Change default-dvm from Fedora 38 to Fedora 39
ah okay, now I’ve understood. I copied the default-dvm, put the Fedora-40 template into the copy, then executed the command at Sys-USB that it changes the dvm template into the dvm copy, restarted Qube. Then I changed the template in the old dvm-default to Fedora 40, then used the Sys USB again in the old dvm-default as template and deleted the Fed 40 dvm copy.
Now everything works. Let’s see if I can do it in a year with Fed 41 without any questions :smiley: :smiley: :smiley:
Thank you for your support. Best regards
