We have published Qubes Security Bulletin (QSB) 106: Information disclosure through uninitialized memory in libxl. The text of this QSB and its accompanying cryptographic signatures are reproduced below, followed by a general explanation of this announcement and authentication instructions.
Qubes Security Bulletin 106
---===[ Qubes Security Bulletin 106 ]===---
2024-11-12
(XSA-464)
Changelog
2024-11-12: Original QSB
2024-11-29: Revise language
User action
Continue to update normally [1] in order to receive the security updates
described in the "Patching" section below. No other user action is
required in response to this QSB.
Summary
On 2024-11-12, the Xen Project published XSA-464, "libxl leaks data to PVH
guests via ACPI tables" (CVE-2024-45819) [3]:
| PVH guests have their ACPI tables constructed by the toolstack. The
| construction involves building the tables in local memory, which are
| then copied into guest memory. While actually used parts of the local
| memory are filled in correctly, excess space that is being allocated is
| left with its prior contents.
Qubes calls libxl via libvirtd. The memory that is not fully initialized
is allocated via malloc. So, the prior content that is leaked to a PVH
qube might be anything that has been previously allocated and
subsequently freed in the libvirtd process.
Impact
The leaked memory usually doesn't contain important secrets, [4] but it
can reveal various information about other qubes and the host system
that would not otherwise be available to a malicious qube. In
particular, the following types of information might be present in
libvirtd's memory:
Information about other qubes:
- Name
- UUID
- kernel version
- kernel cmdline
- IP/MAC addresses of virtual network devices (but not from physical
devices) [5]
- Assigned PCI devices
Information about the host system:
- Total system memory
- Available PCI devices
- DMI/SYSBIOS information (serial number as reported by firmware, RAM
DIMM product number, etc.)
These lists are not intended to be exhaustive. For example, they don't
include less-interesting qube settings like the assigned audio qube, but
they should cover all the important categories.
Note that a malicious qube has very little control over the information
leaked in the uninitialized memory to which it is exposed. [6]
Additionally, the leak happens only once per qube boot, so for a decent
chance of being exposed to interesting information, a malicious qube may
have to wait a long time in order to be exposed to a significant number
of normal qube boots. Alternatively, a malicious qube could attempt to
provoke boots of disposable qubes it can control (for example, via
qubes.VMShell) or shut itself down and hope to be rebooted by the user
or a qrexec call. However, both of these methods would result in unusual
system activity that users would easily notice.
Affected systems
All supported version of Qubes OS are affected.
Only qubes in PVH mode are affected. In the default configuration, this
includes all qubes except for sys-net and sys-usb.
Patching
The following packages contain security updates that address the
vulnerabilities described in this bulletin:
For Qubes 4.2, in dom0:
- Xen packages, version 4.17.5-4
by the community. [2] Once available, the packages are to be installed
via the Qubes Update tool or its command-line equivalents. [1]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen binaries.
Credits
See the original Xen Security Advisory.
References
[1] https://www.qubes-os.org/doc/how-to-update/
[2] https://www.qubes-os.org/doc/testing/
[3] https://xenbits.xen.org/xsa/advisory-464.html
[4] The leaked memory could reveal the ASLR secret of the libvirtd
process, but this is only useful when the attacker has knowledge of
a memory vulnerability in libvirtd/libxl that is reachable in Qubes
OS. Additionally, in an unusual custom setup, a user could have
included a secret in some of the leaked information about other
qubes.
[5] Unless the user actively configures something else for a qube, its
IP addresses is based on its qid/dispid (a number from 0 to 10000),
and the MAC addresses is the same for all qubes.
[6] When starting a disposable qube via qrexec, a malicious qube could
try to time the start in its favor.
The Qubes Security Team
Source: qsb-106-2024.txt
Marek Marczykowski-Górecki’s PGP signature
-----BEGIN PGP SIGNATURE-----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=+ah8
-----END PGP SIGNATURE-----
Source: qsb-106-2024.txt.sig.marmarek
Simon Gaiser (aka HW42)’s PGP signature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=rMw+
Source: qsb-106-2024.txt.sig.simon
What is the purpose of this announcement?
The purpose of this announcement is to inform the Qubes community that a new Qubes security bulletin (QSB) has been published.
What is a Qubes security bulletin (QSB)?
A Qubes security bulletin (QSB) is a security announcement issued by the Qubes security team. A QSB typically provides a summary and impact analysis of one or more recently-discovered software vulnerabilities, including details about patching to address them. For a list of all QSBs, see Qubes security bulletins (QSBs).
Why should I care about QSBs?
QSBs tell you what actions you must take in order to protect yourself from recently-discovered security vulnerabilities. In most cases, security vulnerabilities are addressed by updating normally. However, in some cases, special user action is required. In all cases, the required actions are detailed in QSBs.
What are the PGP signatures that accompany QSBs?
