system.journal is the most recent one.
total 24576
-rw-r-----+ 1 root 190 16777216 Jan 15 2024 system.journal
-rw-r-----+ 1 root 190 8388608 Jan 15 2024 user-1000.journal
drwxr-sr-x+ 1 root 190 62 Jan 15 2024 .
drwxr-sr-x+ 1 root 190 64 Jan 15 2024 ..
Xen logs has the following
[2024-01-14 13:01:52] Logfile Opened
[2024-01-14 13:01:52] (XEN) Built-in command line: ept=exec-sp spec-ctrl=unpriv-mmio
[2024-01-14 13:01:52] Xen 4.17.2
[2024-01-14 13:01:52] (XEN) Xen version 4.17.2 (mockbuild@[unknown]) (gcc (GCC) 12.3.1 20230508 (Red Hat 12.3.1-1)) debug=n Tue Nov 14 00:00:00 UTC 2023
[2024-01-14 13:01:52] (XEN) Latest ChangeSet:
[2024-01-14 13:01:52] (XEN) Bootloader: GRUB 2.06
[2024-01-14 13:01:52] (XEN) Command line: placeholder console=none dom0_mem=min:1024M dom0_mem=max:4096M ucode=scan smt=off gnttab_max_frames=2048 gnttab_max_maptrack_frames=4096 no-real-mode edd=off
[2024-01-14 13:01:52] (XEN) Xen image load base address: 0x9de00000
[2024-01-14 13:01:52] (XEN) Video information:
[2024-01-14 13:01:52] (XEN) VGA is graphics mode 2560x1440, 32 bpp
[2024-01-14 13:01:52] (XEN) Disc information:
[2024-01-14 13:01:52] (XEN) Found 0 MBR signatures
[2024-01-14 13:01:52] (XEN) Found 5 EDD information structures
[2024-01-14 13:01:52] (XEN) Enabling Supervisor Shadow Stacks
[2024-01-14 13:01:52] (XEN) EFI RAM map:
[2024-01-14 13:01:52] (XEN) [0000000000000000, 000000000009ffff] (usable)
[2024-01-14 13:01:52] (XEN) [00000000000a0000, 00000000000fffff] (reserved)
[2024-01-14 13:01:52] (XEN) [0000000000100000, 0000000009e01fff] (usable)
[2024-01-14 13:01:52] (XEN) [0000000009e02000, 0000000009ffffff] (reserved)
[2024-01-14 13:01:52] (XEN) [000000000a000000, 000000000a1fffff] (usable)
[2024-01-14 13:01:52] (XEN) [000000000a200000, 000000000a20ffff] (ACPI NVS)
[2024-01-14 13:01:52] (XEN) [000000000a210000, 000000000affffff] (usable)
[2024-01-14 13:01:52] (XEN) [000000000b000000, 000000000b020fff] (reserved)
[2024-01-14 13:01:52] (XEN) [000000000b021000, 000000009fda0fff] (usable)
[2024-01-14 13:01:52] (XEN) [000000009fda1000, 00000000a5da0fff] (reserved)
[2024-01-14 13:01:52] (XEN) [00000000a5da1000, 00000000a5e50fff] (ACPI data)
[2024-01-14 13:01:52] (XEN) [00000000a5e51000, 00000000a7e50fff] (ACPI NVS)
[2024-01-14 13:01:52] (XEN) [00000000a7e51000, 00000000a9ffefff] (reserved)
[2024-01-14 13:01:52] (XEN) [00000000a9fff000, 00000000abffafff] (usable)
[2024-01-14 13:01:52] (XEN) [00000000abffb000, 00000000acffffff] (reserved)
[2024-01-14 13:01:52] (XEN) [00000000ad7f3000, 00000000afffffff] (reserved)
[2024-01-14 13:01:52] (XEN) [00000000f0000000, 00000000f7ffffff] (reserved)
[2024-01-14 13:01:52] (XEN) [00000000fd000000, 00000000ffffffff] (reserved)
[2024-01-14 13:01:52] (XEN) [0000000100000000, 0000002027ffffff] (usable)
[2024-01-14 13:01:52] (XEN) [0000002028000000, 0000002047ffffff] (reserved)
[2024-01-14 13:01:52] (XEN) [000000204eec0000, 00000020701fffff] (reserved)
[2024-01-14 13:01:52] (XEN) [000000fd00000000, 000000ffffffffff] (reserved)
[2024-01-14 13:01:52] (XEN) ACPI: RSDP A7E38014, 0024 (r2 ALASKA)
[2024-01-14 13:01:52] (XEN) ACPI: XSDT A7E37728, 0134 (r1 ALASKA A M I 1072009 AMI 1000013)
[2024-01-14 13:01:52] (XEN) ACPI: FACP A5E47000, 0114 (r6 ALASKA A M I 1072009 AMI 10013)
