How To make an OpenVPN Gateway in Qubes (4.2, 4.3)
Step-by-step Guide on setting up an OpenVPN Gateway with multiple anti-leak features that make the connection fail closed should it be interrupted.
It has been tested with Debian 13 minimal on Qubes versions 4.2 and 4.3.
Security and privacy features included:
  • :lock: anti-leak nftables rules applied to the VPN Gateway VM from inside the VM
  • :lock: anti-leak dom0 rules applied to the VPN Gateway VM from outside
  • :male_detective:optional random OpenVPN connection selection (requires multiple .ovpn files)
  • :male_detective:optional no-logs OpenVPN client configuration
Before proceeding, you will need to download a copy of your VPN provider’s configuration file(s) and have your VPN login information handy.
Prepare the OpenVPN template
  1. In dom0 terminal, install debian-13-minimal template
    qvm-template install debian-13-minimal
  2. Clone the template to a dedicated OpenVPN template
    qvm-clone debian-13-minimal debian-13-minimal-ovpn
  3. Start XTerm terminal in the OpenVPN template
    qvm-run -u root debian-13-minimal-ovpn xterm
  4. In debian-13-minimal-ovpn terminal, edit XTerm terminal settings to allow copy-pasting
    nano /etc/X11/app-defaults/XTerm
  5. scroll to the end, paste the following line
    *selectToClipboard: true
  6. Save the file (ctrl+x, y, and Enter)
  7. Close the terminal, then open it again (repeat step #3)
    :information_source: Copy-Paste inside XTerm Terminal: to copy, select the text and press Ctrl+Shift+C, to paste press the mousewheel button
  8. Update and install OpenVPN and notification packages
    apt update && apt install -y --no-install-recommends qubes-core-agent-networking qubes-notification-agent libnotify-bin openvpn
    Note: libnotify-bin package is present in debian-13 template, but missing in the minimal version. It is required for VPN status notifications.
  9. Disable the auto-starting services that come with OpenVPN, then close the terminal.
    systemctl stop openvpn.service
    systemctl stop openvpn-client@client
    systemctl stop openvpn-server@server
    systemctl disable openvpn.service
    systemctl disable openvpn-client@client
    systemctl disable openvpn-server@server
    Ignore warnings about locale settings
  10. Shutdown the template. In dom0 qvm-shutdown debian-13-minimal-ovpn
Set up the OpenVPN Gateway VM
  1. Create a new AppVM
    • name it sys-vpn
    • set the template to debian-13-minimal-ovpn
    • set Network to Custom ➝ sys-firewall — :warning: not Default ➝ sys-firewall
    • set Provides network access to other qubes checked in the Advanced Options section
  2. Set up and test the OpenVPN client
    Make sure the VPN template debian-13-minimal-ovpn is not running, then start the VPN VM and launch XTerm terminal. From dom0 run
    qvm-run -u root sys-vpn xterm
    Set up and test the VPN client. Create a new /rw/config/vpn folder
    mkdir /rw/config/vpn
    Copy your VPN configuration files to /rw/config/vpn. Your OpenVPN config file should be named openvpn-client.ovpn so you can use the scripts below as is without modification. Otherwise you would have to replace the file name. Files accompanying the main config such as *.crt and *.pem should also be placed in the /rw/config/vpn folder.
    Check or modify configuration file contents
    nano /rw/config/vpn/openvpn-client.ovpn
    Files referenced in openvpn-client.ovpn should not use absolute paths such as /etc/...
    The config should route all traffic through your VPN’s interface after a connection is created; For OpenVPN the directive for this is redirect-gateway def1
    Make sure it already includes or add:
    Note: If your VPN provider did not supply credentials to use, you may skip the following auth-user-pass directive and pass.txt file creation
    The VPN client may not be able to prompt you for credentials when connecting to the server, so we’ll add a reference to a file containing the VPN username and password, add or modify auth-user-pass like so:
    auth-user-pass pass.txt
    Save the /rw/config/vpn/openvpn-client.ovpn file.
    nano /rw/config/vpn/pass.txt
    Add:
    username
    password
    Replace username and password with your actual username and password.
