On Qubes I had tried it from dom0 and ran into this issue so then I tried it on Kicksecure but ran into the same issue on there.
Then you know the answer ![]()
I was hoping I was wrong and there still was a way
thanks anyway! ![]()
Related, older thread on the same subject:
That file also does not exist for me but my Asus Zenbook automatically limited the charging to 80% when I was first running Windows 11, so I think thereâs more to the story there. Possibly missing kernel modules from asus
Do you see anything in dom0 under /sys/class/power_supply? There should be âACâ or âmainsâ and at least a battery, if you have one.
Yes I have BAT0, AC0 and two directories for the two USBC ports
And nothing looking like âcharging thresholdâ controls in /sys/class/power_supply/BAT0/ ?
Nope. I am tempted to just create the file with my desired value but not sure if that will break something.
Hi, same. If you need to set battery threshold you should build kernel from source and put one fix. CONFIG_HOTPLUG_PCI_CPCI=y to config-base file. Default = n. And on many laptops (my Asus) no file for battery without it. And you should build kernel with qubes-builderv2.
Default =n for protect from attack via attach evil devices to thundrebolt port. May be your laptop havenât this port lol. This disabled only on Qubes os. All another distrs (Debian, fedora, Ubuntu) use kernel with y by default
Ok interesting. Can you link me to the documentation for building the kernel from source? Never did that for an entire OS before.
Also, did you set other options to fix other things like the keyboard backlight?
Thereâs no documentation for building just the kernel. But you can easily change whatâs being built in the example config. Instead of building the entire OS, specify that you want to build only the kernel and its components. Youâll need a Github account for this. Hereâs an example; I use it. Youâll also need to create a GPG signing key and add it to the builder. chatgpt is a great tool for this.
git:
baseurl: https://github.com
prefix: QubesOS/qubes-
branch: release4.2
maintainers:
- âKEYâ
- âKEYâ
backend-vmm:xen
debug: true
verbose: true
qubes-release: r4.2
distributions: - host-fc37
components: - builder-rpm:
packages: False
branch:main - linux-utils
-dracut - linux-kernel-latest:
url: https://github.com//qubes-linux-kernel
branch:main
timeout: 21600
host-fc37:
stages: - build:
environment:
MAKEFLAGS: â-j$(($(nproc) * 2))â
executor:
type: docker
options:
image: âqubes-builder-fedora:latestâ
clean: True
cpus: â0.000â
stages: - fetch
- prep
- build
- post
- verify
- sign:
executor:
type: local - publish:
executor:
type: local
I canât say whether your keyboard or anything else will work better. I have to compile the kernel regularly because without it, the fans are constantly running at maximum power and the laptop temperature reaches 90 degrees Celsius at idle. Effective management of cores, their frequencies, and other things is probably impossible without this option. Itâs very sad that Qubes OS is so inconvenient on many modern laptops.