[2024-01-14 13:01:52] (XEN) ACPI: DSDT A5DD6000, 30E8A (r2 ALASKA A M I 1072009 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: FACS A7E35000, 0040
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E49000, 7BEC (r2 AMD Splinter 2 MSFT 5000000)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E48000, 03F1 (r2 ALASKA CPUSSDT 1072009 AMI 1072009)
[2024-01-14 13:01:52] (XEN) ACPI: FIDT A5E3E000, 009C (r1 ALASKA A M I 1072009 AMI 10013)
[2024-01-14 13:01:52] (XEN) ACPI: MCFG A5E3D000, 003C (r1 ALASKA A M I 1072009 MSFT 10013)
[2024-01-14 13:01:52] (XEN) ACPI: HPET A5E3C000, 0038 (r1 ALASKA A M I 1072009 AMI 5)
[2024-01-14 13:01:52] (XEN) ACPI: WDRT A5E3B000, 0047 (r1 ALASKA A M I 1072009 AMI 5)
[2024-01-14 13:01:52] (XEN) ACPI: UEFI A77E3000, 0048 (r1 ALASKA A M I 1072009 AMI 1000013)
[2024-01-14 13:01:52] (XEN) ACPI: FPDT A5E3A000, 0044 (r1 ALASKA A M I 1072009 AMI 1000013)
[2024-01-14 13:01:52] (XEN) ACPI: VFCT A5E2F000, AE84 (r1 ALASKA A M I 1 AMD 31504F47)
[2024-01-14 13:01:52] (XEN) ACPI: BGRT A5E2E000, 0038 (r1 ALASKA A M I 1072009 AMI 10013)
[2024-01-14 13:01:52] (XEN) ACPI: TPM2 A5E2D000, 004C (r4 ALASKA A M I 1 AMI 0)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E23000, 9BAE (r2 AMD AmdTable 1 AMD 1)
[2024-01-14 13:01:52] (XEN) ACPI: CRAT A5E21000, 1D28 (r1 AMD AmdTable 1 AMD 1)
[2024-01-14 13:01:52] (XEN) ACPI: CDIT A5E20000, 0029 (r1 AMD AmdTable 1 AMD 1)
[2024-01-14 13:01:52] (XEN) ACPI: BGRT A5E1F000, 0038 (r1 ALASKA A M I 1072009 AMI 10013)
[2024-01-14 13:01:52] (XEN) ACPI: BGRT A5E1E000, 0038 (r1 ALASKA A M I 1072009 AMI 10013)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E1C000, 15B0 (r2 AMD CPMDFIG2 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E19000, 29D4 (r2 AMD CDFAAIG2 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E18000, 076F (r2 AMD CPMDFDG1 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E0F000, 8EB0 (r2 AMD CPMCMN 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E0C000, 22E2 (r2 AMD AOD 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: WSMT A5E0B000, 0028 (r1 ALASKA A M I 1072009 AMI 10013)
[2024-01-14 13:01:52] (XEN) ACPI: APIC A5E0A000, 015E (r5 ALASKA A M I 1072009 AMI 10013)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E09000, 0575 (r2 AMD EXTGPP00 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E08000, 04CD (r2 AMD GPIO 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E07000, 0696 (r2 AMD USB 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: IVRS A5E46000, 00D0 (r2 AMD AmdTable 1 AMD 1)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E45000, 04E0 (r2 AMD MEMTOOL0 2 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E44000, 090B (r2 AMD CPMMSOSC 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E43000, 045C (r2 AMD AMDWOV 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E41000, 1026 (r2 AMD CPMACPV4 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E40000, 0085 (r2 AMD AmdTable 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) ACPI: SSDT A5E3F000, 00D8 (r2 AMD AmdTable 1 INTL 20200717)
[2024-01-14 13:01:52] (XEN) System RAM: 130203MB (133327928kB)
[2024-01-14 13:01:52] (XEN) Domain heap initialised
