Every so often I ask people not to use screenshots, or post images
without explanation.
This isnt nitpicking, as some users think.
There are two reasons why I dont like this use of images.
First, search engines dont (as yet) index images - so someone with
exactly the same problem as you, wont be led to the thread and
the solution.
If you add a text explanation to your image, then the search will work
fine.
Second, when I say I cant see these images, I mean that literally.
Let me explain.
I usually interact with the forum by email - often with a screen reader.
So what you see as a helpful image, comes to me like this:
[hvm2|690x249](upload://3shYqzlVtcZLVK7Ttmj2MUXQPF9.jpeg
Actually, I usually just get <img> - if there’s alternate text, I get
that - in the above case it would be <hvm|2690x249><img>
Not very informative.
It’s possible to add alternate text to your image - perhaps someone who
uses the web interface could explain how.
Better is to write a brief summary - something like:
eth0 is set to the same ip settings as in the Qubes Settings page,
as shown in this screenshot:
IMAGE HERE
But there is no network connection - I cannot ping any IP address:
IMAGE HERE
That’s more informative, and will be indexed by search engines.
