Hey,
While running dom0 update via whonix-gw as updateVM recieve next error:
Checking for dom0 updates...
Unable to detect release version (use '--releasever' to specify release version)
- Curl error (6): Coudn't resolve host name for https://yum.qubes-os.org/r4.3/current/host/fc41/repodata/repomd.xml.metalink [Could not resolve host: yum.qubes-os.org]
Error: failed to download metadata for repo 'qubes-dom0-current': Cannot prepare internal mirrorlist: Curl error (6): Coudn't resolve host name for https://yum.qubes-os.org/r4.3/current/host/fc41/repodata/repomd.xml.metalink [Could not resolve host: yum.qubes-os.org]
Failed to check for dom0 updates
After reboot any qubes start with next error:
Sudo lvremove qubes_dom0/vm-sys-net-private-snap
device-mapper: message ioctl on (252:9) failed: File exists
Failed to process message "create_snap 182 22":
Thin pool qubes_dom0-vm--pool-tpool. (252:9) already contain thin device with device:id 182.
Manual intervention may be required to remove device dev_id=182 in thin pool metadata.
Optoonally new thin volume with device_id=182 can be manually added into a volume group.
WARNING: When uncertain how to do this, contact support!
Failed to suspend qubes_dom0/vm_pool with queued messages.
Failed to update pool qubes_dom0/vm-pool.
`xl list
Name ID Mem VCPUs State Time(s)
Domain-0 0 4080 16 r----- 50.1
I never tried to set dom0 16vCPU (shocked).
Another indicator:
sudo lvm lvs
vm-sys-net-private-snap qubes_dom0 Vwi-a-tz-- 2.00g vm-pool vm-default-dvm-private 0.00
How to handle that?
Found same issue appeared at 4.2.4:
