Laptop 4.2 Installation - Failed to Start system-udev-settle.service
Hello,
I am trying to Install Qubes 4.2 on my laptop:
i7-12700H
16GB DDR5
RTX 3050
I got Intel VT-d & Intel VT-x Enabled.
I tried installing via regular, live boot, and kernel mode
all show the same error message:
“Failed to Start system-udev-settle.service - Wait for udev to Complete Device Initialization”
After about 30 minutes or an hour there is a screen that looks like the “tree” command in windows CMD, and then a message “Boot failed” or something similar.
What is the problem? Thanks.
Hi Wrt – and welcome to the forum! :slight_smile:
“RTX 3050” .. that’s a Nvidia GPU .. right?
I had a quick look at the HCL1 and spotted a laptop with that GPU and a description of some GPU settings:
.. maybe they apply to your model/make as well?
:slight_smile:
Looks like the problem in the topic is old (2022) and might be already fixed on 4.2:
This section might be irrelevant in the future when Nouveau fully supports the RTX 3050ti mobile
And they have rendering issues: “default installation results in a black screen”
not similar to the problem I have
Yes - nouveau might have support for the 3050 now … and it might not … :-/
I don’t have your hardware and I don’t recall “Failed to Start system-dev-settle.service”, so I’m trying to eliminate possibilities … Can you try to remove quiet from the kernel line and see if more information should be available?
:slight_smile:
Okay… just did and it started showing “nvme0 timeout completion polled” around the [FAILED] Failed to Start system-udev-settle.service error, I goggled it and disabled hyperthreading in bios. Same issue still.
Note, I can’t take out the NVMe, dont want to void laptop warranty. and I am planning to install Qubes on an external SSD.
This post suggest some RAID / VMD issues:
:slight_smile:
Okay… it fixed the udev prob, but now I have this:
How did you write/make the installation media?
:slight_smile:
Rufus using ISO image mode
Sounds/looks similar to this old case?
– and that is linked from:
Maybe writing the ISO with a different tool, can resolve the problem?
Note: I’m guessing, but hope it can point you in the direction of a solution.
:slight_smile:
Going well now. Thanks.
