OK, running ‘xfce4-panel --disable-wm-check’ seems to have gotten the menu back, but has thrown a whole load of warnings about service files not being provided.
If I stop this process, the menu vanishes. The menu is also now being run as root.
When I boot, there is no menu, I have to use the method above to get it to appear.
sys-usb now fails to start
I have no network connection, and the icon for network connection isn’t in the menu, what is the application named?
I have updated from fedora-34 to 35 over the weekend. It seemed to work fine until yesterday, when there were a couple of fedora 35 updates. Dom0 hasn’t updated in the last while.
Service file ‘/usr/share/dbus-1/services/org.xfce4-notifyd.Notifications.Service’ is not named after the D-Bus name ‘org.freedesktop.Notifications’
Service file ‘[…/]org.xfce4.Thunar.FileManager1.service’ is not named after the D-Bus ‘org.freedesktop.FileManager1’
pciback 0000:00:1d.0: xen_pciback: cannot enable memory-write-invalidate (-22)
pciback 0000:00:1d.0 cache line size of 64 is not supported.
Same for 14 and 1 (in place of 1d)
libvirtd[3266]: internal error: Unable to reset PCI device 0000:00:14: no FLR, PM reset or bus reset available
From /var/log
Lots of Gtk warnings about drawing a gadget with negative dimensions
Failed to terminate process 6271k, no such process