    Test your client configuration: Run the client from the AppVM XTerm terminal in the ‘vpn’
    openvpn --cd /rw/config/vpn --config openvpn-client.ovpn
    Watch for status messages that indicate whether the connection is successful (e.g. Initialization Sequence Completed) and test from another VPN VM terminal window with ping.
    ping 1.1.1.1
    ping can be aborted by pressing the two key combination Ctrl+C. DNS may be tested at this point by replacing addresses in /etc/resolv.conf with ones appropriate for your VPN (although this file will not be used when setup is complete, therefore revert to your original qubes nameservers after testing the connection). Diagnose any connection problems using resources such as client documentation and help from your VPN service provider. Proceed to the next step when you’re sure the basic VPN connection is working.
  3. Create the DNS-handling script
    nano /rw/config/vpn/qubes-vpn-handler.sh
    Add the following:
    #!/bin/bash
    set -e
    export PATH="$PATH:/usr/sbin:/sbin"
    case "$1" in
    up)
    # To override DHCP DNS, assign DNS addresses to 'vpn_dns' env variable before calling this script;
    # Format is 'X.X.X.X  Y.Y.Y.Y [...]'
    if [[ -z "$vpn_dns" ]] ; then
        # Parses DHCP foreign_option_* vars to automatically set DNS address translation:
        for optionname in ${!foreign_option_*} ; do
            option="${!optionname}"
            unset fops; fops=($option)
            if [ ${fops[1]} == "DNS" ] ; then vpn_dns="$vpn_dns ${fops[2]}" ; fi
        done
    fi
    nft flush chain inet user-vpn prerouting-nat
    nft flush chain inet user-vpn forward-filter-dns
    if [[ -n "$vpn_dns" ]] ; then
        # Set DNS address translation in firewall:
        for addr in $vpn_dns; do
    		nft add rule inet user-vpn prerouting-nat iifgroup 2 udp dport 53 counter dnat ip to $addr
    		nft insert rule inet user-vpn forward-filter-dns iifgroup 2 udp dport 53 ip daddr $addr counter accept
    		nft add rule inet user-vpn prerouting-nat iifgroup 2 tcp dport 53 counter dnat ip to $addr
    		nft insert rule inet user-vpn forward-filter-dns iifgroup 2 tcp dport 53 ip daddr $addr counter accept
        done
        su - -c 'notify-send "LINK IS UP." --icon=network-idle' user
    else
        su - -c 'notify-send "LINK UP, NO DNS!" --icon=dialog-error' user
    fi
    down)
    su - -c 'notify-send "LINK IS DOWN !" --icon=dialog-error' user
    # Restart the VPN automatically
    sleep 5s
    sudo /rw/config/rc.local
    esac
    Save the script (ctrl+x, y, and Enter). Make it executable.
    chmod +x /rw/config/vpn/qubes-vpn-handler.sh
  4. Configure client to use the DNS handling script
    Add the following under the redirect-gateway def1 line:
    script-security 2
    up 'qubes-vpn-handler.sh up'
    down 'qubes-vpn-handler.sh down'
    Remove other instances of lines starting with script-security, up or down should there be any others.
  5. Create the nftables anti-leak rules script
    nano /rw/config/vpn/qubes-vpn-firewall.sh
    Add the following:
    #!/bin/bash
    set -e
    # Add the `qvpn` group to system. The sync and sleep were in the original script but might not be needed.
    groupadd -rf qvpn; sync; sleep 2s
    nft add table inet user-vpn
    nft 'add chain inet user-vpn forward-filter { type filter hook forward priority filter - 1; policy accept; }'
