[SOLVED] 4.2 broke my oVPN qubes: Connection refused (fd=3,code=111)
(Scroll down for solution.)
ORIGINAL POST
Fresh 4.2 install
I strictly follow this (or this )
I had 4 working vpn qubes in 4.1 following guide, now i get ovpn error message, i do something wrong.
whenever i sudo openvpn --cd /rw/config/vpn --config openvpn-client.ovpn
I get error
read UDPv4 [ECONNREFUSED]: Connection refused (fd=3,code=111)
2024-04-04 14:57:28 write UDPv4 []: Operation not permitted (fd=3,code=1)
I try troubleshoot
sudo journalctl -u qubes-vpn-handler
– No entries –
sudo iptables -L -v
sudo: iptables: command not found
hmm ok??, i install in template and vm reboot. then I get:
user@vpnqube:/rw/config/vpn$ sudo iptables -L -v
Chain INPUT (policy ACCEPT 0 packets, 0 bytes)
 pkts bytes target     prot opt in     out     source               destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
Chain OUTPUT (policy ACCEPT 0 packets, 0 bytes)
user@vpnqube:/rw/config/vpn$ sudo iptables -L -v -t nat
Chain PREROUTING (policy ACCEPT 0 packets, 0 bytes)
Chain POSTROUTING (policy ACCEPT 0 packets, 0 bytes)
Nothing in /var/logs/syslog
I don’t think is this because i use iptables and script (fail-closed/killswitch threat model requirement). I look here, and here, here. I don’t use minimal templates, just fed39 and deb12
I think I need to open port somewhere? how and where? what doing wrong? I’m sad
E1&2: Formatting
E3: I read more nftables being used instead of iptables? Is there any orderly 4.2 VPN guide for Mullvad / ovpn?
Networking is super hard…
How I got my VPN qube / ProxyVM working
Requirements
  • Mullvad VPN
  • Use TCP, not UDP
  • Debian 12 template
  • Nftables replaces iptables
Step 1 - Prepare Template
Install openvpn in debian template sudo apt install openvpn nftables is already installed for me.
Step 2 - Create new qube.
Apply these settings:
  • Network: sys-firewall
  • Advanced: Check Provides network access to other qubes.
  • Check Launch qube settings after creating
  • Create, wait for settings or go to qube settings, then;
  • Go to Services > Select a service: > Custom > + Add > Name of service: vpn-handler-openvpn
  • Apply & OK
Note: Do not add any other network services or managers.
Step 3 - Create dir /rw/config/vpn
sudo mkdir -p /rw/config/vpn
Step 4 - Downloads and config files
ovpn config file
  • Go to mullvad.net
  • Account > Downloads > OpenVPN configuration > Linux > choose location > Advanced settings: TCP 443 > Download .zip archive
  • Extract .zip
Qubes-vpn-support-replace-iptables-with-nftables.zip
Step 5 Copy the files
Copy all downloaded files to the ProxyVM’s ‘/rw/config/vpn’ folder.
Change config file name to ‘vpn-client.conf’
e.g sudo cp mullvad_*.conf vpn-client.conf
Step 6 Test connection (before script)
In VPN qube, first see if there is connection with ping qubes-os.org
then
sudo openvpn --cd /rw/config/vpn --config vpn-client.conf --auth-user-pass userpassword.txt
userpassword.txt might be mullvad_userpass.txt
I just copied both with sudo cp mullvad_userpass.txt userpassword.txt
You should see ‘Attempting to establish TCP connection with xxx’ and no errors.
Make sure ports in config file are correct (thanks @ DVM)
Step 7 - Install scripts
In /rw/config/vpn you should have unziped Qubes-vpn-support-replace-iptables-with-nftables
Now install with:
cd Qubes-vpn-support-replace-iptables-with-nftables
sudo bash ./install
Step 8 - Restart VM, check connection
Reboot the vpn qube and it should now start with
Ready to start link and shortly after LINK IS UP
Thanks for all the quick responses and help!
Qubes 4.2 switched to nftables.
I see qubes-vpn-handler there, so you can use the following which works with nftables:
Also, Fedora now uses selinux, which could be the cause of the “Operation not permitted” error if you use it.
You can temporarily disable it with this command:
sudo setenforce 0
Qubes 4.2 uses nftables, not iptables. (Thus command not found.)
In those old guides you need to replace the iptables calls with the nft
equivalents.
The tables and chain structure is different in 4.2 so the rules you
apply, and where you apply them, will be different.
What script are you trying to use?
Ok I try fresh, from 1cho1ce
1. Next, add vpn-handler-openvpn to the ProxyVM’s Settings / Services tab by typing it into the top line and clicking the plus icon. Do not add other network services such as Network Manager.
I create new qube: qubevpn, it provides network access. Template: deb12 (with ovpn & nftables).
I create custom service in Settings GUI of qubevpn called: vpn-handler-openvpn
2.Copy the VPN config files from your service provider to the ProxyVM’s ‘/rw/config/vpn’ folder, then copy or link the desired config to ‘vpn-client.conf’:
I make /rw/config/vpn folder with sudo mkdir -p /rw/config/vpn
I sudo copy to /rw/config/vpn
3 Test connection
I test connection and get error
2024-04-05 09:55:15 read UDPv4 [ECONNREFUSED]: Connection refused (fd=3,code=111)
I tried with sys-firewall and sys-net, same error.
If I use fedora template I get /etc missing dir.