A PGP signature is a cryptographic digital signature made in accordance with the OpenPGP standard. PGP signatures can be cryptographically verified with programs like GNU Privacy Guard (GPG). The Qubes security team cryptographically signs all QSBs so that Qubes users have a reliable way to check whether QSBs are genuine. The only way to be certain that a QSB is authentic is by verifying its PGP signatures.
Why should I care whether a QSB is authentic?
A forged QSB could deceive you into taking actions that adversely affect the security of your Qubes OS system, such as installing malware or making configuration changes that render your system vulnerable to attack. Falsified QSBs could sow fear, uncertainty, and doubt about the security of Qubes OS or the status of the Qubes OS Project.
How do I verify the PGP signatures on a QSB?
The following command-line instructions assume a Linux system with git and gpg installed. (For Windows and Mac options, see OpenPGP software.)
Obtain the Qubes Master Signing Key (QMSK), e.g.:
$ gpg --fetch-keys https://keys.qubes-os.org/keys/qubes-master-signing-key.asc gpg: directory '/home/user/.gnupg' created gpg: keybox '/home/user/.gnupg/pubring.kbx' created gpg: requesting key from 'https://keys.qubes-os.org/keys/qubes-master-signing-key.asc' gpg: /home/user/.gnupg/trustdb.gpg: trustdb created gpg: key DDFA1A3E36879494: public key "Qubes Master Signing Key" imported gpg: Total number processed: 1 gpg: imported: 1(For more ways to obtain the QMSK, see How to import and authenticate the Qubes Master Signing Key.)
View the fingerprint of the PGP key you just imported. (Note:
gpg>indicates a prompt inside of the GnuPG program. Type what appears after it when prompted.)$ gpg --edit-key 0x427F11FD0FAA4B080123F01CDDFA1A3E36879494 gpg (GnuPG) 2.2.27; Copyright (C) 2021 Free Software Foundation, Inc. This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: unknown validity: unknown [ unknown] (1). Qubes Master Signing Key gpg> fpr pub rsa4096/DDFA1A3E36879494 2010-04-01 Qubes Master Signing Key Primary key fingerprint: 427F 11FD 0FAA 4B08 0123 F01C DDFA 1A3E 3687 9494 -
Important: At this point, you still don’t know whether the key you just imported is the genuine QMSK or a forgery. In order for this entire procedure to provide meaningful security benefits, you must authenticate the QMSK out-of-band. Do not skip this step! The standard method is to obtain the QMSK fingerprint from multiple independent sources in several different ways and check to see whether they match the key you just imported. For more information, see How to import and authenticate the Qubes Master Signing Key.
Tip: After you have authenticated the QMSK out-of-band to your satisfaction, record the QMSK fingerprint in a safe place (or several) so that you don’t have to repeat this step in the future.
Once you are satisfied that you have the genuine QMSK, set its trust level to 5 (“ultimate”), then quit GnuPG with
q.gpg> trust pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: unknown validity: unknown [ unknown] (1). Qubes Master Signing Key Please decide how far you trust this user to correctly verify other users' keys (by looking at passports, checking fingerprints from different sources, etc.) 1 = I don't know or won't say 2 = I do NOT trust 3 = I trust marginally 4 = I trust fully 5 = I trust ultimately m = back to the main menu Your decision? 5 Do you really want to set this key to ultimate trust? (y/N) y pub rsa4096/DDFA1A3E36879494 created: 2010-04-01 expires: never usage: SC trust: ultimate validity: unknown [ unknown] (1). Qubes Master Signing Key Please note that the shown key validity is not necessarily correct unless you restart the program. gpg> q -
Use Git to clone the qubes-secpack repo.
$ git clone https://github.com/QubesOS/qubes-secpack.git Cloning into 'qubes-secpack'... remote: Enumerating objects: 4065, done. remote: Counting objects: 100% (1474/1474), done. remote: Compressing objects: 100% (742/742), done. remote: Total 4065 (delta 743), reused 1413 (delta 731), pack-reused 2591 Receiving objects: 100% (4065/4065), 1.64 MiB | 2.53 MiB/s, done. Resolving deltas: 100% (1910/1910), done. -
Import the included PGP keys. (See our PGP key policies for important information about these keys.)