    # Block forwarding of connections through upstream network device (in case the vpn tunnel breaks or packets are routed
    # directly between upstream and tunnel interface).
    nft add rule inet user-vpn forward-filter meta iifgroup 1 counter drop
    nft add rule inet user-vpn forward-filter meta oifgroup 1 counter drop
    nft add rule inet user-vpn forward-filter meta mark set 3000 counter
    nft add chain inet user-vpn forward-filter-dns
    nft add rule inet user-vpn forward-filter jump forward-filter-dns
    # The up script adds a DNAT rule to prerouting-nat and a corresponding accept rule to forward-filter-dns. If the accept
    # rule is not hit then the DNAT was not applied and the packet should be dropped else it will go through the tunnel with
    # the AppVM DNS (DNS leak). This could happen if the tunnel is created after a packet passes prerouting-nat but before
    # the routing decision is made. If Qubes adds a higher priority DNAT DNS rule then DNS will stop working but not leak.
    nft add rule inet user-vpn forward-filter iifgroup 2 udp dport 53 counter drop
    nft add rule inet user-vpn forward-filter iifgroup 2 tcp dport 53 counter drop
    nft 'add chain inet user-vpn postrouting-filter { type filter hook postrouting priority filter - 1; policy accept; }'
    # Tunnel broke after forward-filter and the reroute check redirected packet to oifgroup 1.
    nft add rule inet user-vpn postrouting-filter meta mark 3000 oifgroup 1 counter drop
    # Drop all output through the tunnel interface and only allow traffic from the `qvpn` group to the uplink interface. Our
    # VPN client will run with group `qvpn`.
    nft 'add chain inet user-vpn output-filter { type filter hook output priority filter - 1; policy drop; }'
    nft add rule inet user-vpn output-filter meta oifgroup 1 skgid qvpn counter accept
    nft add rule inet user-vpn output-filter meta oifgroup 2 counter accept
    nft add rule inet user-vpn output-filter meta oifname "lo" counter accept
    nft add rule inet user-vpn output-filter counter
    # Chain for up script.
    nft 'add chain inet user-vpn prerouting-nat { type nat hook prerouting priority dstnat - 1; policy accept; }'
    # Rely on Qubes rules for masquerade.
    # Rely on Qubes rules for preventing inbound packets (they're dropped unless established,related).
    chmod +x /rw/config/vpn/qubes-vpn-firewall.sh
  6. Set up the VPN’s autostart
    nano /rw/config/rc.local
    Clear out the existing lines and add:
    #!/bin/bash
    export VPN_CLIENT='openvpn'
    VPN_OPTIONS='--cd /rw/config/vpn/ --config openvpn-client.ovpn --daemon'
    # Uncomment to randomly select a .ovpn config from /rw/config/vpn/
    #VPN_OPTIONS='--cd /rw/config/vpn/ --config '$(find /rw/config/vpn/*.ovpn|shuf -n1|rev|cut -d/ -f1|rev)' --daemon'
    groupadd -rf qvpn ; sleep 2s
    sg qvpn -c "$VPN_CLIENT $VPN_OPTIONS"
    su - --whitelist-environment=VPN_CLIENT -c 'notify-send "Starting $VPN_CLIENT..." --icon=network-idle' user
    :information_source: Optional: If you have multiple .ovpn configuration files inside /rw/config/vpn/ and want to start a random VPN connection each time the VPN Gateway boots up, comment the 3rd line and uncomment the 6th line
    Save the script (ctrl+x, y, and Enter) and close the terminal.
  7. Shutdown the VPN VM. In dom0
    qvm-shutdown sys-vpn
  8. Create a systemd service in VPN template
    Start the OpenVPN template and spawn XTerm terminal
    Create the systemd service
    nano /lib/systemd/system/qubes-vpn-firewall.service
    Add the following:
    [Unit]
    Description=Qubes VPN firewall updater
    After=qubes-firewall.service
    Before=qubes-network.service
    [Service]
    type=oneshot
    ExecStart=/rw/config/vpn/qubes-vpn-firewall.sh
    [Install]
    RequiredBy=qubes-network.service
    Note: This system service ensures the nftables rules from /rw/config/vpn/qubes-vpn-firewall.sh are in place after the qubes-firewall.service is active and before the qubes-network.service has started.
    Enable the service
    systemctl enable qubes-vpn-firewall.service
    Close the terminal.
  9. Shutdown the VPN template. In dom0
  10. Start your VPN Gateway VM. You should see VPN Notifications on the top right corner of your monitor.
You can now use your VPN Gateway! :partying_face: Set sys-vpn as the Net Qube for your AppVMs.
