What’s the output of this command?
cat /etc/modprobe.d/*
Shouldn’t commands like “nvidia-xconfig” work when nvidia driver is installed - even in qubes?
Good idea. I just put a file in it with this:
blacklist nouveau
options nouveau modset=0
And now it’s not loading anymore!
But the resolution is still wrong, the monitors are not recognized. Xrandr outputs this:
“xrandr: Failed to get size of gamma for output default
Screen 0:….”
On both different montors xandr outputs the same error.
Do you still have nomodeset kernel option?
Yes. Otherwise it’s again not working.
But doesn’t nomodeset just deactivate the standard thing until the x server is up?
Also there is a typo, it should be:
options nouveau modeset=0
Sorry! The typo exists only in this Forum; I’m currently using my tablet for research.
Hmm. When using the grapical installation & not the the cli command in the community guideline nvidia installer shows this:
For that i would have to stop lightdm, start the installer again & activate lightdm afterwards right? But how would that be possible because then this wouldn’t work anymore? ^^
Edit: Nevermind, the community guideline uses “—no-x-check” as a workaround.
Not sure how it works. I think it’s disabling kernel modesetting altogether and you can’t use the modesetting Xorg driver, only vesa/nv/etc Xorg drivers that may not support the resolution that you want:
https://wiki.archlinux.org/title/Kernel_mode_setting#Disabling_modesetting
Qubes OS is using modesetting Xorg driver by default.
Do you have any errors or it’s just stuck at the same screen as here?
Hm, okay. Interesting.
No errors, i am just sticking at the same screen as here.
Even if it lead to an error a few hours ago: maybe the error is the missing xorg.conf-file that is not generated?
You can try to configure xorg.conf as described here:
Finally, you should configure Xorg to use nvidia driver. You can use nvidia-xconfig or do it manually:
X -configure mv /root/xorg.conf.new /etc/X11/xorg.conf # replace Driver in Device section by "nvidia"
Maybe you’ve installed wrong nvidia driver?
Or it’s failing?
Check the logs in journalctl, maybe there will be any info about nvidia.
I checked the driver, it’s the right one.
There are no errors:
I’m currently writing all infos together in the hope that something catches my eyes…
You already sent me this link: Stuck in a boot loop after entering Luks PW successfully - #2 by apparatus
Could it be possible that any setting of this could have fixed me issue when it worked once? On my understanding these are only logging configs that shouldn’t have any correlations with this, or am I wrong?
I created a new post here because I realized that this post was too general and already contains many different error fixes. If someone has a similar problem in the future, they will not find it here; hence the new ticket.
Thank you for your incredible support and for your patience! ^^ @apparatus
No, these options shouldn’t have changed anything except for enabling the log output.
