i am trying to do a thing.
For this i need qvm-copy-to-vm or qvm-move-to-vm from domUs to other domUs.
How would one set up the qubes.filecopy policy to do this without the dialog from dom0?
Also: Is there a possibility to do this with dispVMs from a specific template?
I tried a few different versions that seemed logical to me but was not able to get it to work.
As a last resort i would use something like this
Thanks for your help!
In 4.1, you would add this to dom0’s /etc/qubes/policy.d/30-user.policy:
qubes.Filecopy * srcvm destvm allow
In 4.0, if I remember correctly, you would add this to dom0’s /etc/qubes-rpc/policy/qubes.Filecopy (or create it if it doesn’t exist):
srcvm destvm allow
In srcvm, you can then run qvm-copy-to-vm destvm file1 file2 without a prompt.
Thank you for your help!
srcvm destvm allow
I have found the issue: This line has to be the first, otherwise the $any $any ask line is used.