:lock: Anti-leak dom0 firewall rules
A highly recommended extra layer of anti-leak firewall rules can be set in dom0 for the VPN Gateway VM.
These rules are outside the scope of the VPN VM and would require dom0 compromise in order to be tampered with.
:warning: Make sure the VPN Gateway (sys-vpn) is turned off before proceeding.
In dom0 terminal run the following commands — replace <> placeholders with the connection information of your OpenVPN configuration
qvm-firewall <VPN-Gateway-VM-Name> reset
qvm-firewall <VPN-Gateway-VM-Name> add accept <OpenVPN-server-IP>/32 <protocol> <port>
qvm-firewall <VPN-Gateway-VM-Name> add drop
qvm-firewall <VPN-Gateway-VM-Name> del --rule-no 0   # Delete default 'accept' rule
Example:
qvm-firewall sys-vpn reset
qvm-firewall sys-vpn add accept 123.45.67.89/32 udp 1194
qvm-firewall sys-vpn add drop
qvm-firewall sys-vpn del --rule-no 0
Check the firewall rules with
qvm-firewall sys-vpn list
It should look like
user@dom0:~$ qvm-firewall sys-vpn list
NO  ACTION  HOST             PROTOCOL  PORT(S)  SPECIAL TARGET  ICMP TYPE  EXPIRE  COMMENT
0   accept  123.45.67.89/32  udp       1194     -               -          -       -
1   drop    -                -         -        -               -          -       -
:male_detective: No-Logs configuration
To prevent recording OpenVPN (client) logs in the Gateway VM, add the following to your .ovpn configuration file:
log /dev/null
status /dev/null
verb 0
:mag: Debug
To debug your OpenVPN connection, add the following to your .ovpn config:
verb 3
log /home/user/log
This will save the verbose connection log to the /home/user/log file.
Sources:
Thanks @longTimeQubesUser @qubesfirewallbug !
I am using only the anti-leak firewall rules in dom0 since it is must simpler than the nftables.
Do we need
when doing
Which leak cases will be covered by nftables which are not blocked by dom0 firewall approach?
Reference:
Edit: cross-post: Wireguard VPN setup (4.2 and 4.3) - #536 by whoami
You are welcome @whoami.
Almost every VPN guide in the forum, like the one you quoted, rely on dom0 firewall as the sole and primary anti-leak machanism, that is simply a bad security practice. First, you enforce strong firewall rules in the VM itself, THEN you expand it as much as possible to every other security feature available, both inside and outside the domain of the VM. This is done for the same reason that in a chess game you will not rely on the Queen to do all the work, but use all the pieces, and in the correct order.
The qubes dom0 firewall does effectively work to prevent unwanted connections, but it’s better used as a backup rather than the primary defense. That’s why in the 2022 Official Qubes VPN Guide I mentioned in the Sources section, you won’t see dom0 firewall mentioned at all - instead they rely on iptables-based rules in the VPN Gateway VM.
Even those official rules themselves, like mentioned by @qubesfirewallbug did not address a series of potential leaks he pointed out, both in the forum, and on the qubes mailing list with the developers:
The reason many guides in here rely solely on dom0 fw rules is because implementing robust anti-leak nftables rules can be complex, not everyone has the expertise required to confidently share them publicly.
TLDR; Relying solely on dom0 firewall rules does work, but a typo, misconfiguration, or software bug in it could expose you. My guide was written with security paranoia in mind, it’s a considerably more robust, layered defense approach.
That said, feel free to use whatever guide you wish, not everybody is hiding from the NSA! :smile:
Unrelated to previous responses, I wanna say that it took me 2 entire days of my free unpaid time to repeatedly test the guide, and make it easily used by everybody and be referenced in the future as “Gold Standard” in terms of security.
Part of that time was used in testing the VPN Gateway without dom0 firewall rules enabled looking for potential leaks, especially during quick AppVM startup, VPN Gateway reboots (whilst in use by AppVMs), abrupt shutdowns, and other scenarios. Although I have found no leaks, everyone is welcome to test themselves and report any findings, granted they come with a reproducible Proof of Concept.
