Brave and Vivaldi don't connect to internet with mullvad vpn
Hello to everyone.
Im facing with a problem using brave browser or vivaldi browser using a VM (both fedora or deb) linked to a netVM mullvadVPN. Firefox works really well and mullvad vpn works fine too. When I utilize other browser like Brave it says “this site can’t be reached, try - checking the connection - checking the proxy and the firewall”.
I tried to changes a lot of settings, removed extensions, set no proxy… but nothing.
It can be useful, i set my mullvad vpn following this guide: Mullvad on Qubes OS 4.
Thank you :pray:
My guess is you have a DNS problem, and Firefox is configured to do its own DNS resolving using DoH or DoT.
In the web browser qube, open a terminal and try
ping qubes-os.org
does it display an IP?
yes, it shows me the ip address
Do you have Qubes OS 4.1?
This guide shouldn’t work for Qubes OS 4.2:
iptables rules are no longer effective in Qubes OS 4.2.0 and newer.
I have Qubes 4.2
This Qubes 4.2 guide should work for you:
If you want a non-GUI setup I would recommend this wireguard guide:
In this guide you will also find a very simple solution for VPN harding:
try ungoogled-chromium.
