I want to share a small discovery on creating a battery threshold within Qubes OS for ThinkPad users and possible for other laptop brands. I searched on the Qubes forum and found nothing on a workaround for battery threshold, so perhaps this will be useful for others. This finding works in both ThinkPad X230 and T430, running Coreboot via Skulls and working in Qubes 4.0.4 and 4.1. Maybe this is a fluke, but I would like other users to try to see if they can replicate it.
When I first started to set up Qubes OS as my daily driver, I researched online and couldn’t find a way to install TLP to set the battery threshold without installing TLP in dom0. As I could not find any solution apart from installing in dom0, I gave up the search as I didn’t want to install anything in dom0.
The solution came when I wanted to have a backup OS in the laptops just for Zoom calls as Zoom is still a hit and miss with Qubes. I outfitted an mSATA drive on both computers and installed Linux Mint, Zoom and TLP. I have noticed that after setting the battery threshold via TLP on Mint, it carried over to Qubes. The battery threshold would only break if I were to remove the laptop’s battery physically. I would then have to restart in Mint, and then it would carry over again in Qubes.
In addition to an Ubuntu variation, I tried Fedora 35 KDE to replace Mint. It seems to have built-in battery management (perhaps from gnome?) that does not require TLP, which can be found under Advanced Power Management. Like Mint, Fedora 35’s battery threshold appears to carry over to Qubes.
I know that ThinkPads have some chip that controls the batteries. Perhaps after setting the threshold over TLP, this threshold is stored within the battery itself that carries over to Qubes? In my case, this has worked on both original and 3rd party batteries. Since TLP’s threshold is only specifically for ThinkPads, perhaps the Fedora 35’s threshold will work on other brands.
It would be interesting if any users could test this and see if this finding is correct.
What is the problem with Zoom? I mainly use Skype, but have Zoom installed on separte template and it looks like it works. Only thing I noticed is that I have to update it manually since it not has any repo.
Good to know there is a more straight forward method to set the threshold. Will try this and report back. Out of curiosity, will this work with non-ThinkPad models? Thanks everyone.
Just a little script to spare the laptop batteries which I originally wanted to publish in the guides section (Guides - Qubes OS Forum), to small for github…
Thanks so much for the clear explanation! The original battery_thresholds.sh file is located in the home folder. Once I have copied it to the /usr/local/bin folder, per your instruction, do I need to delete the one in the home folder or let it be?
If you don’t have battery settings in BIOS this means that you hardware isn’t sufficient to use it.
And there’s nothing you can do for it to work.
At /sys/class/power_supply/BAT0. I was told on the Kicksecure forum that this wasn’t possible. Do you know of a way that I could still enable charging thresholds?
This was my output: echo '50' | sudo tee sys/class/power_supply/BAT1/charge_control_end_threshold: Permission denied 50
On Qubes OS you have to do this in dom0 because it is where the battery is managed, I’m not sure why you linked the kicksecure link?
If you do not have that file /sys/class/power_supply/BAT0/charge_control_end_threshold in dom0, this is because your laptop does not support the feature.
