Firstly, I posted this in the mailing list but it hasnt gotten any responses there and I really want to get this working as I have only been able to get it working in fedora 31 minmal (which has reached EOL). Below I tried outlining the procedure I have used (that isnt working). While I have gotten it to work in fedora 31 minimal on my desktop, I have tried getting it to work on fed32 minimal, deb10 minimal, and centos7 minimal, and tried it on my laptop - but have not been sucessful so far. Considering, I am assuming I am doing something incorrectly so any thoughts on what I have outlined below, would really really be appreciated:
I start with
sudo dnf install qubes-repo-contrib && sudo dnf update && sudo dnf upgrade
then sudo dnf install qubes-tunnel
Intially I think I was just doing that and not installing anything else but in trying to figure things out I started installing packages that the minimal docs page says are needed for NetVM and VPN qube (things like openvpn and qubes-core-agent-networking qubes-core-agent-network-manager NetworkManager-wifi network-manager-applet wireless-tools notification-daemon gnome-keyring polkit and sakura, a term i can paste into)
The above now seems to work ok, but then I create an appvm - vpnfed32, select the template (centos/deb/fed32 minimals) then check the “provides network” then go to the Services tab and add qubes-tunnel-openvpn then click ok.
Then I make sure the template and new appvm are closed, then start up the vpnvm from dom0:
qvm-run -u root vpnfed32 sakura &
and run
/usr/lib/qubes/qtunnel-setup --config
then enter my vpn provider (PIA) username then password
then copy one of the pia .ovpn profiles to
/rw/config/qtunnel/qtunnel.conf
then shutdown the vpn vm, then open the settings for another appvm set vpnfed32 as the networking vm to vpnfed32 and then try to start the AppVM (that I just set to use vpnfed32) up but nada, no connection to the internet at all. I have tried with protonvpn as well and still nothing so I really am… stumped