I hope my great effort will be of use to Qubes users in the upcoming years :+1: :grin:
Have implemented and done rudimentary testing. So far it appears good, thank you for your work. I would like to use one VPN template for all VPN apps, including OpenVPN and Wireguard. Do you know any reason not to use this with Wireguard (specifically thinking of firewall and DNS)? For example would the firewall rules (nft and also in dom0) cause problems in a Qube like this: Mullvad VPN App 4.3 (and 4.2) setup guide
Update: I confirm that one template can work for both guides.
So if you reinstall Qubes with fresh dom0, you must re-implement these rules. Correct? (Usually I do not backup dom0 in case it was compromised.)
And also: what if the VPN gateway uses an array of IP addresses not in the same subnet, at random? The dom0 rules might not work so well there?
Can I add multiple lines of the type
Solved. I was stupid
I realized the problem. I hasn’t made qubes-vpn-firewall.sh executable. I was looking at the screen and typing without looking, and did chmod +. Leaving this ehre in case anyone else has the same error in the future. This works fine now.
I have tried this guide a few times, and sometimes it has worked. But in two cases, I have the following error when openvpn executes qubes-vpn-handler, and I think it’s when it executes the “up” case:
Error: No such file or directory: did you mean table 'qubes' in family ip?
“user-vpn” is underlined
I don’t know what this indicates. I am still working on this. Probably I have just done something dumb. But if anyone has information that would help, it might help other people too.
Update:
So it’s something with these nft calls:
If I comment them out and run ./qubes-vpn-handler up I do not get the error (but if I uncomment, then I do.)
I don’t know anything about nft (which is why I am using a guide, ever since iptables went away). But I would guess it’s user-vpn that doesn’t exist, maybe, that’s causing the error?
1.
I stumbled upon that error at the beginning of my tests, when writing the guide. It doesn’t recognize the nftable table user-vpn because, most likely, the qubes-vpn-firewall.sh hasn’t executed before the openvpn connection, and has yet to create that table.
If I had to guess it’s because you have included
in your .ovpn conf before setting up the qubes-vpn-firewall.sh script, or you are testing the openvpn connection in between one of the steps in the guide.
I followed the instructions from scratch several times, just like a user would, it always worked, except when I was inattentive and messed the order of the instructions.
Bottom line is, follow the guide with full attention and no assumptions, it is guaranteed to work.
I replied above. Also, if anybody following the guide tampers with the anti-leak rules, then they’re Not following the guide, and they better know what they are doing.
2.
I switched from qubes 4.1 to qubes 4.3 recently, all appvms I restored in the new OS version had their dom0 firewall rules on them. So, no you don’t have to re-implement them, however I, being paranoid, did delete and re-implement them.
In once instance I noticed renaming the appvm caused the loss of dom0 firewall rules applied to the appvm, I later tried to replicate the bug but couldn’t. I’m not entirely sure of what I saw but I’ve been paranoid about dom0 firewall bugs ever since.
3.
I’m not sure what what you mean. I’d stick to a single netvm qube for openvpn, a separate one for wireguard, and definitely another one for proprietary closed-source VPN providers Apps (different app provider, different netvms).
The guide should work with wireguard as well, but I cannot vouch for it as I haven’t tested it. I was thinking of writing the same for wireguard, with the appropriate anti-leak tests, but I’m short on time lately.
Unrelated, I also thought about making a guide on how to properly test for network leaks in Qubes, with Wireshark running in a cloned sys-firewall instance and capturing all traffic, that’s out of topic to talk about here though.
@longTimeQubesUser Excellent work.
ps by the way, what window theme are you using? nice buttons
Yes, but would be a great guide!
Not sure if you noticed but I added a comment later that I confirm this works.
You saw that I added a comment later that the problem was I hadn’t made qubes-vpn-firewall.sh executable, right?
This is a wild statement but I will repeat that I confirm that your guide works, though I haven’t tested the dom0 rules.
