Finally, I’ve written up some notes on building flavors. Don’t be put
off by the length - the actual process is straightforward and much
faster to do.
I hope they are (almost) readable and clear.
Here’s how to build a Parrot template - you can adapt this to cover just
about any case which is based on an existing template.
Parrot, like Kali, is based on Debian testing - so the first thing you
need to do is make sure you can build a bullseye template.
Set up the Qubes build environment, as set out here:
Qubes Builder | Qubes OS
If you want a configured environment there is a salt formula in GitHub - unman/shaker
In qubes-builder, run ./setup
Select 4.0
Stable
Git Clone Faster
DO NOT use Pre-build Packages - select OK without having selected an option
Build only the templates
In the Selection list choose “buster”
In the Plugins Selection, deselect builder-rpm and select builder-debian.
Get-sources - select “Yes”
Now edit the file that has been created - builder.conf:
Look for the Section headed LIST OF DIST VM'S
This is where you specify what VM will be built.
Change the line under # Enabled DISTS_VMs that says:
DISTS_VM += buster+standard TO
DISTS_VM += bullseye
Save the file
make qubes-vm
This will create a bullseye chroot, and build all the qubes packages.
Once you can build the bullseye packages, you can build Parrot.
Parrot is a “flavor” of bullseye, so you specify it like this in the builder.conf file:
bullseye+parrot
You can change the template name in the section marked TEMPLATE CONFIGURATION
TEMPLATE_LABEL += bullseye+parrot:parrot`
Add a line:
TEMPLATE_FLAVOR_DIR += +parrot:$$$$TEMPLATE_SCRIPTS/parrot
- Almost all of the necessary work is done in the
builder-debian directory.
You have to identify any changes that are needed to a standard bullseye build.
You need to set the Parrot repository.
Add the Parrot signing key.
Specify what packages you want to install in the template.
Put the Parrot signing key in the keys directory.
In the template_debian directory create a file packages_parrot.list and specify the packages to install - just one line will do:
parrot-tools-full
Create template_debian/parrot, and create a file 04_install_qubes_post.sh
This is the file that does the Parrot install - it runs after the standard 04_install_qubes.sh script.
You can copy an existing file and adapt it as you will.
In this case, we want to add the parrot key, update the repository list, and then run the install.
If you look at the file you will see that we use chroot_cmd to run commands in the chroot built earlier, and various helper scripts from distribution.sh
Because Bullseye is a testing distribution it may be that some updates would break the Qubes packages.
You can avoid this by marking the key packages with “hold”, so they wont
be replaced:
chroot_cmd apt-mark hold qubes-core-agent
chroot_cmd apt-mark hold qubes-core-agent-networking
chroot_cmd apt-mark hold qubes-gui-agent
- The only other change needed is to make sure there is enough space in the template.
The templates are created in qubes-src/linux-template-builder/prepare_image:
if [ -z "$TEMPLATE_ROOT_SIZE" ]; then
TEMPLATE_ROOT_SIZE=10G
fi
You can change this, or insert a new stanza like so:
if [ "$TEMPLATE_FLAVOR" == "parrot" ];then
TEMPLATE_ROOT_SIZE=30G
fi
fi
- Now everything is in place.
In qubes-builder, run make template, and new parrot template should (finally) appear in qubes-builder/qubes-src/linux-template-builder/rpm/noarch ready to copy in to dom0 and install.
The changes to builder-debian are in my “parrot” branch.
You can grab them like so:
cd qubes-src/builder-debian
git remote add unman https://github.com/unman/qubes-builder-debian.git
git fetch unman
git checkout -b parrot unman/parrot
Although this is long, it takes far longer to read than to do, and the process is simple.
You can adapt this process to build almost any flavor of template you want: any template based on an existing template.
Parrot, Kali, Mint, BlackArch.
Building a new template takes a little more work.
