cisba
February 1, 2024, 5:20pm
1
Remarks
I turned off UEFI Secure Boot in the Boot Configuration section of the BIOS.
I disabled VMD controller in the Storage section of BIOS selecting the option “AHCI/NVMe” instead of “RAID On”.
At the end of the installation I encountered the “Unable to reset PCI device” error, solved following instructions published here simply using the Qubes interface.
I did not tested AEM/TPM.
Everything seems working fine.
Qubes-HCL-Dell_Inc_-Latitude_5540-20240201-181333.cpio.gz (13.6 KB)
Qubes-HCL-Dell_Inc_-Latitude_5540-20240201-181333.yml (895 Bytes)
balko
February 2, 2024, 5:35am
2
Thank you for HCL report and additional information. Can you please also fill a detailed report based on this template:
I made a draft of the list of steps that user should check for entering the future RECOMMENDED list (HCL is also required).
Not all steps can be applicable, for the skipped steps the reason they were why skipped should be provided.
Installation
Any problems with installation
Was latest kernel required?
Were some additional kernel options required?
Basic Input
Keyboard
External USB mouse [if possible to check]
Touch-pad
Touch-pad supports “tap as click” and scrolling with 2 fingers works,
Di…
Example of user providing the answers is here . The more information the better, it may be helpful to other users, thank you.
flavio
February 8, 2024, 9:24pm
3
Thanks for the HCL report. I just submitted a pull request to add it.
