inaudible to humans. A nearby device (phone in your pocket) picks up the signal and reports back, linking your anonymous session to your real identity/device.
  • Referenced Snowden’s 2013 warning that using iPhones was “a crime” from a privacy standpoint.
  • All three systems fail — none address this. It’s a physical-layer attack that software alone can’t fully prevent.
Attack 10: TCP/IP Fingerprinting
  • TCP headers reveal OS type, version, and even network card characteristics. While Tor rewrites the TCP stack before it reaches the destination website, the ISP sees the original TCP fingerprint before it enters the Tor network.
  • Tails is visible as Linux; Whonix reveals the virtualization platform (VirtualBox, VMware, QEMU); Qubes shows Linux with certain artifacts.
  • Combined with systems like Palantir Gotham that surveil from the origin point (not the destination), this becomes a meaningful identification vector.
  • None of the three systems manipulate TCP headers to mask their identity from the ISP. All fail.
Key Takeaways
  1. “Install and forget” anonymity is dead. All three systems score 3/10 or lower against basic, well-known attacks. In raw/default form, they are relics of a 2013 threat model.
  2. The ISP is your biggest enemy. Most attacks exploit what the ISP can observe: traffic patterns, volume, timing, TCP fingerprints, device profiles. The target website is almost irrelevant — surveillance starts at the origin.
  3. AI/ML has transformed traffic analysis. Automated DPI systems (Vectra AI, Cisco Mercury, Sophos, Fortinet) combined with neural networks make Tor detection, blocking, and user correlation far easier and cheaper than manual analysis ever was.
  4. Encryption ≠ anonymity. Encrypted messengers (Matrix, Element, Signal, Threema, Jabber) protect content but leak metadata, timing, and volume patterns that can deanonymize users.
  5. The critical missing piece is an intermediate network device — a properly configured router, Raspberry Pi, VPN server, or Hysteria proxy that sits between your machine and the ISP. This would mitigate attacks 2, 3, 4, 5, and 10 by hiding traffic patterns, masking TCP fingerprints, and bypassing Tor blocks.
  6. Many vulnerabilities are fixable with proper configuration (disabling swap files, avoiding VMs on host OSes, adding traffic noise, using intermediate routing devices), but the systems don’t do this by default, and most users won’t do it themselves.
  7. Surveillance is patient. The presenter’s personal Dropbox screenshot showed the FBI requested his data in October 2022 and he wasn’t notified until March 2024 — a year and a half of silent monitoring. Users can be watched for years before action is taken.
Was this synthetic video and the post even reviewed by a human in the first place, other than being uploaded and pasted after a generative model has finished its work?
Qubes OS was designed for security in mind, not privacy. For privacy the integration with Whonix is what matters.
The why does my link/ether address differ from my permaddr in sys-net?
This seems more about complaints that Tor traffic isn’t masked properly, rather than about anonymity. How can a service, that I’d use/visit through Whonix Workstation in Qubes OS prove, that it was me, if no personal information (or other identifiers) has been provided?
Yes, protecting confidential data from memory forensics is hard, as described in Thoughts dereferenced from the scratchpad noise. | ram-wipe: Further analysis
This is true in general, even if considering someone, who cares about keeping the information safe from prying eyes, but not about anonymity. Does this section try to suggest, that a service, that I’d use/visit through Whonix Workstation in Qubes OS, would notify the authorities that at a given time someone used it in such a way, so that all Tor users would be subjected to forensic examination?
This once again shows no understanding that Qubes OS was designed for security in mind, not privacy.
What if I mute my speaker?
What if I don’t have a phone at all, or one that “reports back” (unless infected with malware)?
I personally would be more worried about attacks that make use of a “noisy” electromagnetic environment, addressed by some rugged machines that meet the MIL-STD 461 standard. Again, this isn’t about anonymity per-se, but seems worth mentioning.
