We have just published Qubes Security Bulletin (QSB) 069:
Multiple Xen and Intel issues.
The text of this QSB is reproduced below. This QSB and its accompanying
signatures will always be available in the Qubes Security Pack (qubes-secpack).
---===[ Qubes Security Bulletin 069 ]===---
2021-06-08
(XSA-373, XSA-374, XSA-375, XSA-377, INTEL-SA-00442)
User action required
Users must install the following specific packages in order to address
the issues discussed in this bulletin:
For Qubes 4.0, in dom0:
- Xen packages, version 4.8.5-34
- Linux kernel packages, versions 5.12.9-1 (for users of the "latest"
kernel flavor)
- microcode_ctl package, version 2.1-33.qubes1 (for Intel CPU users)
For Qubes 4.1, in dom0:
- Xen packages, version 4.14.1-5
- Linux kernel packages, versions 5.10.42-1, 5.12.9-1 (for users of
the "latest" kernel flavor)
by the community. [1] Once available, the packages are to be installed
via the Qubes Update Tool or its command-line equivalents. [2]
effect.
passphrase to new PCR values, as PCR18+19 will change due to the new
Xen binaries.
Summary
The following security advisories were published on 2021-06-08:
XSA-373 [3] "Inappropriate x86 IOMMU timeout detection / handling":
| IOMMUs process commands issued to them in parallel with the operation
| of the CPU(s) issuing such commands. In the current implementation in
| Xen, asynchronous notification of the completion of such commands is
| not used. Instead, the issuing CPU spin-waits for the completion of
| the most recently issued command(s). Some of these waiting loops try
| to apply a timeout to fail overly-slow commands. The course of action
| upon a perceived timeout actually being detected is inappropriate:
| - on Intel hardware guests which did not originally cause the timeout
| may be marked as crashed,
| - on AMD hardware higher layer callers would not be notified of the
| issue, making them continue as if the IOMMU operation succeeded.
XSA-374 [4] "Guest triggered use-after-free in Linux xen-netback":
| A malicious or buggy network PV frontend can force Linux netback to
| disable the interface and terminate the receive kernel thread
| associated with queue 0 in response to the frontend sending a
| malformed packet.
| Such kernel thread termination will lead to a use-after-free in Linux
| netback when the backend is destroyed, as the kernel thread associated
| with queue 0 will have already exited and thus the call to
| kthread_stop will be performed against a stale pointer.
XSA-375 [5] "Speculative Code Store Bypass":
| Modern superscalar processors may employ sophisticated decoding and
| caching of the instruction stream to improve performance. However, a
| consequence is that self-modifying code updates may not take effect
| instantly.
| Whatever the architectural guarantees, some CPUs have
| microarchitectural behaviour whereby the stale instruction stream may
| be speculatively decoded and executed.
| Speculation of this form can suffer from type confusion in registers,
| and potentially leak data.
XSA-377 [6] "x86: TSX Async Abort protections not restored after S3":
| This issue relates to the TSX Async Abort speculative security
| vulnerability. Please see https://xenbits.xen.org/xsa/advisory-305.html
| for details.
| Mitigating TAA by disabling TSX (the default and preferred option)
| requires selecting a non-default setting in MSR_TSX_CTRL. This
| setting isn't restored after S3 suspend.
INTEL-SA-00442 [7] "Intel® VT-d Advisory":
| A potential security vulnerability in some Intel® Virtualization
| Technology for Directed I/0 (VT-d) products may allow escalation of
| privilege. Intel is releasing firmware updates to mitigate this
| potential vulnerability.
Impact
XSA-373:
As the Xen Security Team explains, "A malicious guest may be able to
elevate its privileges to that of the host, cause host or guest Denial
of Service (DoS), or cause information leaks." Only a guest with a PCI
device can leverage this vulnerability, such as `sys-net` or `sys-usb`
in a default Qubes OS configuration.
XSA-374:
A malicious or buggy VM can trigger its network-providing VM to crash.
In a typical installation, the affected network-providing VM would be
`sys-firewall` or `sys-whonix`. Privilege escalation (to the
network-providing VM) and information leaks cannot be ruled out.
The issue affects only Linux kernel version 5.5 and newer. By default,
Qubes OS R4.0 uses Linux 5.4.x and is therefore not affected. However,
if the user has manually installed a newer, affected kernel version
(e.g., using the `kernel-latest-qubes-vm` package), then that
installation is affected.
XSA-375:
As explained by the Xen Security Team, "An attacker might be able to
infer the contents of arbitrary host memory, including memory assigned
to other guests."
XSA-377:
The impact is the same as XSA-305, which we explained in QSB-053 [8]:
| An attacker, which could include a malicious untrusted user process on
| a trusted guest, or an untrusted guest, can sample the content of
| recently-used memory operands and IO Port writes.
| This can include data from:
| * A previously executing context (process, or guest, or
| hypervisor/toolstack) at the same privilege level.
| * A higher privilege context (kernel, hypervisor, SMM) which
| interrupted the attacker's execution.
| Vulnerable data is that on the same physical core as the attacker.
| This includes, when hyper-threading is enabled, adjacent threads.
| An attacker cannot use this vulnerability to target specific data.
| An attack would likely require sampling over a period of time and the
| application of statistical methods to reconstruct interesting data.
INTEL-SA-00442:
As explained by Intel, "Incomplete cleanup in some Intel(R) VT-d
products may allow an authenticated user to potentially enable
escalation of privilege via local access."
Only Intel CPUs are affected.
Credits
See the original Security Advisories.
References
[1] https://www.qubes-os.org/doc/testing/
[2] https://www.qubes-os.org/doc/updating-qubes-os/
[3] https://xenbits.xen.org/xsa/advisory-373.html
[4] https://xenbits.xen.org/xsa/advisory-374.html
[5] https://xenbits.xen.org/xsa/advisory-375.html
[6] https://xenbits.xen.org/xsa/advisory-377.html
[7] https://www.intel.com/content/www/us/en/security-center/advisory/intel-sa-00442.html
[8] https://www.qubes-os.org/news/2019/11/13/qsb-053/
The Qubes Security Team
Looks like another* QSB containing not one, but two vulnerabilities (Edit: XSA-374 doesn’t concern sys-net. I wasn’t thinking straight. Excuse me while I put on my dunce hat and sit in this corner for a bit. Don’t mind the drool.) a vulnerability that particularly impacts sys-net. As noted before, because sys-net is an HVM with PCI access, it is the weak link in our systems’ security–especially because it can’t sit behind a firewall (unless external).
Sometimes I just feel like we should crowdfund development of a unikernel like Mirage to replace sys-net, if only just for ethernet connections (if you’re this worried about your security, you shouldn’t be using WiFi anyways).
XSA-337: A malicious HVM with a PCI device (such as sys-net or sys-usb
in the default Qubes OS configuration) can potentially compromise the
whole system.
