ok i fixed everything now and would explain what ive done so, if anyone got the same issues, he could fix it, but anyhow i still got some issues, would explain them later, heres the write up:
first, i disabled cacher again in the dom0 terminal:
cat /etc/qubes/policy.d/30-user.policy
this should put out a line like:
qubes.UpdatesProxy * @type:TemplateVM @default allow target=cacher
so i vim`d into it:
sudo vim
and commented the line out
sudo apt update got still errors so i run the command:
sudo sed -i s^http://HTTPS///^https://^ /etc/apt/sources.list.d/*
then i run in parrot sudo apt update and got an error message like:
key is stored in legacy trusted gpg keyring
what i have done were:
sudo cp -r /etc/apt/trusted.gpg ~
mv /etc/apt/trusted.gpg /etc/apt/trusted.gpg.d/
now almost everything worked, to install quassel i had to run sudo aptitude install quassel
but now my issue here:
i also installed the proton deb and run a sudo apt update.
if i want to install with apt it doesnt work
with aptitude it would work but it wants to remove these packages:
Remove the following packages:
1) python3-qubesdb [4.2.1-1+deb12u1 (<NULL>, now)]
2) qubes-core-agent [4.2.1-1+deb12u1 (now)]
3) qubes-core-agent-network-manager [4.2.1-1+deb12u1 (now)]
4) qubes-core-agent-networking [4.2.1-1+deb12u1 (now)]
5) qubes-gui-agent [4.1.27-1+deb12u1 (now)]
6) qubes-vm-dependencies [4.2.2-1+deb12u1 (<NULL>, now)]
same behavior if i want to install terminator.
is there a way to install terminator and / or protonvpn without installed gui agent etc.?
guess these are dependencies which i have to keep, if i would uninstall them, this qube wouldnt work anymore?
