It is quite lengty, but here it is below:
+ set -e
+ true 'INFO /usr/bin/sdwdate-log-viewer: START'
+ /bin/journalctl --boot --output cat -n 10000 -f
+ grep --color 'sdwdate\|bootclockrandomization\|anondate\|firewall\|suspend-pre\|suspend-post'
/var/lib/sdwdate is not a symlink
Bind mounting /rw/bind-dirs/var/lib/sdwdate onto /var/lib/sdwdate
Starting Whonix firewall loader...
2022-06-06 12:36:48 - /usr/bin/whonix-gateway-firewall - OK: Loading Whonix firewall...
2022-06-06 12:36:48 - /usr/bin/whonix-gateway-firewall - OK: Skipping firewall mode detection since already set to 'full'.
2022-06-06 12:36:48 - /usr/bin/whonix-gateway-firewall - OK: (Full torified network access allowed.)
audit: type=1400 audit(1654519008.964:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/whonix_firewall" pid=421 comm="apparmor_parser"
audit: type=1400 audit(1654519008.964:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/libexec/whonix-firewall/**" pid=421 comm="apparmor_parser"
AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/whonix_firewall" pid=421 comm="apparmor_parser"
AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/libexec/whonix-firewall/**" pid=421 comm="apparmor_parser"
audit: type=1400 audit(1654519008.995:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="bootclockrandomization" pid=437 comm="apparmor_parser"
AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="bootclockrandomization" pid=437 comm="apparmor_parser"
AVC apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/sdwdate" pid=450 comm="apparmor_parser"
Condition check resulted in Qubes base firewall settings being skipped.
Condition check resulted in Qubes firewall updater being skipped.
+ addgroup sdwdate systemd-journal
The user `sdwdate' is already a member of `systemd-journal'.
+ gcc /usr/libexec/sdwdate/sclockadj.c -o /usr/libexec/sdwdate/sclockadj -ldl -D_GNU_SOURCE -Wdate-time -D_FORTIFY_SOURCE=2 -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -Wl,-z,relro -Wl,-z,now
2022-06-06 12:36:04 - /usr/bin/whonix-gateway-firewall - OK: Whonix firewall loaded.
Finished Whonix firewall loader.
Started Whonix firewall watcher.
Finished Notify sdwdate-gui on gateway about shutdown..
2022-06-06 12:36:08 - sdwdate - INFO - sdwdate started. PID: 1068
2022-06-06 12:36:08 - sdwdate - INFO - Tor socks host: 127.0.0.1 Tor socks port: 9108
2022-06-06 12:36:08 - sdwdate - INFO - Running sdwdate main loop. iteration: 1 / 10000
2022-06-06 12:36:10 - sdwdate - INFO - PREPARATION:
__ Status: First run after boot. (Creating file '/run/sdwdate/onion-time-script-after-boot'.)
2022-06-06 12:36:10 - sdwdate - INFO - PREPARATION RESULT: WAIT.
2022-06-06 12:36:13 - sdwdate - INFO - PREPARATION:
2022-06-06 12:36:13 - sdwdate - INFO - PREPARATION RESULT: WAIT.
2022-06-06 12:36:17 - sdwdate - INFO - PREPARATION:
2022-06-06 12:36:17 - sdwdate - INFO - __ ### START: ### /usr/libexec/helper-scripts/onion-time-pre-script
2022-06-06 12:36:17 - sdwdate - INFO - PREPARATION RESULT: SUCCESS.
2022-06-06 12:36:17 - sdwdate - INFO - Initial time fetching in progress...