$ gpg --import qubes-secpack/keys/*/* gpg: key 063938BA42CFA724: public key "Marek Marczykowski-Górecki (Qubes OS signing key)" imported gpg: qubes-secpack/keys/core-devs/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key 8C05216CE09C093C: 1 signature not checked due to a missing key gpg: key 8C05216CE09C093C: public key "HW42 (Qubes Signing Key)" imported gpg: key DA0434BC706E1FCF: public key "Simon Gaiser (Qubes OS signing key)" imported gpg: key 8CE137352A019A17: 2 signatures not checked due to missing keys gpg: key 8CE137352A019A17: public key "Andrew David Wong (Qubes Documentation Signing Key)" imported gpg: key AAA743B42FBC07A9: public key "Brennan Novak (Qubes Website & Documentation Signing)" imported gpg: key B6A0BB95CA74A5C3: public key "Joanna Rutkowska (Qubes Documentation Signing Key)" imported gpg: key F32894BE9684938A: public key "Marek Marczykowski-Górecki (Qubes Documentation Signing Key)" imported gpg: key 6E7A27B909DAFB92: public key "Hakisho Nukama (Qubes Documentation Signing Key)" imported gpg: key 485C7504F27D0A72: 1 signature not checked due to a missing key gpg: key 485C7504F27D0A72: public key "Sven Semmler (Qubes Documentation Signing Key)" imported gpg: key BB52274595B71262: public key "unman (Qubes Documentation Signing Key)" imported gpg: key DC2F3678D272F2A8: 1 signature not checked due to a missing key gpg: key DC2F3678D272F2A8: public key "Wojtek Porczyk (Qubes OS documentation signing key)" imported gpg: key FD64F4F9E9720C4D: 1 signature not checked due to a missing key gpg: key FD64F4F9E9720C4D: public key "Zrubi (Qubes Documentation Signing Key)" imported gpg: key DDFA1A3E36879494: "Qubes Master Signing Key" not changed gpg: key 1848792F9E2795E9: public key "Qubes OS Release 4 Signing Key" imported gpg: qubes-secpack/keys/release-keys/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key D655A4F21830E06A: public key "Marek Marczykowski-Górecki (Qubes security pack)" imported gpg: key ACC2602F3F48CB21: public key "Qubes OS Security Team" imported gpg: qubes-secpack/keys/security-team/retired: read error: Is a directory gpg: no valid OpenPGP data found. gpg: key 4AC18DE1112E1490: public key "Simon Gaiser (Qubes Security Pack signing key)" imported gpg: Total number processed: 17 gpg: imported: 16 gpg: unchanged: 1 gpg: marginals needed: 3 completes needed: 1 trust model: pgp gpg: depth: 0 valid: 1 signed: 6 trust: 0-, 0q, 0n, 0m, 0f, 1u gpg: depth: 1 valid: 6 signed: 0 trust: 6-, 0q, 0n, 0m, 0f, 0u -
Verify signed Git tags.
$ cd qubes-secpack/ $ git tag -v `git describe` object 266e14a6fae57c9a91362c9ac784d3a891f4d351 type commit tag marmarek_sec_266e14a6 tagger Marek Marczykowski-Górecki 1677757924 +0100 Tag for commit 266e14a6fae57c9a91362c9ac784d3a891f4d351 gpg: Signature made Thu 02 Mar 2023 03:52:04 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-Górecki (Qubes security pack)" [full]The exact output will differ, but the final line should always start with
gpg: Good signature from...followed by an appropriate key. The[full]indicates full trust, which this key inherits in virtue of being validly signed by the QMSK. -
Verify PGP signatures, e.g.:
$ cd QSBs/ $ gpg --verify qsb-087-2022.txt.sig.marmarek qsb-087-2022.txt gpg: Signature made Wed 23 Nov 2022 04:05:51 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-Górecki (Qubes security pack)" [full] $ gpg --verify qsb-087-2022.txt.sig.simon qsb-087-2022.txt gpg: Signature made Wed 23 Nov 2022 03:50:42 AM PST gpg: using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490 gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full] $ cd ../canaries/ $ gpg --verify canary-034-2023.txt.sig.marmarek canary-034-2023.txt gpg: Signature made Thu 02 Mar 2023 03:51:48 AM PST gpg: using RSA key 2D1771FE4D767EDC76B089FAD655A4F21830E06A gpg: Good signature from "Marek Marczykowski-Górecki (Qubes security pack)" [full] $ gpg --verify canary-034-2023.txt.sig.simon canary-034-2023.txt gpg: Signature made Thu 02 Mar 2023 01:47:52 AM PST gpg: using RSA key EA18E7F040C41DDAEFE9AA0F4AC18DE1112E1490 gpg: Good signature from "Simon Gaiser (Qubes Security Pack signing key)" [full]Again, the exact output will differ, but the final line of output from each
gpg --verifycommand should always start withgpg: Good signature from...followed by an appropriate key.
For this announcement (QSB-106), the commands are:
$ gpg --verify qsb-106-2024.txt.sig.marmarek qsb-106-2024.txt
$ gpg --verify qsb-106-2024.txt.sig.simon qsb-106-2024.txt
You can also verify the signatures directly from this announcement in addition to or instead of verifying the files from the qubes-secpack. Simply copy and paste the QSB-106 text into a plain text file and do the same for both signature files. Then, perform the same authentication steps as listed above, substituting the filenames above with the names of the files you just created.
This is a companion discussion topic for the original entry at https://www.qubes-os.org/news/2024/11/12/qsb-106/
