Emergency Dracut Shell errors. Boot Drive unable to login to Qubes OS
When loading qubes, it takes longer than normal and asks for a root password and enters into shell.
I get the errors:
“Warning: /dev/qubes_dom0/root does not exist”
“Warning: Not all disks have been found.”
“Warning: You might want to regenerate your initramfs”
/dev/qubes_dom0/swap does not exist
crypto LUKS UUID ****************** (long character string) not found
I cannot figure out how to bypass this. I don’t want to erase and reinstall information on this drive so I need this fixed.
Updated BIOS firmware and tried again with no success.
I cannot figure out how to burn: rEFIt file using RUFUS ISO image burner to a extra flash drive. This may be able to find my drives.
I also tried multiple shell commands to find my drive volume number and I cannot figure that out.
I did try this suggestion with no success: Lost EFI entry in boot menu after removing and re-connecting drive - #8 by 51lieal
When I see the new drive and click it to boot it up, it will just take me directly to windows 10.
@51lieal
Also, I tried this: Lost EFI entry in boot menu after removing and re-connecting drive - #11 by 51lieal
I am unable to identify my exact directory name.
I tried command: lsblk and it does nothing.
I believe my directory name is sdc3 because when using the recovery boot usb, it does mention this directory name and asks me to login to root with the password.
Hi @lovely, welcome to the Community!
Just guessing. Did you attempt to restore your installation with the using a Qubes USB stick?
@fsflover I tried that. It does the same thing. How do you recommend restoring it? it goes to the same shell screen
I tried rescue a qubes os system.
Should I try troubleshooting? do we have next steps for each of these processes? I’m willing to pay someone for the help.
@fsflover I performed the qubes os system step and it asks for my password then after it will say “you dont have any partitions. Rebooting”
I loaded the hard drive with the qubes os installation onto a computer with gparted and here is the report:
/dev/sdc1 = EFI System partition Fat32 600mib (7.89 mib used) flags = boot; esp
/dev/sdc2 | file system: ext4 | 1 gib
/dev/sdc3 [Encrypted lvm2 pv | mount point = qubes_dom0 | 181.76 gib
unallocated | 1.00 mib
I am willing to pay $50 + tip in btc to whomever can give me 1on1 support to solve this issue.
Unfortunately this is beyond my level of expertise. All I can do is to point out to a couple of semi-relevant threads:
I am willing to pay $50 + tip in BTC to anyone who can provide 1on1 support to solve this ASAP.
My other thread isn’t getting any user support.
I get the errors in shell after the gui boot screen:
Even in such case, you should not create new topics for the same problem. Every new post in your original thread puts it to the top of Qubes OS Forum, so if anyone can help, they should already see it. I’m merging this thread to there to help other users find (future) solution more easily.
I need your help @tanky0u and willing to pay in xmr please assist!
@BEBF738VD and @51lieal can you guys help me out with this?
please let me understand…
If You boot from usb , get a recovery shell and try lsblk /dev/sdc3, what’s the UUID You get?
Cheers,
M.
I think Mila is on the right track – my question would be:
Does the output from[1]
lsblk /dev/sdc3 | grep luks
match what GRUB has as
rd.luks.uuid=luks-...
[1] Adjust sdc3 to match the name of your drive.
@mila It says “not a block device” when typing lsblk /dev/sdc3 in shell using recovery
@ChrisA
same thing when i type in: lsblk /dev/sdc3 | grep luks
"not a block device"
I checked gparted in a different linux distro, and these are the /dev’s i found below
Did remember to check/adjust the name of the drive?
how do i find the name of my drive. I don’t remember my name. the Label name? the label name was New G thats the option that I get when I go into boot manager and it lets me select windows or New G (aka Qubes OS)
Oh - the name is /dev/sdc3 … can you try a plain:
lsblk
with lsblk here is what i found
name sdb 183gb 0 disk
sdb1 600mb
sdb2 1gb
sdb3 | SIZE 181 gb
sdc 20gb disk /run/install/repo
