Hello people,
just to make sure I don’t miss something.
I ran an upgrade to Qubes 4.1 today, but the qubes-dist-upgrade --all crashed at Stage 1. (Some VMs didn’t want to update and the process hang for 20’ - then I closed the console and started it again, this time manually.) I had to start from Stage 2, but wrongly I started the Stage 3, which ran successfully. Then I tried to run Stage 2 → without success. I decided that I will be able to upgrade the VMs at a later point so I continued. At the end I ran Qubes Update for all the systems.
Now everything seems to be fine (I had that issue: Error: Failed to import module localemod - #6 by ivan-jli , it’s fixed). Do you find some other possible hidden issue there?
Regards,
Ivan
What is your Qube Manager saying in “About”->“Qubes OS”->“Version Information”?
Thank you for replying fsflover. It says “4.1.1 (R4.1)”.
You should also go to “Version Information” there and tell us which packages are listed in it.
How has this worked out for you?
You might be interested in this post. Qubes-dist-upgrade (4.0 to 4.1) Break down / Manual upgrade option. In particular what steps may have been missed in STAGE 1 & 2.
May I have a list with the “right” versions of the packages? Is there an easy way to get such, or I have to go trough all the packages manually and see which version is the right one?
If I run on my actual state of qubes “qubes-dist-upgrade -l”, it tries to upgrade my windows TemplateVM and it fails:
2022-07-30 17:10:04.659 qrexec-client[10995]:qrexec-client.c:184:connect_unix_socket: connect: No such file or directory
so the process is aborted and the other VMs are left untouched.
Best,
Ivan
Here is my list of (I believe) fully updated packages listed in “About”->“Qubes OS”->“Version Information”:
xen_version : 4.14.5
Linux 5.15.52-1.fc32.qubes.x86_64
Installed Packages:
grub2-qubes-theme.x86_64 5.14.4-2.fc32
kernel-qubes-vm.x86_64 1000:5.10.109-1.fc32.qubes
kernel-qubes-vm.x86_64 1000:5.10.112-1.fc32.qubes
kernel-qubes-vm.x86_64 1000:5.15.52-1.fc32.qubes
python3-qubesadmin.noarch 4.1.23-1.fc32
python3-qubesdb.x86_64 4.1.13-1.fc32
python3-qubesimgconverter.x86_64 4.1.16-1.fc32
qubes-anaconda-addon.noarch 4.1.8-1.fc32
qubes-artwork.noarch 4.1.12-1.fc32
qubes-artwork-anaconda.noarch 4.1.12-1.fc32
qubes-artwork-plymouth.noarch 4.1.12-1.fc32
qubes-audio-daemon.x86_64 4.1.21-1.fc32
qubes-audio-dom0.x86_64 4.1.21-1.fc32
qubes-core-admin-addon-whonix.noarch 4.1.1-1.fc32
qubes-core-admin-client.noarch 4.1.23-1.fc32
qubes-core-dom0.noarch 4.1.27-1.fc32
qubes-core-dom0-linux.x86_64 4.1.23-1.fc32
qubes-core-dom0-linux-kernel-install.x86_64 4.1.23-1.fc32
qubes-core-qrexec.x86_64 4.1.18-1.fc32
qubes-core-qrexec-dom0.x86_64 4.1.18-1.fc32
qubes-core-qrexec-libs.x86_64 4.1.18-1.fc32
qubes-db.x86_64 4.1.13-1.fc32
qubes-db-dom0.x86_64 4.1.13-1.fc32
qubes-db-libs.x86_64 4.1.13-1.fc32
qubes-desktop-linux-common.noarch 4.1.12-1.fc32
qubes-desktop-linux-manager.noarch 4.1.14-1.fc32
qubes-desktop-linux-menu.noarch 0.2.1-1.3.fc32
qubes-dom0-meta-packages.noarch 4.1.21-1.fc32
qubes-gpg-split-dom0.x86_64 2.0.60-1.fc32
qubes-gui-daemon.x86_64 4.1.21-1.fc32
qubes-gui-dom0.x86_64 4.1.21-1.fc32
qubes-img-converter-dom0.x86_64 1.2.11-1.fc32
qubes-input-proxy.x86_64 1.0.26-1.fc32
qubes-input-proxy-receiver.x86_64 1.0.26-1.fc32
qubes-input-proxy-sender.x86_64 1.0.26-1.fc32
qubes-libvchan-xen.x86_64 4.1.7-1.fc32
qubes-manager.noarch 4.1.23-1.fc32
qubes-menus.noarch 4.1.12-1.fc32
qubes-mgmt-salt.noarch 4.1.14-1.fc32
qubes-mgmt-salt-admin-tools.noarch 4.1.14-1.fc32
qubes-mgmt-salt-base.noarch 4.1.4-1.fc32
qubes-mgmt-salt-base-config.noarch 4.1.1-1.fc32
qubes-mgmt-salt-base-topd.noarch 4.1.3-1.fc32
qubes-mgmt-salt-config.noarch 4.1.14-1.fc32
qubes-mgmt-salt-dom0.noarch 4.1.14-1.fc32
qubes-mgmt-salt-dom0-qvm.noarch 4.1.4-1.fc32
qubes-mgmt-salt-dom0-update.noarch 4.1.9-1.fc32
qubes-mgmt-salt-dom0-virtual-machines.noarch 4.1.17-1.fc32
qubes-pdf-converter-dom0.x86_64 2.1.12-1.fc32
qubes-release.noarch 4.1-2.fc32
qubes-release-notes.noarch 4.1-2.fc32
qubes-repo-templates.noarch 4.1.2-1.fc32
qubes-rpm-oxide.x86_64 0.2.5-1.fc32
qubes-usb-proxy-dom0.noarch 1.1.1-1.fc32
qubes-utils.x86_64 4.1.16-1.fc32
qubes-utils-libs.x86_64 4.1.16-1.fc32
xfce4-settings-qubes.x86_64 4.0.5-2.fc32
Thanks fsflover.
Because Stage 2 failed, I had to upgrade the templates. I had this error: https://github.com/QubesOS/qubes-issues/issues/7251 so I’ve used the fedora snippet from https://github.com/QubesOS/qubes-dist-upgrade/blob/release4.0/scripts/upgrade-template-standalone.sh . After that I could install qubes-template-fedora-36.
Best,
Ivan
