It is a regression, the issue seems to be that the pulseaudio version used in the stubdom is too old compared to the stubdom kernel.
The pulseaudio process crash in the stubdom
Some relevant logs here:
(no issue with the domid, the value is correct)
[2025-11-02 07:32:52] + pulseaudio '--use-pid-file=no' '--daemonize=no' '--exit-idle-time=-1' -n -L 'module-native-protocol-unix auth-anonymous=1 socket=/tmp/pa.sock' -L 'module-vchan-sink domid=1'
[2025-11-02 07:32:52] pulseaudio[55]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[2025-11-02 07:32:52] W: [pulseaudio] authkey.c: .[1mFailed to open cookie file '/tmp/pulse/cookie': No such file or directory.[0m
[2025-11-02 07:32:52] W: [pulseaudio] authkey.c: .[1mFailed to load authentication key '/tmp/pulse/cookie': No such file or directory.[0m
[2025-11-02 07:32:52] W: [pulseaudio] authkey.c: .[1mFailed to open cookie file '//.pulse-cookie': No such file or directory.[0m
[2025-11-02 07:32:52] W: [pulseaudio] authkey.c: .[1mFailed to load authentication key '//.pulse-cookie': No such file or directory.[0m
[2025-11-02 07:32:52] E: [pulseaudio] module-vchan-sink.c: .[1;31mvchan module loading.[0m
[2025-11-02 07:32:52] E: [pulseaudio] module-vchan-sink.c: .[1;31musing domid: 0.[0m
[2025-11-02 07:32:52] E: [pulseaudio] module-vchan-sink.c: .[1;31mplay libvchan_fd_for_select=14, ctrl=0x561ea70b2d60.[0m
[2025-11-02 07:32:52] E: [pulseaudio] module-vchan-sink.c: .[1;31mrec libvchan_fd_for_select=22, ctrl=0x561ea70b3790.[0m
[2025-11-02 07:32:52] E: [vchan-sink] module-vchan-sink.c: .[1;31msink cork req state =1, now state=-2.[0m
[2025-11-02 07:32:52] E: [vchan-sink] module-vchan-sink.c: .[1;31msource cork req state =1, now state=-2.[0m
This error:
is directly related to having a kernel too recent for the pulseaudio version (warning / restriction have been imposed by the kernel on memfd_create that the current version of pulseaudio donât respect yet. More recent version of pulseaudio respect it)
If someone is motivated, create a github issue / try to write a pull request
(note: tested in R4.3)
Created an issue [R4.3] pulseaudio process crashing in stubdom for Windows VM ¡ Issue #10379 ¡ QubesOS/qubes-issues ¡ GitHub
