Error: Failed to import module localemod
:wave: Hallo community,
:anger: I get an error message, if I run the dom0 updater.
[user@dom0 ~]$ sudo qubesctl --show-output state.sls update.qubes-dom0
[WARNING ] /usr/lib/python3.8/site-packages/salt/utils/files.py:396: RuntimeWarning: line buffering (buffering=1) isn't supported in binary mode, the default buffer size will be used
  f_handle = open(*args, **kwargs)  # pylint: disable=resource-leakage
[ERROR   ] Failed to import module localemod, this is due most likely to a syntax error:
  File "/usr/lib/python3.8/site-packages/salt/loader.py", line 1685, in _load_module
    mod = spec.loader.load_module()
  File "<frozen importlib._bootstrap_external>", line 522, in _check_name_wrapper
  File "<frozen importlib._bootstrap_external>", line 1027, in load_module
  File "<frozen importlib._bootstrap_external>", line 852, in load_module
  File "<frozen importlib._bootstrap>", line 265, in _load_module_shim
  File "<frozen importlib._bootstrap>", line 702, in _load
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 848, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/var/cache/salt/minion/extmods/modules/localemod.py", line 222, in <module>
    @decorators.which('locale-gen')
AttributeError: module 'salt.utils.decorators' has no attribute 'which'
local:
    Function: file.replace
      Result: True
     Comment: No changes needed to be made
     Started: 00:35:35.489167
    Duration: 12.268 ms
     Changes:
      Result: True
     Started: 00:35:35.501546
    Duration: 1.288 ms
     Changes:
    Function: cmd.run
        Name: if qubes-dom0-update --quiet --assumeyes --clean --action=clean expire-cache >/dev/null 2>&1; then
    echo "result=True comment='Cache cleaned'"
else
    echo "result=False comment='Could not clean cache'"
fi
      Result: True
     Comment: Cache cleaned
     Started: 00:35:35.503942
    Duration: 5986.629 ms
     Changes:
    Function: pkg.uptodate
      Result: True
     Comment: System is already up-to-date
     Started: 00:35:43.050404
    Duration: 101501.898 ms
     Changes:
Summary for local
Succeeded: 4
Failed:    0
Total states run:     4
Total run time: 107.502 s
:question: Should I be worried? How can I solve this error?
:pray: Thank you very much for your help.
It has failed to load a resource for your locale. Salt Localemod docs refer to this variable…
It appears it didn’t break any other functionality based on the “Comment” and “Result” fields.
How can I avoid this error? What should I do?
Hello there,
getting the same error after upgrading to Qubes OS 4.1. I think exactly the same issue is described and marked as Solution here: Dom0 update fails after 4.1 upgrade .
After the update attempt, there’s still a green tick shown after dom0 (!) Only after opening the Details, one can see that there is an [Error ] . Is this a security concern?
Thank you!
Please note that the upgrade process didn’t ran that smooth, I unintentionally skipped Stage 2. I ran qubes-dist-upgrade --all , but Stage 1 was stuck for a while, I aborted it and “continued” manually.
I’ll try to fix the problem by myself first.
Fixed. Followed the instructions from RhizomaticNomad from https://github.com/QubesOS/qubes-issues/issues/7114 from Dom0 update fails after 4.1 upgrade
in Global settings → Default kernel used by qubes was pointing to 5.4 from fc25, changed that to 5.10.109-1.fc32.
sudo dnf remove qubes-mgmt-salt-base-overrides (not necessary, because it wasn’t installed (anymore?))
qubesctl saltutil.clear_cache
qubesctl saltutil.sync_all
After this, the Dom0 could be updated again.
That’s all I did (even no reboot).
Best regards,
Ivan
