@novacustom can you please submit a HCL report?
Could you please confirm, should I run qubes-hcl-report dom0 on a certified NV41 Series and share the result here?
Please follow these instructions:
Here it is.
Qubes-HCL-Notebook-NV4xPZ-20230510-100826.yml (851 Bytes)
Thank you @novacustom for your HCL report, which is online now!
@Sven thank you!
Hello Qubes team. Thank you for an amazing OS.
I have a question: how NV41 is certified if there is no hardware buttons for camera and microphone. Wasnāt this a requirement before?
Thank you.
IC
Hi @immaculate
This has never been a requirement - it it were then no x230 based
machine would have qualified.
The relevant sections say:
You can read the full specification here.
I never presume to speak for the Qubes team. When I comment in the Forum or in the mailing lists I speak for myself.Even though we donāt have hardware switches for the camera and microphone module, there is an option in our configurator to permanently remove this entire module.
Hello
Pls find my HCL report for NV41 at the bottom of this submission [1] (CC @Sven )
And Iād like to report problems running Q4.1.2 on NV41 (i7-1260P + wifi 6 ax210):
When running latest kernel (6.3.2-1.qubes.fc32) and having S3 or S0ix as suspend mode set, resume from sleep does not work.
Suspend and resume works with S3 and previous kernel version (6.2.10-1)
I am also curious if your laptop is able to be charged via USB-C, because my workstation is, but only for few seconds
and then is back to drain the battery.
In specs they stated following:
1 x USB 3.1 Gen. 2 port (Type C) with Thunderbolt⢠4 support and charging over USB-C and Display Alt Mode (up to two external displays via USB-C)
There are also some other open issues reported here
[1] HCL report for NV41
layout:
'hcl'
type:
'notebook'
hvm:
'yes'
iommu:
'yes'
slat:
'yes'
tpm:
'unknown'
remap:
'yes'
brand: |
NovaCustom NV41
model: |
NV4xPZ
bios: |
Dasharo (coreboot+UEFI) v1.6.0
cpu: |
12th Gen Intel(R) Core(TM) i7-1260P
cpu-short: |
i7-1260P
chipset: |
Intel Corporation Device [8086:4621] (rev 02)
chipset-short: |
FIXME
gpu: |
Intel Corporation Device [8086:46a6] (rev 0c) (prog-if 00 [VGA controller])
gpu-short: |
Intel iRIS Xe
network: |
Intel Corporation Wi-Fi 6 AX210/AX211/AX411 160MHz (rev 1a)
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
memory: |
65376
scsi: |
usb: |
3
versions:
- works:
'partial'
qubes: |
R4.1
xen: |
4.14.5
kernel: |
6.3.2-1
remark: |
Suspend/Resume works with previous kernel 6.2.10.1, but resume fails when running latest kernel 6.3.2-1, there are also issues with charging over USB-C (3.1 with ThunderBolt 4, when it works for few seconds and then it stops).
credit: |
disp666
link: |
https://forum.qubes-os.org/t/novacustom-nv41-series/18531
I was advised to use verify that I install and run Qubes with kernel version 6.1.x. After instalation I the qubes-hcl-report said it is 6.1.12 now it got upgraded to 6.3.2-1 - after running al sorts of updates. For me as of now I everything seems to be working fine.
Are there any known issues with this kernel other than the suspend? How could I have triggered a kernel upgrade? Is there an way to downgrade?
You can select older kernel in grub menu during the boot (in case you did not uninstalled the older versions)
I just did experiment with test kernel (6.3.9-1.fc32) but resume after suspend does not work properly either.
Iāll try to describe it better, it looks like the problem is in dom0.
Machine can wake up from suspend and I can get back to GUI. Iām able to switch between virtual desktops (i3wm), appVMs.
dom0 applications and tools work OK after resume.
The problem is stuck or frozen appVM windows.
