Continuing the discussion from Why Anonymity No Longer Exists in 2026 - Open Discussion:
Simply installing anything in privsec field is a dubious claim. Have it ever been different?
complexity
I have a suspicion that computing cannot be simple by nature. Things like package managers and privacy extensions for browsers just shift the problem around. Real simplicity is achieved either through science, like a better performing algorithm, or minimalism, e.g. cgit vs codeberg or alpine vs QubesOS. But even in these cases you may argue that we’re just shifting complexity - either by using trickier algorithm, or by shifting the burden of missing features elsewhere.
In any case, some described problems are unreasonable or wrong. Privacy is hard, and it’s unlikely to get better any time soon. I guess topics like this are a reminder of the uneven struggle.
To make this post qubes-specific, here are some correctoins:
AFAIK it’s the other way around, and you can set up Ethernet MAC spoofing
I refuse to believe there is a significant portion of tor users tat is not aware of the built-in bridge mechanism. Are not default as a government blocking counter-measure.
Does not discuss qubes, although qubes is very good at generating background noise. In any case, unintentional background noise is useless against DPI, and arguably harms your privacy if you’re running Qubes.
Related: NovaCustom + BusKill partnership
Together with encryption should be okay for all but highest-ranking supervillains.
Everybody is vulnerable to lightning strikes. That is why I never leave the house.
Also whonix shouldn’t pass because network software 0-days are not impossible
Qubes is actually decent at this as it doesn’t come with audiovm preinstalled, and you can whitelist which qubes are allowed to use media system.
There are other similar techniques, sound from media isn’t the only option.