2022-06-06 12:36:17 - sdwdate - INFO - Running sdwdate fetch loop. iteration: 1
2022-06-06 12:36:17 - sdwdate - INFO - pool 0: pool_size: 18 url_index: 13 already_picked_number: 1 already_picked_index: [13]
2022-06-06 12:36:17 - sdwdate - INFO - pool 1: pool_size: 18 url_index: 11 already_picked_number: 1 already_picked_index: [11]
2022-06-06 12:36:17 - sdwdate - INFO - pool 2: pool_size: 25 url_index: 1 already_picked_number: 1 already_picked_index: [1]
2022-06-06 12:36:17 - sdwdate - INFO - requested urls ['http://monerotoruzizulg5ttgat2emf4d6fbmiea25detrmmy7erypseyteyd.onion', 'http://fpfjxcrmw437h6z2xl3w4czl55kvkmxpapg37bbopsafdu7q454byxid.onion', 'https://vfnmxpa6fo4jdpyq3yneqhglluweax2uclvxkytfpmpkp5rsl75ir5qd.onion']
[session uid=1000 pid=1269] Activating service name='org.gtk.vfs.Daemon' requested by ':1.7' (uid=1000 pid=5079 comm="xfce4-terminal --title=sdwdate Log Viewer --hold -")
user : TTY=pts/0 ; PWD=/home/user ; USER=root ; COMMAND=/usr/bin/sdwdate-log-viewer
2022-06-06 12:38:17 - sdwdate - INFO - returned urls "['http://monerotoruzizulg5ttgat2emf4d6fbmiea25detrmmy7erypseyteyd.onion', 'http://fpfjxcrmw437h6z2xl3w4czl55kvkmxpapg37bbopsafdu7q454byxid.onion', 'https://vfnmxpa6fo4jdpyq3yneqhglluweax2uclvxkytfpmpkp5rsl75ir5qd.onion']"
2022-06-06 12:38:17 - sdwdate - INFO - failed_urls: 3 allowed_failures: 6
2022-06-06 12:38:17 - sdwdate - INFO - Running sdwdate fetch loop. iteration: 2
2022-06-06 12:38:17 - sdwdate - INFO - pool 0: pool_size: 18 url_index: 9 already_picked_number: 2 already_picked_index: [13, 9]
2022-06-06 12:38:17 - sdwdate - INFO - pool 1: pool_size: 18 url_index: 3 already_picked_number: 2 already_picked_index: [11, 3]
2022-06-06 12:38:17 - sdwdate - INFO - pool 2: pool_size: 25 url_index: 23 already_picked_number: 2 already_picked_index: [1, 23]
2022-06-06 12:38:17 - sdwdate - INFO - requested urls ['http://offprivqqdxfmssktx3y5h3miqvceq6yy37s5sxkhz4mojvsz74ohqid.onion', 'http://cct5wy6mzgmft24xzw6zeaf55aaqmo6324gjlsghdhbiw5gdaaf4pkad.onion', 'http://ogdwaroarq4p6rnfn2hl4crvldyruyc2g24435qtxmd3twhevg7dsqid.onion']
user : PWD=/home/user ; USER=sdwdate-gui ; COMMAND=/usr/bin/bash -c echo "disp9062 status" | tee /run/sdwdate-gui/anon-status >/dev/null
pam_unix(sudo:session): session opened for user sdwdate-gui(uid=113) by (uid=1000)
pam_unix(sudo:session): session closed for user sdwdate-gui
2022-06-06 12:40:17 - sdwdate - INFO - returned urls "['http://offprivqqdxfmssktx3y5h3miqvceq6yy37s5sxkhz4mojvsz74ohqid.onion', 'http://cct5wy6mzgmft24xzw6zeaf55aaqmo6324gjlsghdhbiw5gdaaf4pkad.onion', 'http://ogdwaroarq4p6rnfn2hl4crvldyruyc2g24435qtxmd3twhevg7dsqid.onion']"
2022-06-06 12:40:17 - sdwdate - ERROR - General Timeout Error. Internet connection might be down.
2022-06-06 12:40:17 - sdwdate - INFO - Sleeping for 97 minutes, ok.
2022-06-06 12:40:17 - sdwdate - INFO - running command: sleep 5815.215267807
user : PWD=/home/user ; USER=sdwdate-gui ; COMMAND=/usr/bin/bash -c echo "anon-whonix status" | tee /run/sdwdate-gui/anon-status >/dev/null
user : PWD=/home/user ; USER=root ; COMMAND=/usr/sbin/sdwdate-clock-jump
root : PWD=/home/user ; USER=sdwdate ; COMMAND=/usr/bin/touch /run/sdwdate/clock_jump_do_once
pam_unix(sudo:session): session opened for user sdwdate(uid=111) by (uid=0)
2022-06-06 12:51:52 - sdwdate - INFO - Signal SIGTERM received.
2022-06-06 12:51:52 - sdwdate - INFO - Exiting with exit_code '143' because or reason 'signal_handler called'.
2022-06-06 12:51:52 - sdwdate - INFO - sdwdate stopped by user or system.
2022-06-06 12:51:52 - sdwdate - INFO - sclockadj process not running, ok.
2022-06-06 12:51:52 - sdwdate - INFO - Terminated sleep process.
