Sorry for this rather basic topic: I am looking for some information on how the storage of the template/app VMs is handled internally by QubesOS.
My main question is: What is happening internally from storage perspective when I’m starting/shutting down an app VM and why does the shutdown seem to take longer, the more data is inside?
I do know that the LVMs are manged automatically and I did observe through sudo lvs that their number changes when the VM is started compared to when it’s stopped.
I tried to find the relevant explanation in the documentation but wasn’t successful yet.
Thanks in advance for some more insight on this topic!
In case it helps someone: This solution worked for me to resolve the slow VM shutdowns that I was experiencing. Also large VMs are now shutting down within a few seconds.
@qpost135 did you follow a guide? @tasket mentioned it’s an option in the installer. I am highly interested in reproducing this … shutting down my 100GB Windows 10 HVM blocks everything for a good minute.
I didn’t follow a guide but it was a simple process in the installer GUI.
Just to ensure that you are indeed experiencing the same issue, I would recommend to observe the lvs output during your large VM shutdown, as explained here. When I saw that my system behaves exactly the same (= slow deletion of the -bak), I was more confident to try out BTRFS.
What I did in the installer GUI to get a BTRFS system:
Select Manual Partitioning: “I will configure partitioning”
Delete all automatically created/previous partitions
Set "New mount points will use the following partitioning scheme: " to Btrfs
Click on “Click here to create them automatically”
Observe the new partition entries: The boot partition is still ext4 but the partition mounted at / is now Btrfs
