Change default-dvm from Fedora 38 to Fedora 39
Hello,
new template Fedora 39 successfully downloaded and already replaced the old Fedora 38 templates in 39.
Now the problem. Now I want to change the last template, the default dvm from fedora 38 to fedora 39. would work if it wasn’t for the sys-usb. Because I would have to switch it off to be able to change the template. Well, if I shut it down I can’t do anything anymore, because my mouse and keyboard are attached to it.
Any ideas?
The command (in dom0 terminal) is:
qvm-shutdown --wait sys-usb; qvm-prefs -s sys-usb template dvm-default; qvm-start sys-usb
But best way is, you clone your default-dvm to a default-fedora-39-dvm and then insert:
qvm-shutdown --wait sys-usb; qvm-prefs -s sys-usb template default-fedora-39-dvm; qvm-start sys-usb
…and so on the next time
fedora-40
fedora-41
The command stops sys-usb // change the template // starts sys-usb again. You don’t have to do anything with keyboard and mouse during this…
5 seconds of fear!
okay, it worked, thanks
potentially followed by disaster.
I always recommend a failsafe:
#!/usr/bin/bash
sleep 10
qvm-prefs sys-usb template <NEW_TEMPLATE>
qvm-start sys-usb
## Delete this section after testing
sleep 120
qvm-shutdown sys-usb
sleep 10
qvm-prefs sys-usb template <OLD_TEMPLATE>
sleep 5
qvm-start sys-usb
That gives you 2 minutes to test out the new template backed sys-usb,
and will then revert to the old.
Once you are happy you can delete, or comment out, the testing section, and
rerun the script to make the change permanent.
Okay, thanks.
Does this text have to be in the #!/usr/bin/bash ?
and then execute it?
Or just write it in the terminal from Dom0 one after the other?
I’m just making a documentation for next time.
You have to write unmans text into a file, which you can execute (i.e. change-sys-usb-template.sh) and store wherever you want.
This is already documented here:
https://www.qubes-os.org/doc/templates/#switching
Perhaps you should update the documentation above and/or upstream your script into Qubes.
I’m looking for an option that is similar because Qubes is my daily driver on my desktop and I am picky about my keyboard. I really like this type of solution because it is the creation of an editable script that could progress with the system.
Here is my process when I tested it today:
Saved the text as <filename> .
Used chmod -x <filename> in a terminal window in the correct directory to make it executable.
Had to bash <filename> for it to run.
I got the following errors:
qvm-shutdown: command not found
qvm-prefs: command not found
qvm-start: command not found
Here is where I could use some clarification in the process:
It makes sense that these commands can only be run from dom0. Is that a correct assumption?
I read how to move a file to dom0 in unman’s post.
or I know that I could write using an editor like vim in a dom0 terminal. Is there a gui text editor equivalent in dom0?
or could I somehow ask dom0 to execute a file in a vm but it run in dom0?
What would the best practice be for security? (Outside of buying a ps2 keyboard or reinstalling when a new qubes image is available, of course?)
chmod - removes the mode bit
You want chmod +x
Yes
nano may suit you better than vi
You are awesome! Thank you for the help.
I’m so glad that I did this as a practice with a script! I would have locked myself out again.
qvm-prefs: error: template for DispVM must have template_for_dispvms=True
Then tried in dom0 terminal
qvm-prefs --set fedora-39-dvm template_for_dispvms True (also tried with the ‘=’ included)
and got this error
qvm-prefs: error: no such property: ‘template_for_dispvms’
‘template_for_dispvms’ shows up under man qvm-prefs but not under qvm-prefs --help-properties fedora-39-dvm
Under the ‘–help-properties’ info I couldn’t find a similar property.
I’m at a loss of how to change it. Any idea what I missed?
So I spent a few minutes reading and testing some of the commands to change my default-dvm when I am using a desktop with only usb keyboard.
Here is what I made as a bash script.
# change-default-template
qvm-shutdown --force sys-net
qvm-shutdown --force sys-firewall
qvm-shutdown --force sys-usb
qvm-shutdown --force sys-whonix
sleep 20
echo "Testing NEW Template"
qvm-prefs --set default-dvm template fedora-39-xfce
sleep 15
qvm-start sys-net
qvm-start sys-firewall
qvm-start sys-usb
qvm-start sys-whonix
#Comment out this section after testing
sleep 120
echo "Restoring OLD Template"
sleep 20
qvm-prefs --set default-dvm template fedora-38-xfce
sleep 5
qvm-start sys-usb
qvm-start sys-net
echo "Template Change Test Completed"
#end comment out section
Does anyone suggest a better method other than forcing qvm-shutdown or is there a better order to shut down templates? I’m self taught with this. I guess most people are really. If you’re new to Qubes and want an explanation of what it is doing line by line let me know and I’ll update this.
qvm-shutdown --force --wait sys-net sys-firewall sys-usb sys-whonix
I tested your suggestion as I made some changes recently. It worked much better. Thank you again.
Hello everyone,
new version, new luck.
I am now trying to upgrade my default dvm to fedora 40.
qvm-shutdown --wait sys-usb; qvm-prefs -s sys-usb template default-fedora-40-dvm; qvm-start sys-usb
I did everything like this, now I get the following error message:
qvm-frefs: error: template for DispVM must have template_for_dispvms=True
No idea, where do I have to change something to execute the command?
You need to set the “Disposable template” option in the default-fedora-40-dvm qube Settings → Advanced tab for it to be a disposable template.
okay, I just tried that. The error appears:
ERROR: Advanced tab:
Invalid property “template_for_dispvms” of fedora-40_dvm
What can I do?
How did you create fedora-40_dvm qube? It is clone of fedora-40 template?
TemplateVM can’t be disposable template.
Disposable template should be app qube (AppVM).
yes, I downloaded Fedora 40 according to the description. Then I created 2 clones, one with the name fedora-40_App and one with fedora-40_dvm. So I have 3 templates. The fedora-40_AppVM is for my App VM and the dvm clone should be for my dvm. What do I have to do differently, I don’t understand what I have done wrong
i just want to change my “default-dvm” where my sys usb and my sys-firewall is running the template for it from fedora-39 to fedora-40.
The name for my template fedora-40_dvm I have chosen only so that I know that it is the template for the default dvm.
Disposable template is an app qube, not a template qube:
Create default-f40-dvm app qube based on fedora-40 template.
Open default-f40-dvm qube Settings → Advanced tab and enable “Disposable template” option.
Now you have default-f40-dvm disposable template qube.