Yes, I’m sure that if I ran an application in Whonix Workstation in Qubes OS, the application would be able to read e.g. my keyboard layout, my dom0 timezone and other identifiers described 2 years ago in How to hide the fact that I'm Qubes OS from Telegram - #80 by aronowski
Qubes OS and its Whonix integration are free and anyone can download and use them. So let me ask for the third time, how can a service, that I’d use/visit through Whonix Workstation in Qubes OS prove, that it was me, if no personal information (or other identifiers) has been provided?
I recommend learning more about Signal’s purpose and why it’s internally named “org.thoughtcrime.securesms”.
(Note: I spoke too soon)
Please keep the topic about Qubes. Otherwise we will have to close it (even though many here, including myself are keen to discuss it).
I can tell that about my side, I don’t know about the original redditor. Though I’m not a security or privacy expert, a reason, why I reposted it here.
Also I stumbled about this post already 3 months ago and haven’t seen anyone yet talking much about this.
I think that’s a very great point!
Can you explain?
Yes, I wouldn’t give that hold against QubesOS too. About your question: It probably depends on your threat model, the service will not know, but maybe you are a journalist in an dictatorship with advanced surveillance capabilities. For 90% of people it is probably still safe, still we’re lacking an anonymity network right now capable defending against such attacks. Maybe Datura will fix it?
There is actually a fix to this the author probably doesn’t know about: @linuxuser1 's 🛡 Qubes OS live mode. dom0 in RAM. Non-persistent Boot. RAM-Wipe. Protection against forensics. Tails mode. Hardening dom0. Root read‑only. Paranoid Security. Ephemeral Encryption. But it isn’t preinstalled by default. Maybe it would be worth it?
I use it everyday and like it.
I don’t read this out of this.
Again, totally agree!
What if I mute my speaker? […]
I have no idea!
Thanks for the recommendation!
Mullvad VPNs DAITA attempts to overcome traffic pattern analysis by sending packets in fixed size and fixed frequency all the time. ISPs will not know if the packet carries actual internet traffic or one created by DAITA. However I am not sure how effective this solution is in stopping traffic pattern analysis.
Add on top of these that the Intel ME and AMD PSP have full read+write access to the memory used by the subordinate CPU. Anyone who got a better grade than a C- in computer science 101 can comprehend what the presence of Intel ME and AMD PSP means in real-world practice… Flipping the HAP bit hasn’t done shit since the HAP bit was burned and newer Intel ME firmware images were released.
The spy OS on these spy chips that control the entire board guarantee that a target can always be compromised and any OS on the subordinate CPU (Qubes included) can’t do anything about it.
Tor is inadvertantly designed to be friendly to the surveillance.
Part of the solution is a delay oriented protocol like NNCP with hops done over QUIC with encrypted hello for the QUIC sessions. Delay oriented protocols can shirk potential for traffic analysis to be useful.
Delay oriented protocols are not backwards compatible with standard web protocols out of the box. Existing applications can be retrofitted with a proxy to be accessible by delay oriented protocols in some cases.
Even if the network effect of delay oriented protocols remains small it’s still a win for high value users.
_
What this means in real-world practice for those 90% of people is the attempts they maintain their privacy are a placebo. The banality of their traffic doesn’t change that their traffic is analyzed and their attempts at having privacy are totally defeated by traffic analysis in the ai era.
They don’t achieve any safety. Their activities just happen to be inconsequential or too small to act on. This further serves to provide a false sense of safety to the remaining 10% which is dangerous for everybody.
_
For a lot of us out there, our anonymity is essential to our personal safety, our “security”. In pedantic technical terms, “privacy and security are not the same thing” is something many could agree on, in pedentic technical terms.
For many of us, without anonymity we don’t have security. For many privacy/anonymity and security are effectively one and the same.
I’ll have to close this as the topic itself as it encourages discussion in a way bigger scope than just Qubes (what this forum is all about).
If anyone wants to continue discussion, please open a topic with only one subject and contextualize it around Qubes.
Qubes OS — […] Vulnerable to Meltdown/Spectre class attacks by design.
I don’t understand this. These are CPU vulnerabilities, not OS ones. How can an OS be designed (intentionally) to be vulnerable to those?
I thank thee brave and good sir for defending Our Democracy™.
This topic was automatically closed after 4 hours. New replies are no longer allowed.
