Hello, I need urgent help please.
I was planning to set up qubes-remote-desktop (GitHub - QubesOS-contrib/qubes-remote-desktop ).
To do this I first created
sudo qubes-dom0-update qubes-remote-desktop
vncpasswd
qvm-service --enable dom0 qubes-x0vncserver
systemctl start qubes-x0vncserver@user
executed. I executed the command from this post (Remote Qubes User Testing (Running Qubes in the Browser) )
echo "qubes.ConnectTCP +5901 remote-admin @default allow target=dom0" | sudo tee - /etc/qubes/policy.d/30-remote-admin.policy
This did not work and I tried ConnectTCP via
Understanding firewalling in Qubes Every qube in Qubes is connected to the network via a FirewallVM, which is used to enforce network-level policies. By default there is one default FirewallVM, but the user is free to create more, if needed. For more...
This did not work either and now the service qubes-qrexec-policy-daemon is not running.
[user@dom0 Desktop] systemctl status qubes-qrexec-policy-daemon
...(code=exited, status=1/FAILURE)
Sep 29 09:56:12 dom0 qrexec-policy-daemon[8378]: qrexec.exc.PolicySyntaxError: /etc/qubes-rpc/policy/-:1: invalid action: remote-admin
What I have tried so far: Deleting the files /etc/qubes/policy.d/30-remote-admin.policy as well as /etc/qubes-rpc/policy/qubes.ConnectTCP and rebooting the computer and restarting services. Without success.
I do not find any other reference to remote-admin and I’m afraid of doing more damage.
Maybe there is a cache which I need to delete?
deeplow
September 29, 2022, 8:17am
2
From the status message I see:
Can you try running in the dom0 terminal the following:
grep -r 'remote-admin' /etc/qubes/policy.d/
It should show in which file you still have a remote-admin action that is messing up your configuration
Thanks for the fast response. No, there is no output.
deeplow
September 29, 2022, 8:21am
4
Do you have a qube called remote-admin? (step 1 of the guide)
Yes. I followed the steps and created a debian based qube remote-admin
deeplow
September 29, 2022, 8:22am
6
Then let me check the commands I ran. It could be that I mistyped something.
Sure. If you need more logs or further information, just let me know.
One thing I noticed was that there was no command called vncpassword after installation.
Just vncpasswd. But I think it’s not related to this issue.
deeplow
September 29, 2022, 8:27am
9
Yes. That was a typo which I just fixed. Thanks!
deeplow
September 29, 2022, 8:29am
10
Rnd3sB3g13rng:
Ah. I see what the problem might be. Did you perhaps foget to type the .d? It was supposed to be /policy.d/ and not /policy/. And it’s not just this but also /etc/qubes/policy.d/ and not /etc/qubes-rpc/policy/.
Notice the command:
I did not forget it and executed exactly your provided command.
I have deleted the files /etc/qubes/policy.d/30-remote-admin.policy and /etc/qubes-rpc/policy/qubes.ConnectTCP so I don’t know why there is still a reference to remote-admin
Also this command
yields no result.
deeplow
September 29, 2022, 8:33am
12
And now I noticed another issue with the guide. It should have been 5900 and not 5901
deeplow
September 29, 2022, 8:34am
13
Try
grep -r 'remote-admin' /etc/qubes-rpc/
Ahh I did find a difference:
# your command
# my command
echo "qubes.ConnectTCP +5901 remote-admin @default allow target dom0" | sudo tee - /etc/qubes/policy.d/30-remote-admin.policy
deeplow
September 29, 2022, 8:35am
15
Ah. That was it, then! But don’t forget to change +5901 to +5900 in this and the following command
Ahh yes
/etc/qubes-rpc/policy/-:qubes.ConnectTCP +5901 remote-admin @default allow target dom0
deeplow
September 29, 2022, 8:37am
17
OK. That’s my fault. the tee command shoudn’t have the - dash. I have fixed it in the guide now.
I get
[user@dom0 policy] ll
-rw-r--r-- 1 root root 63 Sep 28 22:58 -
So can I savely delete this file?
deeplow
September 29, 2022, 8:40am
19
Yes. You were the one creating with my wrong tee command. And I don’t have it on my Qubes system. So you’re good to go.
It has those permissions because you created it with sudo.
That did it. So the correct command is
echo "qubes.ConnectTCP +5900 remote-admin @default allow target=dom0" | sudo tee /etc/qubes/policy.d/30-remote-admin.policy
