That works, disabling autostart works. So, the cause of it is sys-net with PCI device attaching is crashing the dom0?
On the side note, does rebooting/shutting down Qubes OS in the dom0 takes some time? & dom0 by default does not have internet access right? I’m pretty new to Qubes OS.
It could be sys-net or sys-usb.
You can try starting them after you boot into dom0 and see if it’ll cause the system to crash. Then you can figure out which PCI device is causing it.
You can try to use kernel-latest in case this bug was fixed there and it won’t crash your system anymore.
It shouldn’t take too much time. You can check the logs to see which service is blocking the reboot until it times out.
Yes.
