Audio qube
Yea, output:
packages installed
pipewire-qubes.x86_64 4.3.11-1.fc42 qubes-vm-r4.3-current
Last one and I have no more idea, it might be something that changed in Q4.3
sudo fuser /dev/snd/*
/dev/snd/cotrolC0: 610 757
/dev/snd/seq: 754
                     USER        PID ACCESS COMMAND
/dev/snd/controlC0:  root        663 f.... alsactl
                     user        709 F.... wireplumber
/dev/snd/seq:        user        708 F.... pipewire
I have same error but sound works
aplay -L
I will test it after clean installation, in few days.
Did you made sys-audio on base of minimal template or xfce template?
Welcome to AudioVM Hell. I’m right here beside you.
I spent months trying to get mine to work, then finally discovered it won’t work when audio is going out over HDMI. I had to buy a usb device to output audio to get it to work (and that device does bad things to the sound quality) so I ended up, after all that work, just not using it even after I got it to work.
That’s why posting real output of command and not what you think is relevant is essential - nobody would guess what output is used if user says
I have very similar Intel sound as you