Thank you @longTimeQubesUser for providing this important guide. Appreciate that.
I just started executing the command:
And I get
Error: Unable to locate package qubes-notification-agent
So I left qubes-notification-agent out and it works.
Despite I did not finish the guideline, I am asking me if qubes-notification-agent is mandotory?
Thank you!
The window theme is Wallis
You’re welcome!
That package is not mandatory for the vpn-gateway to work, you just won’t get:
these awesome notifications (last two)
However, it is strange that apt is not finding that package. Are you using the minimal debian 13 template ?
I tried it in
debian-13
debian-13-xcfe
debian-13-minimal
All fail with the
I do not know why, because it seems to work for everyone else.
Why do you not use systemd for auto-starting openvpn? Is it dangerous to do so?
Ok I resolved it partially:
qubes-notification-agent is not available in r4.2, but in r4.3.
@longTimeQubesUser maybe you can tell us how the notification was done in r4.2?
And if it is not possible, we got to rename the title of this topic.
Everything else works. Great!
@longTimeQubesUser Thank you for taking the time to make this guide. If you have some time, would you mind helping me troubleshoot setting this up?
I recently did a fresh install of 4.3 and realized I wasn’t able to set up my VPN template/qubes the way I had before via: Configuring a ProxyVM VPN Gateway
I’ve followed your guide step-by-step a few times now, and I can’t figure out why I don’t have internet access (I’m using ProtonVPN, if this helps at all).
Things of note:
My ovpn config file:
client
dev tun
proto tcp
remote 156.146.54.81 443
remote 156.146.54.81 7770
remote 156.146.54.81 8443
remote-random
resolv-retry infinite
nobind
cipher AES-256-GCM
setenv CLIENT_CERT 0
tun-mtu 1500
mssfix 0
persist-key
persist-tun
reneg-sec 0
remote-cert-tls server
script-security 2
verb 3
log /home/user/log
When I test my client configuration with:
I’m receiving packets via pinging, consistently, although I’m receiving this:
Connection reset, restarting [-1]
SIGUSR1[soft,connection-reset] received, process restarting
NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
TCP/UDP: Preserving recently used remote address: [AF_INET]156.146.54.81:7770
I continued with the guide until I finished everything and the logs say I’m establishing a connection but I only receive the first notification stating “sys-vpn: Starting openvpn…”, I never receive the “sys-vpn: LINK IS UP.” notification.
Logs after starting my vpn qube:
2026-03-07 17:30:24 Note: Kernel support for ovpn-dco missing, disabling data channel offload.
2026-03-07 17:30:24 WARNING: file 'pass.txt' is group or others accessible
2026-03-07 17:30:24 OpenVPN 2.6.14 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] [D>
2026-03-07 17:30:24 library versions: OpenSSL 3.5.4 30 Sep 2025, LZO 2.10
2026-03-07 17:30:24 DCO version: N/A
2026-03-07 17:30:24 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2026-03-07 17:30:24 TCP/UDP: Preserving recently used remote address: [AF_INET]156.146.54.81:7770
2026-03-07 17:30:24 Socket Buffers: R=[131072->131072] S=[16384->16384]
2026-03-07 17:30:24 Attempting to establish TCP connection with [AF_INET]156.146.54.81:7770
2026-03-07 17:30:24 TCP connection established with [AF_INET]156.146.54.81:7770
2026-03-07 17:30:24 TCPv4_CLIENT link local: (not bound)
2026-03-07 17:30:24 TCPv4_CLIENT link remote: [AF_INET]156.146.54.81:7770
2026-03-07 17:30:43 Connection reset, restarting [-1]
2026-03-07 17:30:43 SIGUSR1[soft,connection-reset] received, process restarting
2026-03-07 17:30:43 Restart pause, 1 second(s)
2026-03-07 17:30:44 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2026-03-07 17:30:44 TCP/UDP: Preserving recently used remote address: [AF_INET]156.146.54.81:8443
2026-03-07 17:30:44 Socket Buffers: R=[131072->131072] S=[16384->16384]
2026-03-07 17:30:44 Attempting to establish TCP connection with [AF_INET]156.146.54.81:8443
