as the title says, my upgrade does not even start after
sudo qubes-dist-upgrade --all-pre-reboot -y
I get the above message. Manually shutdown of sys-firewall (only possible after manually shutdown of sys-whonix) will not help, because once I run the command, both start up again and the error is the same.
Can’t believe its only me, because I use a pretty normal setup. Please help.
If I remember correctly stage 1 is updating dom0 and all templates and HVMs. For this you probably want sys-firewall to download those updates.
sudo qubes-dist-upgrade --help
shows you how you can exclude sys-firewall from shutting down, if I understand that error correctly.
Ran into the same problem. Manually shutting down sys-whonix and sys-firewall prior to running the command made no difference, as the sys-firewall VM appears to re-launch the instant the qubes-dist-upgrade command is executed.
I’m re-running with this command to see if it resolves
Adding the --keep-running sys-firewall option allowed the command to complete executing, but ultimately the upgrade process failed after running both pre and post stages and performing the required reboots.
I rebooted and started again doing one stage at a time. On stage 1, I’m getting errors on a few VMs still, one Win7, one OpenBSD and the other a Debian StandAloneVM with some PGP key errors where it’s incorrectly sending qubes-os as the apt pkg distro vernsion instead of a debian one. Going to nuke the problem VMs and at least see if I can get through stage 1 without errors.
Update: I powered through the update process one stage at a time, and finally got through it. So it is possible, but might not work if you batch everything into the pre-reboot and post-reboot command options. Be prepared to re-download what seem to be the same redhat packages at each of the earlier stages in the process. It might be better to just backup your VMs and do a clean install, but I at least wanted to prove to myself that the upgrade process was viable.
For me, the first y/N prompt will start sys-whonix. After the first prompt, then shutdown sys-whonix and then yes at the second prompt. If you’ve just shutdown sys-whonix, it should work. Worked for me multiple times.
In stage 3, I did run into an issue where “Shutdown all unnecessary VMs” would also shutdown the sys-usb, which causes the loss of kb/mouse, and the inability to respond to subsequent prompts.
For me, I looked through the grub config and saw no reference to blocking dom0 So I simply removed sys-usb.
Once your upgrade was completed, did get the following warning in the Qubes menu?
“Some qubes are no longer supported!
The following qubes are based on distributions that are no longer supported:
fedora-36
Install new templates with the Template Manager”
No. I prefer to maintain the latest supported OSes if possible.
The hardest thing is to in-place upgrade a stand alone, but I’ve done it many times and the instructions are foolproof. It’s also healthy to start over now and then, and installing a new template is pretty easy. Usually the most work comes from re-configuring the new template, removing the installed apps and services that aren’t needed and installing/configuring the ones that are.
then performed a clean install (to upgrade from 4.2 to 4.2.1)
then restored the vms that I want to keep.
I get the same message. My vms are based on fedora 38.
When I click on the message (black gear symbol) - and try to clear it by installing new templates (as it insists) I only get blank qubes template manager windows. I click through them but this does not help.
To clarify - the blank window that I was getting when I clicked the icon (in the message/notification area) was/is actually the “Qubes Template Manager” - it seems to now be a permanent feature. Perhaps one in six times or so when I click the icon the window will be populated (with a list of templates). The template that it complains about (based on fedora 38) is shown at the bottom of the list as “extra” under status. And I have installed a number of the templates that it lists but it won’t go away.
When I hover over it (the black gears icon) with the cursor it says “updates are available” but none are shown. Clicking on it does not bring up the update box - instead it brings up the template manager.