Options error: --up script fails with ‘/etc/openvpn/update-resolv-conf’: No such file or directory (errno=2)
In debian I find update-resolv-conf in /etc/openvpn
Troubleshooting
From 1cho1ce
Connections should be manually tested with a command like sudo openvpn --cd /rw/config/vpn --config vpn-client.conf --auth-user-pass userpassword.txt before the script ‘install’ step. This is a good idea because it shows whether or not the basic link is working before Qubes-specific scripts become a factor.
I don’t make basic connection. Ok, if i ping I get response:
ping qubes-os.org
PING qubes-os.org (188.114.97.0) 56(84) bytes of data.
64 bytes from 188.114.97.0 (188.114.97.0): icmp_seq=1 ttl=57 time=5.71 ms
64 bytes from 188.114.97.0 (188.114.97.0): icmp_seq=2 ttl=57 time=7.22 ms
64 bytes from 188.114.97.0 (188.114.97.0): icmp_seq=3 ttl=57 time=5.99 ms
^C
— qubes-os.org ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
and
-- No entries --
I strictly followed Set up a ProxyVM as a VPN gateway using iptables and CLI scripts for 4.1. I don’t use any custom scripts I’m not advanced.
For 4.2 I have tried many things but seems like I cannot get connection before scripts…
I tried again
How can I better troubleshoot? Seems like I’m missing something obvious
Are you sure that your VPN server is working and your VPN client config is correct?
Or maybe you have some firewall blocking the the connection outside of Qubes OS?
I use Mullvad, which worked on 4.1. I don’t change config file unless it’s advised.
Old config:
client
dev tun
resolv-retry infinite
nobind
persist-key
persist-tun
verb 3
remote-cert-tls server
ping 10
ping-restart 60
sndbuf xxxxxx
rcvbuf xxxxxx
cipher AES-256-CBC
tls-cipher TLS-DHE-RSA-WITH-AES-256-GCM-SHA384:TLS-DHE-RSA-WITH-AES-256-CBC-SHA
proto tcp
auth-user-pass mullvad_userpass.txt
ca mullvad_ca.crt
tun-ipv6
script-security 2
up ‘qubes-vpn-handler.sh up’ #added by me
down ‘qubes-vpn-handler.sh down’ #added by me
redirect-gateway def1 #added by me
remote-random
remote ip xxx
New config:
client
dev tun
nobind
persist-key
persist-tun
verb 3
ping 10
ping-restart 60
sndbuf xxxxxx
rcvbuf xxxxxx
cipher AES-256-GCM
proto udp
ca mullvad_ca.crt
tun-ipv6
script-security 2
up /etc/openvpn/update-resolv-conf
down /etc/openvpn/update-resolv-conf
fast-io
remote-random
IP xxx
Unlikely, unless I’m compromised which is possible but then someone is really wasting their time and money on me.
Can you try to connect using TCP as in old config?
user@aVPN:~$ sudo openvpn --cd /rw/config/vpn --config vpn-client.conf --auth-user-pass userpassword.txt
2024-04-05 11:04:24 Note: option tun-ipv6 is ignored because modern operating systems do not need special IPv6 tun handling anymore.
2024-04-05 11:04:24 Note: Kernel support for ovpn-dco missing, disabling data channel offload.
2024-04-05 11:04:24 WARNING: file ‘userpassword.txt’ is group or others accessible
2024-04-05 11:04:24 OpenVPN 2.6.3 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] [DCO]
2024-04-05 11:04:24 library versions: OpenSSL 3.0.11 19 Sep 2023, LZO 2.10
2024-04-05 11:04:24 DCO version: N/A
2024-04-05 11:04:24 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2024-04-05 11:04:24 NOTE: --fast-io is disabled since we are not using UDP
2024-04-05 11:04:24 TCP/UDP: Preserving recently used remote address: [AF_INET]xxx
2024-04-05 11:04:24 Socket Buffers: R=[xxxxxx->xxxxxx] S=[xxxxx->xxxxx]
2024-04-05 11:04:24 Attempting to establish TCP connection with [AF_INET]IPxxx:1302
2024-04-05 11:04:24 TCP: connect to [AF_INET]IPxxx:1302 failed: Connection refused
2024-04-05 11:04:24 SIGUSR1[connection failed(soft),connection-failed] received, process restarting
2024-04-05 11:04:24 Restart pause, 1 second(s)
2024-04-05 11:05:18 Restart pause, 8 second(s)
^C2024-04-05 11:05:24 SIGINT[hard,init_instance] received, process exiting
changed something, but still ‘connection refused’
1302 is a UDP port. Mullvad supports 80, 443 and 1401 for TCP. Replace the port with one of these and try again.
Thanks, that’s it. Why doesn’t UDP work? I’ll edit first post
Not sure, there could be several reasons. Your network could be blocking the UDP packets from going to the server.
Mullvad uses these UDP ports, if you want to try some of them and see if one might work in your situation:
53, 1194, 1195, 1196, 1197, 1300, 1301, 1302, 1303, 1400
Following this is the closest i’ve came to getting a vpn qube setup.
I’ve followed the instructions and when i reboot the qube it just keeps displaying Ready to start link. Never gets to LINK IS UP.
Any ideas what i’ve done wrong here am very new to qubes.
Did you try to manually start the VPN using openvpn command as stated in the guide to check that it works?
  • Connections should be manually tested with a command like sudo openvpn --cd /rw/config/vpn --config vpn-client.conf --auth-user-pass userpassword.txt before the script ‘install’ step. This is a good idea because it shows whether or not the basic link is working before Qubes-specific scripts become a factor.