[2024-01-14 13:01:52] (XEN) ACPI: 32/64X FACS address mismatch in FADT - a7e35000/0000000000000000, using 32
[2024-01-14 13:01:52] (XEN) IOAPIC[0]: apic_id 32, version 33, address 0xfec00000, GSI 0-23
[2024-01-14 13:01:52] (XEN) IOAPIC[1]: apic_id 33, version 33, address 0xfec01000, GSI 24-55
[2024-01-14 13:01:52] (XEN) AMD-Vi: IOMMU Extended Features:
[2024-01-14 13:01:52] (XEN) - Peripheral Page Service Request
[2024-01-14 13:01:52] (XEN) - NX bit
[2024-01-14 13:01:52] (XEN) - Guest APIC Physical Processor Interrupt
[2024-01-14 13:01:52] (XEN) - Invalidate All Command
[2024-01-14 13:01:52] (XEN) - Performance Counters
[2024-01-14 13:01:52] (XEN) - Host Address Translation Size: 0x2
[2024-01-14 13:01:52] (XEN) - Guest Address Translation Size: 0
[2024-01-14 13:01:52] (XEN) - Guest CR3 Root Table Level: 0x1
[2024-01-14 13:01:52] (XEN) - Maximum PASID: 0xf
[2024-01-14 13:01:52] (XEN) - SMI Filter Register: 0x1
[2024-01-14 13:01:52] (XEN) - SMI Filter Register Count: 0x1
[2024-01-14 13:01:52] (XEN) - Guest Virtual APIC Modes: 0x1
[2024-01-14 13:01:52] (XEN) - Dual PPR Log: 0x2
[2024-01-14 13:01:52] (XEN) - Dual Event Log: 0x2
[2024-01-14 13:01:52] (XEN) - Secure ATS
[2024-01-14 13:01:52] (XEN) - User / Supervisor Page Protection
[2024-01-14 13:01:52] (XEN) - Device Table Segmentation: 0x3
[2024-01-14 13:01:52] (XEN) - PPR Log Overflow Early Warning
[2024-01-14 13:01:52] (XEN) - PPR Automatic Response
[2024-01-14 13:01:52] (XEN) - Memory Access Routing and Control: 0x1
[2024-01-14 13:01:52] (XEN) - Block StopMark Message
[2024-01-14 13:01:52] (XEN) - Performance Optimization
[2024-01-14 13:01:52] (XEN) - MSI Capability MMIO Access
[2024-01-14 13:01:52] (XEN) - Guest I/O Protection
[2024-01-14 13:01:52] (XEN) - Enhanced PPR Handling
[2024-01-14 13:01:52] (XEN) - Invalidate IOTLB Type
[2024-01-14 13:01:52] (XEN) - VM Table Size: 0x2
[2024-01-14 13:01:52] (XEN) - Guest Access Bit Update Disable
[2024-01-14 13:01:52] (XEN) Switched to APIC driver x2apic_phys
[2024-01-14 13:01:52] (XEN) CPU0: 3000 ... 4500 MHz
[2024-01-14 13:01:52] (XEN) xstate: size: 0x988 and states: 0x2e7
[2024-01-14 13:01:52] (XEN) Vulnerable to SRSO, without suitable microcode to mitigate
[2024-01-14 13:01:52] (XEN) Speculative mitigation facilities:
[2024-01-14 13:01:52] (XEN) Hardware hints: STIBP_ALWAYS IBRS_FAST IBRS_SAME_MODE BTC_NO IBPB_RET
[2024-01-14 13:01:52] (XEN) Hardware features: IBPB IBRS STIBP SSBD PSFD L1D_FLUSH
[2024-01-14 13:01:52] (XEN) Compiled-in support: INDIRECT_THUNK
[2024-01-14 13:01:52] (XEN) Xen settings: BTI-Thunk JMP, SPEC_CTRL: IBRS+ STIBP+ SSBD- PSFD-, Other: IBPB-ctxt BRANCH_HARDEN
[2024-01-14 13:01:52] (XEN) Support for HVM VMs: MSR_SPEC_CTRL MSR_VIRT_SPEC_CTRL RSB
[2024-01-14 13:01:52] (XEN) Support for PV VMs: None
[2024-01-14 13:01:52] (XEN) XPTI (64-bit PV only): Dom0 disabled, DomU disabled (without PCID)
[2024-01-14 13:01:52] (XEN) PV L1TF shadowing: Dom0 disabled, DomU disabled
[2024-01-14 13:01:52] (XEN) Using scheduler: SMP Credit Scheduler rev2 (credit2)
[2024-01-14 13:01:52] (XEN) Initializing Credit2 scheduler
[2024-01-14 13:01:52] (XEN) Platform timer is 14.318MHz HPET
[2024-01-14 13:01:52] (XEN) Detected 4499.974 MHz processor.
[2024-01-14 13:01:52] (XEN) AMD-Vi: IOMMU 0 Enabled.