2022-06-06 12:51:52 - sdwdate - INFO - End.
sdwdate.service: Succeeded.
sdwdate.service: Consumed 6.281s CPU time.
2022-06-06 12:51:53 - sdwdate - INFO - sdwdate started. PID: 5881
2022-06-06 12:51:53 - sdwdate - INFO - Tor socks host: 127.0.0.1 Tor socks port: 9108
2022-06-06 12:51:53 - sdwdate - INFO - Running sdwdate main loop. iteration: 1 / 10000
2022-06-06 12:51:54 - sdwdate - INFO - PREPARATION:
2022-06-06 12:51:54 - sdwdate - INFO - __ ### START: ### /usr/libexec/helper-scripts/onion-time-pre-script
2022-06-06 12:51:54 - sdwdate - INFO - PREPARATION RESULT: SUCCESS.
2022-06-06 12:51:54 - sdwdate - INFO - Initial time fetching in progress...
2022-06-06 12:51:54 - sdwdate - INFO - Running sdwdate fetch loop. iteration: 1
2022-06-06 12:51:54 - sdwdate - INFO - pool 0: pool_size: 18 url_index: 8 already_picked_number: 1 already_picked_index: [8]
2022-06-06 12:51:54 - sdwdate - INFO - pool 1: pool_size: 18 url_index: 1 already_picked_number: 1 already_picked_index: [1]
2022-06-06 12:51:54 - sdwdate - INFO - pool 2: pool_size: 25 url_index: 11 already_picked_number: 1 already_picked_index: [11]
2022-06-06 12:51:54 - sdwdate - INFO - requested urls ['http://45tbhx5prlejzjgn36nqaxqb6qnm73pbohuvqkpxz2zowh57bxqawkid.onion', 'http://zkaan2xfbuxia2wpf7ofnkbz6r5zdbbvxbunvp5g2iebopbfc4iqmbad.onion', 'http://lvtu6mh6dd6ynqcxtd2mseqfkm7g2iuxvjobbyzpgx2jt427zvd7n3ad.onion']
2022-06-06 12:53:54 - sdwdate - INFO - returned urls "['http://45tbhx5prlejzjgn36nqaxqb6qnm73pbohuvqkpxz2zowh57bxqawkid.onion', 'http://zkaan2xfbuxia2wpf7ofnkbz6r5zdbbvxbunvp5g2iebopbfc4iqmbad.onion', 'http://lvtu6mh6dd6ynqcxtd2mseqfkm7g2iuxvjobbyzpgx2jt427zvd7n3ad.onion']"
2022-06-06 12:53:54 - sdwdate - INFO - failed_urls: 3 allowed_failures: 6
2022-06-06 12:53:54 - sdwdate - INFO - Running sdwdate fetch loop. iteration: 2
2022-06-06 12:53:54 - sdwdate - INFO - pool 0: pool_size: 18 url_index: 9 already_picked_number: 2 already_picked_index: [8, 9]
2022-06-06 12:53:54 - sdwdate - INFO - pool 1: pool_size: 18 url_index: 4 already_picked_number: 2 already_picked_index: [1, 4]
2022-06-06 12:53:54 - sdwdate - INFO - pool 2: pool_size: 25 url_index: 22 already_picked_number: 2 already_picked_index: [11, 22]
2022-06-06 12:53:54 - sdwdate - INFO - requested urls ['http://offprivqqdxfmssktx3y5h3miqvceq6yy37s5sxkhz4mojvsz74ohqid.onion', 'https://duckduckgogg42xjoc72x3sjasowoarfbgcmvfimaftt6twagswzczad.onion', 'http://xm33ge4kupk5o66eqxcd2r4fqcplpqb2sbdduf5z2nw4g2jrxe57luid.onion']