For example when I click the other open tab in browser window, the title in window change, but the content of windows shows the same screen without any re-draw.
appVMs responsible for network are stuck as well and Iām not able to close them by shutdown, I need to kill them.
This can be related to stuck processes visible in dom0:
root 39460 3045 0 19:26 ? 00:00:00 /usr/bin/qrexec-client -d disp2633 root:QUBESRPC qubes.SuspendPostAll dom0
root 39462 3045 0 19:26 ? 00:00:00 /usr/bin/qrexec-client -d disp3854 root:QUBESRPC qubes.SuspendPostAll dom0
root 39464 3045 0 19:26 ? 00:00:00 /usr/bin/qrexec-client -d sys-firewall root:QUBESRPC qubes.SuspendPostAll dom0
root 39470 3045 0 19:26 ? 00:00:00 /usr/bin/qrexec-client -d sys-vpn root:QUBESRPC qubes.SuspendPostAll dom0
root 39472 3045 0 19:26 ? 00:00:00 /usr/bin/qrexec-client -d sys-whonix root:QUBESRPC qubes.SuspendPostAll dom0
root 39474 3045 0 19:26 ? 00:00:00 /usr/bin/qrexec-client -d vault root:QUBESRPC qubes.SuspendPostAll dom0
When I kill all stuck app and sys VMs, Iām able to restart everything and continue using NV41 without reboot, but I guess there is no real benefit to this workaround. I need to be able to resume after suspend into fully working system.
So far the only solution for me is to manually choose kernel version (6.2.10-1) for suspend/resume to work as expected.
This paragraph above is not true any more, even with 6.2.10-1 in dom0, appVMs will not resume correctly ![]()
If you know anything that needs to be done to mitigate resume issue in recent kernels please let me know.
The Qubes OS team is working on a fix:
Thx!
with 6.3.12-1 resume works as expected on NV41
I really enjoy running qubesOS on new HW!
How can I install this kernel version?
I have the kernel 6.3.9-1.
I would also like to try this with my Nitropad NV41.
You need to install kernel-latest package:
sudo qubes-dom0-update kernel-latest in dom0.
There is corresponding kernel-latest-qubes-vm package to provide latest
kernel in qubes. You may want to install that also.
- Did anyone manage to setup
sys-audioand use BT headset successfully? (r4.1) - Anyone running Q r4.2?
- For quite some time (month?) laptop is not able to complete reboot or shutdown, but it hangs with black screen and is not responding to any key-press except power-button. (6.4.13-1.qubes.fc32.x86_64)
- Another observation laptop it-self is doing strange noises, itās not related to mechanical movement like fans but more like electric interference and when surrounding is quiet it is kind of annoying. Did anyone else observe something similar?
Look here
Very interesting, thank you! So it is possible to use different USB controllers with external USB drives / thumbdrives on the NV41, if this diagram is correctā¦itās just more complicated to achieve separationā¦the reason I gave up on that on my NV41 early on is because I was getting all sorts of strange behavior in my tests, but as it turned out my external SSD drive needed to be reformatted, and, as you now reveal, USB-2 behaves differently from USB-3.
So, having done some quick, preliminary tests now again, basically one could designate the TB4 USB-C port as ātrustedā by assigning the two TB4 controllers to a sys-thunderbolt, while the other controller will be in sys-usb, for example. My tests now show that in this configuration, using only USB-3 devices:
- when only
sys-thunderboltis running, only the TB4 port can be used - when only
sys-usbis running, only the other three ports can be used - performance seems to be very similar for the same SSD drive when hooked up to the TB4 port via
sys-thunderboltvs. when hooked up to the other USB-C port viasys-usb - all USB ports still provide power even when no controller is attached to any VM
Though perhaps itās prudent to instead designate the TB4 as untrusted, since when e.g. flashing new BIOS firmware the separation cannot be achieved and only the two TB4 controllers can be āisolatedā from the rest by not using that portā¦that is, unless one needs the TB4 for a dock or external graphics card.