[2024-01-14 13:01:52] (XEN) I/O virtualisation enabled
[2024-01-14 13:01:52] (XEN) - Dom0 mode: Relaxed
[2024-01-14 13:01:52] (XEN) Interrupt remapping enabled
[2024-01-14 13:01:52] (XEN) Enabled directed EOI with ioapic_ack_old on!
[2024-01-14 13:01:52] (XEN) Enabling APIC mode: Physical. Using 2 I/O APICs
[2024-01-14 13:01:52] (XEN) ENABLING IO-APIC IRQs
[2024-01-14 13:01:52] (XEN) -> Using old ACK method
[2024-01-14 13:01:52] (XEN) Allocated console ring of 64 KiB.
[2024-01-14 13:01:52] (XEN) HVM: ASIDs enabled.
[2024-01-14 13:01:52] (XEN) SVM: Supported advanced features:
[2024-01-14 13:01:52] (XEN) - Nested Page Tables (NPT)
[2024-01-14 13:01:52] (XEN) - Last Branch Record (LBR) Virtualisation
[2024-01-14 13:01:52] (XEN) - Next-RIP Saved on #VMEXIT
[2024-01-14 13:01:52] (XEN) - VMCB Clean Bits
[2024-01-14 13:01:52] (XEN) - DecodeAssists
[2024-01-14 13:01:52] (XEN) - Virtual VMLOAD/VMSAVE
[2024-01-14 13:01:52] (XEN) - Virtual GIF
[2024-01-14 13:01:52] (XEN) - Pause-Intercept Filter
[2024-01-14 13:01:52] (XEN) - Pause-Intercept Filter Threshold
[2024-01-14 13:01:52] (XEN) - TSC Rate MSR
[2024-01-14 13:01:52] (XEN) - NPT Supervisor Shadow Stack
[2024-01-14 13:01:52] (XEN) - MSR_SPEC_CTRL virtualisation
[2024-01-14 13:01:52] (XEN) HVM: SVM enabled
[2024-01-14 13:01:52] (XEN) HVM: Hardware Assisted Paging (HAP) detected
[2024-01-14 13:01:52] (XEN) HVM: HAP page sizes: 4kB, 2MB, 1GB
[2024-01-14 13:01:52] (XEN) Brought up 16 CPUs
[2024-01-14 13:01:52] (XEN) Scheduling granularity: cpu, 1 CPU per sched-resource
[2024-01-14 13:01:52] (XEN) xenoprof: Initialization failed. AMD processor family 25 is not supported
[2024-01-14 13:01:52] (XEN) Dom0 has maximum 1304 PIRQs
[2024-01-14 13:01:52] (XEN) Xen kernel: 64-bit, lsb
[2024-01-14 13:01:52] (XEN) Dom0 kernel: 64-bit, PAE, lsb, paddr 0x1000000 -> 0x5000000
[2024-01-14 13:01:52] (XEN) PHYSICAL MEMORY ARRANGEMENT:
[2024-01-14 13:01:52] (XEN) Dom0 alloc.: 0000001fc0000000->0000001fc8000000 (1001962 pages to be allocated)
[2024-01-14 13:01:52] (XEN) Init. ramdisk: 00000020249ea000->0000002027fff794
[2024-01-14 13:01:52] (XEN) VIRTUAL MEMORY ARRANGEMENT:
[2024-01-14 13:01:52] (XEN) Loaded kernel: ffffffff81000000->ffffffff85000000
[2024-01-14 13:01:52] (XEN) Phys-Mach map: 0000008000000000->0000008000800000
[2024-01-14 13:01:52] (XEN) Start info: ffffffff85000000->ffffffff850004b8
[2024-01-14 13:01:52] (XEN) Page tables: ffffffff85001000->ffffffff8502e000
[2024-01-14 13:01:52] (XEN) Boot stack: ffffffff8502e000->ffffffff8502f000
[2024-01-14 13:01:52] (XEN) TOTAL: ffffffff80000000->ffffffff85400000
[2024-01-14 13:01:52] (XEN) ENTRY ADDRESS: ffffffff834f91c0
[2024-01-14 13:01:52] (XEN) Dom0 has maximum 16 VCPUs
[2024-01-14 13:01:52] (XEN) Initial low memory virq threshold set at 0x4000 pages.
[2024-01-14 13:01:52] (XEN) Scrubbing Free RAM in background
[2024-01-14 13:01:52] (XEN) Std. Loglevel: Errors and warnings
[2024-01-14 13:01:52] (XEN) Guest Loglevel: Nothing (Rate-limited: Errors and warnings)
[2024-01-14 13:01:52] (XEN) *** Serial input to DOM0 (type 'CTRL-a' three times to switch input)
[2024-01-14 13:01:52] (XEN) Freed 644kB init memory