2022-06-06 12:55:54 - sdwdate - INFO - returned urls "['http://offprivqqdxfmssktx3y5h3miqvceq6yy37s5sxkhz4mojvsz74ohqid.onion', 'https://duckduckgogg42xjoc72x3sjasowoarfbgcmvfimaftt6twagswzczad.onion', 'http://xm33ge4kupk5o66eqxcd2r4fqcplpqb2sbdduf5z2nw4g2jrxe57luid.onion']"
2022-06-06 12:55:54 - sdwdate - INFO - failed_urls: 6 allowed_failures: 6
2022-06-06 12:55:54 - sdwdate - INFO - Running sdwdate fetch loop. iteration: 3
2022-06-06 12:55:54 - sdwdate - INFO - pool 0: pool_size: 18 url_index: 0 already_picked_number: 3 already_picked_index: [8, 9, 0]
2022-06-06 12:55:54 - sdwdate - INFO - pool 1: pool_size: 18 url_index: 17 already_picked_number: 3 already_picked_index: [1, 4, 17]
2022-06-06 12:55:54 - sdwdate - INFO - pool 2: pool_size: 25 url_index: 5 already_picked_number: 3 already_picked_index: [11, 22, 5]
2022-06-06 12:55:54 - sdwdate - INFO - requested urls ['https://p53lf57qovyuvwsc6xnrppyply3vtqm7l6pcobkmyqsiofyeznfu5uqd.onion', 'http://5gdvpfoh6kb2iqbizb37lzk2ddzrwa47m6rpdueg2m656fovmbhoptqd.onion', 'http://b52gknakgsyqqeq476oi5nymw6yapysfig4owqgwppi5qpuk4az6bxad.onion']
2022-06-06 12:57:54 - sdwdate - INFO - returned urls "['https://p53lf57qovyuvwsc6xnrppyply3vtqm7l6pcobkmyqsiofyeznfu5uqd.onion', 'http://5gdvpfoh6kb2iqbizb37lzk2ddzrwa47m6rpdueg2m656fovmbhoptqd.onion', 'http://b52gknakgsyqqeq476oi5nymw6yapysfig4owqgwppi5qpuk4az6bxad.onion']"
2022-06-06 12:57:54 - sdwdate - INFO - failed_urls: 9 allowed_failures: 6
2022-06-06 12:57:54 - sdwdate - ERROR - Maximum allowed number of failures. Giving up.
2022-06-06 12:57:54 - sdwdate - INFO - Sleeping for 116 minutes, ok.
2022-06-06 12:57:54 - sdwdate - INFO - running command: sleep 6959.217963267
2022-06-06 13:16:04 - sdwdate - INFO - Signal SIGTERM received.
2022-06-06 13:16:04 - sdwdate - INFO - Exiting with exit_code '143' because or reason 'signal_handler called'.
2022-06-06 13:16:04 - sdwdate - INFO - sdwdate stopped by user or system.
2022-06-06 13:16:04 - sdwdate - INFO - sclockadj process not running, ok.
2022-06-06 13:16:04 - sdwdate - INFO - Terminated sleep process.
2022-06-06 13:16:04 - sdwdate - INFO - End.
sdwdate.service: Consumed 6.020s CPU time.
2022-06-06 13:16:05 - sdwdate - INFO - sdwdate started. PID: 7000
2022-06-06 13:16:05 - sdwdate - INFO - Tor socks host: 127.0.0.1 Tor socks port: 9108
2022-06-06 13:16:05 - sdwdate - INFO - Running sdwdate main loop. iteration: 1 / 10000
2022-06-06 13:16:07 - sdwdate - INFO - PREPARATION:
2022-06-06 13:16:07 - sdwdate - INFO - __ ### START: ### /usr/libexec/helper-scripts/onion-time-pre-script
2022-06-06 13:16:07 - sdwdate - INFO - PREPARATION RESULT: SUCCESS.
2022-06-06 13:16:07 - sdwdate - INFO - Initial time fetching in progress...