2026-03-07 17:30:44 TCP connection established with [AF_INET]156.146.54.81:8443
2026-03-07 17:30:44 TCPv4_CLIENT link local: (not bound)
2026-03-07 17:30:44 TCPv4_CLIENT link remote: [AF_INET]156.146.54.81:8443
2026-03-07 17:31:04 Connection reset, restarting [-1]
2026-03-07 17:31:04 SIGUSR1[soft,connection-reset] received, process restarting
2026-03-07 17:31:04 Restart pause, 1 second(s)
2026-03-07 17:31:05 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2026-03-07 17:31:05 TCP/UDP: Preserving recently used remote address: [AF_INET]156.146.54.81:443
2026-03-07 17:31:05 Socket Buffers: R=[131072->131072] S=[16384->16384]
2026-03-07 17:31:05 Attempting to establish TCP connection with [AF_INET]156.146.54.81:443
2026-03-07 17:31:05 TCP connection established with [AF_INET]156.146.54.81:443
I cloned both the template/vpn qube to correct the kernel support error by installing: openvpn-dco-dkms - but I don’t think it’s necessary, though. I’m not sure if changing the location of any of the configurations in the ovpn config file would make a difference, as I tried that (keeping redirect-gateway def1 above script-security 2).
Now I’m receiving pretty much the same thing, just without the kernel error:
2026-03-07 17:40:00 WARNING: file 'pass.txt' is group or others accessible
2026-03-07 17:40:00 OpenVPN 2.6.14 x86_64-pc-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [PKCS11] [MH/PKTINFO] [AEAD] [DCO]
2026-03-07 17:40:00 library versions: OpenSSL 3.5.4 30 Sep 2025, LZO 2.10
2026-03-07 17:40:00 DCO version: 0.0+git20241121
2026-03-07 17:40:00 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
2026-03-07 17:40:00 TCP/UDP: Preserving recently used remote address: [AF_INET]156.146.54.81:443
2026-03-07 17:40:00 Socket Buffers: R=[131072->131072] S=[16384->16384]
2026-03-07 17:40:00 Attempting to establish TCP connection with [AF_INET]156.146.54.81:443
2026-03-07 17:40:00 TCP connection established with [AF_INET]156.146.54.81:443
2026-03-07 17:40:00 TCPv4_CLIENT link local: (not bound)
2026-03-07 17:40:00 TCPv4_CLIENT link remote: [AF_INET]156.146.54.81:443
If there’s something I’m missing to give more insight into what’s going on, please let me know. Thank you again for the excellent guide. Any help would be greatly appreciated.
@longTimeQubesUser For some reason trying to go back to default resolv-conf in the config file, then changing it back to qubes-vpn-handler.sh made it work? Not sure why it’s working now but I’m glad it is. Really appreciate you putting in the time to make this guide, don’t like going to sites without a reliable vpn.
Guide is assumed to work on 4.2 as there are no changes between 4.2 and 4.3 (tested version) that would prevent the guide from working.
I wasn’t aware that package wasn’t available in 4.2. The guide should still work the same for 4.2, but you won’t have notifications without the notification package.
Please create a forum post asking what that package naming is in qubes 4.2, if you find out what it is, install that instead. If the notifications work, we can update the guide to use that package for v4.2. users, even though it will soon be End-of-Life.
EDIT: see if installing libnotify-bin works, maybe that is enough for you to get the notifications on 4.2.
Hi. Unfortunately this thread is specific to the guide, we cannot troubleshoot what could be general vpn issues with your vpn provider.
Please, first verify the vpn works in a standalone debian 13 (non minimal) qube.
Note: default qubes nftables will block the vpn from forwarding the traffic (not from connecting, that should work). I suggest disabling the qube firewall (inside the qube) just for the test, and then try connecting to your vpn provider and see if the vpn works at all. You can delete this standalone vm afterwards.
Great guide! Not sure if this improves anything but I made sys-vpn a disposable template with no netvm and created a named disposable called sys-vpn-inuse with sys-firewall.
Thanks for writing this guide!
