Thanks @adw … I’ll get on it in the next days! Still doing my other “homework” (VPN/Tor/Whonix etc)
Hello. I have been using Qubes 4.0.4 for a long time on my Thinkpad T430s with 3320M processor, everything is working perfectly, where should I send the hcl?
I recently switched to the beta 4.1 rc version, everything also works perfectly for me there, except for only the keyboard layout, which I created a theme about (4.1 layout does not switch), but I do not think that this is a very serious problem. I can also provide hcl with this version of Qubes.
I have a friend using Qubes on a lenovo g505s laptop, which is completely AMD and has 16 GB of memory, according to his statement, he has 4.0.4 and 4.1 beta working well, I could ask him to provide it hcl
Change: I decided that it was necessary to determine my choice of the t430s model, maybe it will be important for someone when choosing.
The T430s differs from the T430 in its dimensions, the T430 is much lighter and more compact, just as I know it comes with a new keyboard. And at release, the T430s was much cheaper than the T430.
One thing I don’t like about the T430s is that if you want to install coreboot there you may have problems with the chip and you have to re-solder it in order to install coreboot, it can be very difficult for an inexperienced person in these matters.
This category.
I can also provide hcl with [R4.1] version of Qubes.
Yes please. You can post both in one new thread at the HCL Reports category.
That would be great!
HP Elitebooks up to generation 5 work well with Qubes 4.0, and generation 6, that has the ax200 wifi chip, is supported with Qubes 4.1
Unfortunately this is not enough information, see the first post.
@Sven would it be better to separate the Qubes certified hardware list and the “just works” list? Currently, the second list contains the first one. If something is changed in the first list, you would have to edit the second one.
Instead, I suggest to add a link to certified hardware in the beginning of the post and then proceed to list the “just works” hardware without the certified machines. Something like this:
That’s alright, I just thought, if someone searched for “Elitebook” it may be encouraging for them to find this little info
I don’t see any advantage for the users. Quite the opposite, the current list is a mix of two different things: official and unofficial recommendations. I suggest to link to the official recommendations on top, so the users are not confused and the whole thing is better organized…
The certified hardware page is linked with each entry that is certified. All links to the “community-recommended” list from the Qubes OS website are part of a list that begins with the certified hardware.
I don’t see any way this is confusing or not well organized. I do see that removing PrivacyBeast and NitroPad would make the Librem like the only option on the list offering attestation. I don’t want that. I feel conflicted about including them as it stands (they are likely to create issues down the road and this needs to be tightly monitored).
Fool me once, …
In my opinion, it creates unnecessary clutter in the list.
This is a good thing. But not everyone comes to that page from the Qubes OS website.
I disagree and actually see it the other way around. Currently, Librem 14 is on top of the certified hardware, whereas I suggest to put it below it. I don’t understand how such change would make Librem look like the only option. To me, it looks like that now.
Just a reminder, this laptop has to be flashed with Coreboot first in order to work with Qubes. It does work well but should be included in the large HCL. ![]()
Let’s table this discussion until I transformed the list into a proper markup table (next 2-3 days max, probably earlier). I have some ideas how to make it less cluttered too. Then if you still see an issue we can reevaluate. Discussing the current form is wasted energy. OK?
FYI, I shared the “just works” list in the Qubes subreddit (because people ask for hardware recommendations there all the time):
It appears that some users have started replying with computer models in the comments, but it’s unclear why. I’m not sure if they’re trying to suggest additions to the list or what. (One of them is already on the list, so maybe not.) Anyway, just thought I’d let you know.
Hi. There is no reason to use 4.0.4 anymore.
x220 works good with Qubes 4.1 from daily builds and lastest heads firmware.
If anyone need I can report freshly HCL
The reason to use 4.0 is that 4.1 is still in beta, and if you care about stability and security you should use the stable version.
This would be very helpful, since soon™ 4.1 will become the main version.
There is, as @flover says, every reason to use 4.0, and not to use
4.1, at the moment.
4.1 is in beta, and suitable for testing, but no more.
As to generating hcl reports, I think this would better be done when we
have an rc, perhaps rc2. (And best of all, when 4.1 is released.)
Otherwise, Sven will be sent reports from different stages of the
release, and unless the old ones are pruned out, the situation may
become hard to work with for users.
My opinion.
Is there a possibility of regressions concerning the HCL report? I expected that if a device works well with 4.1-beta, it should also work well with 4.1-final, no?
