I’ve also uploaded packages for Debian-12, bookworm for 4.1.
You can build these from qubes-builder, but the packages aren’t yet
available from official repositories.
Check out the instructions at https://qubes.3isec.org/
Thanks unman for your hard work, enjoy everything you and the others do…New parrot template unman did installed just fine. With the new parrot template the apps are not launching right. If I click like “run terminal” and parrot template will start but it will not launch “run terminal”. I have to go back in and click it again then it will populate.
Also I can’t install like “terminator” or even update/upgrade…
I am getting…
Ign:1 http://HTTPS///deb.parrot.sh/
500 Unable to connect [IP: 127.0.01 8082]
Err:1 Failed to fetch http://HTTPS//
Parrot will not update from qubes manager as well. I right click on parrot template and click on update and nothing happens. Thought I would just add that.
Rolling distros - Parrot, Arch, Kali
Templates like Parrot or Kali are based on Debian testing.
To avoid breakage when updating, the core Qubes packages are on hold. This means that they will not be updated.
You can confirm this by running apt-mark showhold in the template. apt-mark unhold will remove the hold, and allow you to update the Qubes packages.
I suggest you restore the hold apt-mark hold to make sure that the Qubes packages are not removed when updating other packages.
So, while updating a template you will see that some packages cannot be upgraded because they will conflict with the Qubes packages.
Periodically, in the template, remove the hold on the Qubes packages. Update the package list with apt update and then update the Qubes packages - either manually with apt install... , or using a manager like aptitude, and selecting Qubes packages for upgrade.
Once the upgrade has been completed, put the Qubes packages back on hold, and upgrade again.
Undoubtedly a pain, but less than the pain of breaking your qubes, and having to crawl backwards to get them working again.
Then again, if you use aptitude you would be able to see what changes would be made, opt to retain the Qubes packages - always keep the Qubes packages , and avoid breakage that way. This depends on you looking to see what changes will be made and acting accordingly. Using apt-mark hold will take some pressure off.
I have to admit, i’m totally confused by what this is and what it does, I changed my sources to just https, but i’m fairly sure that isn’t the idea? searched the forum and the net for “https://HTTPS///” and didn’t come up with anything.
Scrolled further back on this post and saw about apt-cacher-ng. Am sticking with changing to https as I don’t really need this.
The repos are configured to use a caching proxy.
Any proxy has to find a way to deal with encrypted requests -
https://…
Some solutions are:
MITM - the proxy intercepts the request, sends it own https request, and
returns cached
Don’t cache https request
Rewrite the client request: http://HTTPS/// means that the request is
sent to the proxy as http, and the proxy then rewrites it to https://
This means that outbound traffic still uses https, but the proxy can see
all requests and cached the packages.
Rewriting the repository definitions is fine: sed -i s^http://HTTPS///^https://^ REPO_DEFINITION will do it.
sed is a Stream EDitor - it allows you to make changes to files.
Breaking it down:
REPO_DEFINITION - the file (or files) you want to change. -i - edits files in place. Without this the edited file will be
shown in the terminal, but the original file will not be changed. s ^TEXT^REPLACEMENT^ - Substitutes TEXT with REPLACEMENT - you can
use other delimiters
So the whole line will change the text http://HTTPS/// to https://
everywhere in the files you specify.
sed is a great tool for mass editing, and has many features.
Useful tip - If you use sed -ibk then the file will be edited in place but a backup
will be stored with suffix you specify - in this case bk
Thanks @unman, and thank you to the qubes team for creating/maintaining this great project. I used it 4 years ago, however, due to school i had to switch back to Windows. Now, 4 years later, i can use Qubes for work, school, pentesting etc. etc.!
any updates on here? i also installed unmans cacher now because i thought this would be the problem.
if i try sudo apt update i would get this back:
┌─[✗]─[user@parrot-hacking]─[~]
└──╼ $sudo apt update
Ign:1 https://deb.parrot.sh/parrot parrot InRelease
Ign:2 https://deb.qubes-os.org/r4.2/vm bookworm InRelease
Ign:3 https://deb.parrot.sh/parrot rolling-security InRelease
Err:1 https://deb.parrot.sh/parrot parrot InRelease
Invalid response from proxy: HTTP/1.0 403 CONNECT denied (ask the admin to allow HTTPS tunnels) [IP: 127.0.0.1 8082]
Err:2 https://deb.qubes-os.org/r4.2/vm bookworm InRelease
Err:3 https://deb.parrot.sh/parrot rolling-security InRelease
Reading package lists... Done
E: Failed to fetch https://deb.parrot.sh/parrot/dists/parrot/InRelease Invalid response from proxy: HTTP/1.0 403 CONNECT denied (ask the admin to allow HTTPS tunnels) [IP: 127.0.0.1 8082]
E: Failed to fetch https://deb.parrot.sh/parrot/dists/rolling-security/InRelease Invalid response from proxy: HTTP/1.0 403 CONNECT denied (ask the admin to allow HTTPS tunnels) [IP: 127.0.0.1 8082]
E: Failed to fetch https://deb.qubes-os.org/r4.2/vm/dists/bookworm/InRelease Invalid response from proxy: HTTP/1.0 403 CONNECT denied (ask the admin to allow HTTPS tunnels) [IP: 127.0.0.1 8082]
E: Some index files failed to download. They have been ignored, or old ones used instead.
i also tried kali (but not the one from unman, the community one from the template-gui) and if i would fully update it, i would get a qrexec error, so it cant start.
im using the parrot-full btw.
and cacher should be fine, because if i want to update, i can see the cacher is starting