2022-06-06 13:16:07 - sdwdate - INFO - Running sdwdate fetch loop. iteration: 1
2022-06-06 13:16:07 - sdwdate - INFO - pool 0: pool_size: 18 url_index: 4 already_picked_number: 1 already_picked_index: [4]
2022-06-06 13:16:07 - sdwdate - INFO - pool 1: pool_size: 18 url_index: 12 already_picked_number: 1 already_picked_index: [12]
2022-06-06 13:16:07 - sdwdate - INFO - pool 2: pool_size: 25 url_index: 17 already_picked_number: 1 already_picked_index: [17]
2022-06-06 13:16:07 - sdwdate - INFO - requested urls ['http://keybase5wmilwokqirssclfnsqrjdsi7jdir5wy7y7iu3tanwmtp6oid.onion', 'http://xp44cagis447k3lpb4wwhcqukix6cgqokbuys24vmxmbzmaq2gjvc2yd.onion', 'http://xpxduj55x2j27l2qytu2tcetykyfxbjbafin3x4i3ywddzphkbrd3jyd.onion']
2022-06-06 13:18:07 - sdwdate - INFO - returned urls "['http://keybase5wmilwokqirssclfnsqrjdsi7jdir5wy7y7iu3tanwmtp6oid.onion', 'http://xp44cagis447k3lpb4wwhcqukix6cgqokbuys24vmxmbzmaq2gjvc2yd.onion', 'http://xpxduj55x2j27l2qytu2tcetykyfxbjbafin3x4i3ywddzphkbrd3jyd.onion']"
2022-06-06 13:18:07 - sdwdate - INFO - failed_urls: 3 allowed_failures: 6
2022-06-06 13:18:07 - sdwdate - INFO - Running sdwdate fetch loop. iteration: 2
2022-06-06 13:18:07 - sdwdate - INFO - pool 0: pool_size: 18 url_index: 7 already_picked_number: 2 already_picked_index: [4, 7]
2022-06-06 13:18:07 - sdwdate - INFO - pool 1: pool_size: 18 url_index: 7 already_picked_number: 2 already_picked_index: [12, 7]
2022-06-06 13:18:07 - sdwdate - INFO - pool 2: pool_size: 25 url_index: 5 already_picked_number: 2 already_picked_index: [17, 5]
2022-06-06 13:18:07 - sdwdate - INFO - requested urls ['http://potatoynwcg34xyodol6p6hvi5e4xelxdeowsl5t2daxywepub32y7yd.onion', 'http://lxjacvxrozjlxd7pqced7dyefnbityrwqjosuuaqponlg3v7esifrzad.onion', 'http://b52gknakgsyqqeq476oi5nymw6yapysfig4owqgwppi5qpuk4az6bxad.onion']
2022-06-06 13:20:07 - sdwdate - INFO - returned urls "['http://potatoynwcg34xyodol6p6hvi5e4xelxdeowsl5t2daxywepub32y7yd.onion', 'http://lxjacvxrozjlxd7pqced7dyefnbityrwqjosuuaqponlg3v7esifrzad.onion', 'http://b52gknakgsyqqeq476oi5nymw6yapysfig4owqgwppi5qpuk4az6bxad.onion']"
2022-06-06 13:20:07 - sdwdate - INFO - failed_urls: 6 allowed_failures: 6
2022-06-06 13:20:07 - sdwdate - INFO - Running sdwdate fetch loop. iteration: 3
2022-06-06 13:20:07 - sdwdate - INFO - pool 0: pool_size: 18 url_index: 17 already_picked_number: 3 already_picked_index: [4, 7, 17]
2022-06-06 13:20:07 - sdwdate - INFO - pool 1: pool_size: 18 url_index: 11 already_picked_number: 3 already_picked_index: [12, 7, 11]
2022-06-06 13:20:07 - sdwdate - INFO - pool 2: pool_size: 25 url_index: 18 already_picked_number: 3 already_picked_index: [17, 5, 18]
2022-06-06 13:20:07 - sdwdate - INFO - requested urls ['http://jrw32khnmfehvdsvwdf34mywoqj5emvxh4mzbkls6jk2cb3thcgz6nid.onion', 'http://fpfjxcrmw437h6z2xl3w4czl55kvkmxpapg37bbopsafdu7q454byxid.onion', 'http://srumyob2jq5nvppzt66aaab333n2wmq6xgkg4khfe24ixdb7umf7mtyd.onion']
user : PWD=/home/user ; USER=sdwdate-gui ; COMMAND=/usr/bin/bash -c echo "disp1823 status" | tee /run/sdwdate-gui/anon-status >/dev/null
2022-06-06 13:22:07 - sdwdate - INFO - returned urls "['http://jrw32khnmfehvdsvwdf34mywoqj5emvxh4mzbkls6jk2cb3thcgz6nid.onion', 'http://fpfjxcrmw437h6z2xl3w4czl55kvkmxpapg37bbopsafdu7q454byxid.onion', 'http://srumyob2jq5nvppzt66aaab333n2wmq6xgkg4khfe24ixdb7umf7mtyd.onion']"
2022-06-06 13:22:07 - sdwdate - ERROR - General Timeout Error. Internet connection might be down.
2022-06-06 13:22:07 - sdwdate - INFO - Sleeping for 165 minutes, ok.
2022-06-06 13:22:07 - sdwdate - INFO - running command: sleep 9906.177963935
